Old Jan 07, 2013, 12:06 AM
microrcfiend is online now
Find More Posts by microrcfiend
microrcfiend's Avatar
United Kingdom, England, Sheffield
Joined Jun 2012
Happy new year guys, finally got my mini cp inverted today after all the issues and it feels fantastic. not having 35C nanotech was my biggest issue and now I see hobbyking lists 45C now too. Is this the most powerful that will fit the stock tray under 400mah? I see some 2s 350mah 65C that may be worth splitting up
mini cp first flips and inverted flying (3 min 32 sec)
V120d02s is on the way but the brushless mod is calling louder by the minute. Has anyone bought the rc711 already modded one? How does it perform compared to the walkera drop in one or one made from parts from the Jade dude?
http://www.rc711.com/shop/24g-walker...65_122_292_294
Thanks to everyone patient enough to put up with my complaining and still offering advice, it really did help my sanity.
microrcfiend is online now Find More Posts by microrcfiend
Old Jan 07, 2013, 12:51 AM
sbstnp is online now
Find More Posts by sbstnp
Deviant
sbstnp's Avatar
Australia, NSW, Sydney
Joined Jul 2012
http://www.youtube.com/watch?v=ulAOZwTqhOU
This is a subject that comes up pretty often. The cheapest and most optimal combination for a brushless mod comes you guessed it from HobbyKing.
1. 14000kv motor
2. 10A Brushless ESC
3. ESC flashing stick, for use use BLHeli
Optional (if the tail doesn't hold):
4. 7mm FBL100 tail motor
5. FBL100 tail motor mount
6. FBL100 tail motor fin
First 3 should be around $50, half the price found everywhere else. Info about mounting can be found in this thread or on helifreak. Good luck
sbstnp is online now Find More Posts by sbstnp
Old Jan 07, 2013, 02:01 AM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
Would the 14000 kv motor work with a 7A esc?
I ordered that last week, thinking that it will work .
miketre is offline Find More Posts by miketre
Old Jan 07, 2013, 02:16 AM
Deviant
sbstnp's Avatar
Joined Jul 2012
Yes, it will without any problem. The reason I list the 10A ESC is because it already has a flashing connector mounted on and makes updating and setting up BLHeli a lot easier. And yeah, it has really good FETs.
Old Jan 07, 2013, 04:43 AM
miketre is offline
miketre's Avatar
Joined Dec 2010
Thanks. I did a search on this thread and read that a BLheli flashed ESC does not need an additional signal convertor. Is this true?
I got a Genius CP, a brushless motor and an ESC that suports blheli. Everything except for a signal convertor.
If this is true, then it is great news for me indeed!
Old Jan 07, 2013, 06:47 AM
Crasy666 is online now
Find More Posts by Crasy666
Crasy666's Avatar
Germany, BY, Nord
Joined Oct 2012
but the ESC from Hobbyking doesn't work out of the box on the negative main motor connector of the Mini CP RX, there is a hardware difference between the real WK customized Oversky 10A ESC and this one from Hobbyking (or the same from Oversky for the MCPx) I have both and can confirm that the HK doesn't work, there is a resistor different on the input, but since I burned my HK ESC, I need to wait for the new one to double check)
to get the HK ESC working on the Mini CP you need to solder the input on this pin 1 or 2:
see also the separate thread for the Oversky ESC
I hope to try if that resistor mod / capacitor removal will work to modify a HK ESC to a "real" Oversky 10A ESC working on the Mini CP.
Rgds
crasy666
Crasy666 is online now Find More Posts by Crasy666
Old Jan 07, 2013, 08:06 AM
Deviant
sbstnp's Avatar
Joined Jul 2012
Rgds
crasy666
That's my picture and yes, that's correct.
For performance's sake, you would get rid of the connectors and solder everything down anyway, so I look at the price
Old Jan 07, 2013, 08:55 AM
Crasy666's Avatar
Germany, BY, Nord
Joined Oct 2012
and as soon as I get my new 10A ESC from HK (in transit) I will check, if it can be easily modified from a "MCPx" to a WK version by soldering the 1k resistor at the input and removing the capacitor, I have now two ESC in my hand, the original Oversky WK and the HK, so it should be easy to measure the difference.
if that will work, you can get for 14 USD a great ESC, the softstart itself is perfect like on my YGE ESC for my bigger heli, (a German ESC with all options like Gov (store mode), different timing and frequ.......)
I ordered the 14000kv motor from HK so will be able to compare the 11000kv c05m, the 13000kv c05m, the HP05s 14000kv and this 14000kv HK motor, let's see.
Rgds
Old Jan 07, 2013, 11:43 AM
OiOi is offline
Find More Posts by OiOi
Joined Apr 2009
1. 14000kv motor
What Pinion/main gear do you recommend for this motor?
OiOi is offline Find More Posts by OiOi
Old Jan 07, 2013, 12:38 PM
Crash Survivor is offline
Find More Posts by Crash Survivor
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
I ordered 1 also, should be getting it soon, but no tracking info for some reason. Right now I'm running a HP05S & 8T & GCP main with a 7mm HM-V120D06-Z-09 tail motor. I'm going to use same setup & looking for close to same performance but more run time I hope.
Crash Survivor is offline Find More Posts by Crash Survivor
Old Jan 07, 2013, 02:01 PM
thomasprevere is offline
Find More Posts by thomasprevere
Greece, Attica, Nea Ionia
Joined Feb 2011
I have the same setup HP05S 8T but with mini main gear, you set 100 % throttle or less?
What batterys do you use ? i use nano 300 45 c and some others 350 20c and 25 c
but my flyingtime sucks!! 2 or 2.30 minutes with 100%
i dont know whats going wrong
thomasprevere is offline Find More Posts by thomasprevere
Old Jan 07, 2013, 02:08 PM
Joined Feb 2011
Rgds
hi, i have oversky 10a esc for walkera, recently i order from hk this 10A esc this esc dosent fit too walkera mini cp ,it needs modifacations?
Old Jan 07, 2013, 02:21 PM
Deviant
sbstnp's Avatar
Joined Jul 2012
I will run Mini main gear with a 8T pinion. Probably 7T is good too if you're a beginner.
I don't know about 9T, I'm not familiar with this motor but I suspect it could bog down on hard collective. Motors this small don't have enough torque to run with 6k headspeed.
Old Jan 07, 2013, 02:22 PM
Deviant
sbstnp's Avatar
Joined Jul 2012
Yes, HK needs signal from a FET on mini RX and not from the motor plug. But is an easy job if you can solder (don't see why anyone couldn't solder tbh).
Old Jan 07, 2013, 02:31 PM
Heli Crash Survivor
Joined Feb 2011
Those flight times seem about right. I run 100% throttle & timer set for 3 minutes. Then land a little after & batteries are at upper 3.77 to 3.8. I have an old V100D08 & the stock batteries fit the MCP tray perfect. Also took the tail motor off of V100D08 which keeps the tail rock solid on the MCP. The GCP main gear I heard is a better gear ratio with a BL setup.
HM-V100D08-Z-10: Battery 3.7v 350mAh 25C for Walkera V100D08 Helicopters
http://www.wowhobbies.com/hm-v100d08-z-10_battery.aspx
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9888 Jan 15, 2016 02:26 AM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 11:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 12:38 PM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 08:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 06:07 PM
