Old Jan 10, 2013, 12:26 PM
helicopter_new is offline
Find More Posts by helicopter_new
Austria
Joined Sep 2008
One question please. If I use Genius' main motor with Mini's main gear what will be the results? There will be any temperature issues? Should I try it?
Thanks!
helicopter_new is offline Find More Posts by helicopter_new
Old Jan 10, 2013, 01:02 PM
i812 is offline
Find More Posts by i812
i812's Avatar
Joined Aug 2009
Originally Posted by Xermalk View Post
Update, its definitely not vibrations. With the main/tail motors disconnected the swash still slowly but constantly tilts to the right, even happens when i hold it tilted. Its as if the rx is constantly getting a aileron right signal when its receiving a throttle signal.
This is very strange and i even tried using a completely new model slot on my 7e with the same issue.
Do both AIL Servos move (one tilts UP and the other tilts DOWN) when the Swash drifts toward the right AIL direction?
i812 is offline Find More Posts by i812
Old Jan 10, 2013, 01:38 PM
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Yup, but seems i got rid of it by downgrading from 1.3 to 1.1 and resetting all models on my devo 7e.
Xermalk is offline Find More Posts by Xermalk
Old Jan 10, 2013, 03:27 PM
Crash Survivor is offline
Find More Posts by Crash Survivor
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
Where did you get 1.3 from all I see is 1.1 for the MCP & none for the 7e.
Crash Survivor is offline Find More Posts by Crash Survivor
Old Jan 10, 2013, 04:04 PM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
Oh, so it seems they removed it.
I spotted it on the 31'th http://www.rcgroups.com/forums/showt...6#post23669467
Tom also mentions it in his thread. http://www.rcgroups.com/forums/showp...&postcount=544
still have the file for it if anyone wants to test it.
Old Jan 10, 2013, 04:57 PM
Dleach1407 is offline
Find More Posts by Dleach1407
Joined Dec 2012
does anyone have a copy of the current mini cp 1.1 bin file. I downloaded the current one from the website after fixing the address it sends you to LOL. When I attempt to extract it, it gives me an error. i am able to extract other files downloaded from their website. Please let me know.
Dleach1407 is offline Find More Posts by Dleach1407
Old Jan 10, 2013, 05:55 PM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
soft_file_1337670581676_MiniCP.zip
Last Modified 12-04-12
https://skydrive.live.com/redir?resi...A131FE32C0!165
Old Jan 10, 2013, 06:03 PM
Joined Dec 2012
when i attempt to extract that file using winzip I get an error.
Old Jan 10, 2013, 06:22 PM
DantHimself is offline
Find More Posts by DantHimself
Joined Oct 2012
try winrar, just tested and worked
DantHimself is offline Find More Posts by DantHimself
Old Jan 10, 2013, 06:25 PM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
Works just fine with winrar and 7zip? Even windows builtin zip manager can extract it.
Old Jan 10, 2013, 08:59 PM
Joined Dec 2012
That was my own stupid mistake. I got it, the file posted is good, but walkeras site has a corrupted .bin file I'm going to update to that version in just a bit. Is there a reason not to do the update?
Old Jan 11, 2013, 05:47 PM
thomasprevere is offline
Find More Posts by thomasprevere
Greece, Attica, Nea Ionia
Joined Feb 2011
Originally Posted by Crasy666 View Post
you need to bridge that resistor on the "top back" side of the RX that will eliminate the LVC, but also show wrong value on the telemetry (of course the same ADC input used on the processor.
see the attached photo, sorry need to take a photo from the German heli board:
That works perfect, 4:30min on a HP05S with 5400 RPM and 260mAh consumption out of the HK 300mAh 45c battery
Rgds
crasy666
WOW! 4.30min with 260mah battery?
Ι have to bridge that resistor with a little wire?
Can you tell me more datails is IT difficult to bridge it?
thomasprevere is offline Find More Posts by thomasprevere
Old Jan 11, 2013, 06:03 PM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
He clearly stated he uses a HK 300 mah battery.
The LVC is there for a reason, one should only consider disabling it if one has a very power hungry brushless setup, resulting in major voltage drops.
On a stock mini it kicks in once a pack has been drained to 3,75-3.8v. One should not drain battery's more under load as this reduces their lifetime.
Old Jan 11, 2013, 06:18 PM
Joined Feb 2011
Rgds
crasy666
I did it but i dont know if i did it write , i solder it with a solder ball ,i think
know voltage on telemetry is 88,7volt
mini starts when i plug battery, itss very small this resistor , i dont know what i did i hope with a lot of luck that i solder it good
Old Jan 11, 2013, 06:26 PM
Joined Feb 2011
300 mah with hp05s and 4.30min = perfect!
i have hp05 and lvc cut me at 3.80 .385.or 3.90 it depends of battery , i dont like to cut me at this voltage!
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
