Old Dec 24, 2012, 08:39 PM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
Any tips on installing the metal pinions on these motors? I'm afraid of bending the shaft when I take a hammer to it.
Is there a plastic pinion sold somewhere?
miketre is offline Find More Posts by miketre
Old Dec 24, 2012, 08:43 PM
Crash Survivor is offline
Find More Posts by Crash Survivor
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
All the pinions I purchased are slip on & you use red loctite,
Crash Survivor is offline Find More Posts by Crash Survivor
Old Dec 24, 2012, 08:51 PM
DantHimself is offline
Find More Posts by DantHimself
Joined Oct 2012
Aren't you supposed to apply heat to the pinion to install?
DantHimself is offline Find More Posts by DantHimself
Old Dec 24, 2012, 09:45 PM
pmerritt is offline
Find More Posts by pmerritt
Joined Oct 2010
only if it doesn't slip fit as it should....otherwise it should fit.
pmerritt is offline Find More Posts by pmerritt
Old Dec 25, 2012, 12:38 AM
i812 is offline
Find More Posts by i812
i812's Avatar
Joined Aug 2009
I've read that excessive heat permanently damages magnets.
Metals shrink when cold, and expand when hot; therefore instead of heating the Pinion, maybe the same difference could be accomplished by freezing the Motor?
When freezing the Motor doesn't work, I've had success installing tight Pinions on Shafts by carefully pressing them together sandwiched between two blocks of wood and a C-Clamp. One block of wood is about 2 inches thick, and is used as magnetic "insulation" between my metal C-Clamp and back end of magnetic Motor, and the other block of wood has a hole drilled allowing the Pinion to be pressed further on to the Shaft so it can be positioned for proper alignment with the Main Gear. Before tightening the C-Clamp, make certain not to pinch wires, and everything is aligned properly before putting the squeeze to it.
The Pinion hole can be enlarged with a drill bit, and/or the Shaft diameter can be reduced with abrasive as it spins.
I try to avoid using excessive heat with magnetic Motors; therefore, prefer Pinions that are press fitted, and remove them with a Gear Puller.
i812 is offline Find More Posts by i812
Old Dec 25, 2012, 02:36 AM
sbstnp is offline
Find More Posts by sbstnp
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
Originally Posted by Crash Survivor View Post
Ordered one anyway. May be the best indoor combo with the MCP to fly this winter.
Same, was waiting for it for a few months to be back in stock so I grabbed one.
sbstnp is offline Find More Posts by sbstnp
Old Dec 25, 2012, 04:35 AM
nac is offline
nac
Find More Posts by nac
nac
nac's Avatar
Melbourne, Australia
Hey Guys,
I am selling my kit if anyone is interested.
Walkera Mini CP with Devo 8s transmitter.
2.4G Walkera Devention Mini CP Flybarless Micro Helicopter.
Devo8S TX
extra receiver.
Portable Aluminium Case.
9 x lipo's.
2 x chargers.
Spare parts.
The lot for $250
nac is offline Find More Posts by nac
Old Dec 25, 2012, 07:53 AM
sbstnp is offline
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
Originally Posted by nac View Post
Hey Guys,
Devo8S TX
extra receiver.
9 x lipo's.
2 x chargers.
Spare parts.
The lot for $250
Keep the 8S and flash it with Deviation, http://www.deviationtx.com
Unless you get out of the hobby ofc.
By the way this is a good deal.
Old Dec 25, 2012, 10:22 AM
miketre is offline
miketre's Avatar
Joined Dec 2010
Thanks for the tips everyone.
I'm wating for my pinions from overskyrc to arrive. Hopefully, they will be an easy fit on my C05 motor from HK.
Old Dec 26, 2012, 04:47 PM
torsten01 is offline
Find More Posts by torsten01
Australia, TAS, Abels Bay
Joined Nov 2012
fluctuating rpms
As a newbee I have crashed my MIni a fair bit and am amazed that I only had to replace a boom and rear rotor!
Anyway, this is my problem: motor will now change revs up briefly w/o command change, Mini will hop up, sometimes change direction. Directional change -I guess- would be due to headspeed change, so probably just the one issue: very sudden motor speed change, fraction of a second, but makes it very hard to fly (for me!).
Is this the board? Or is the motor worn out (I use several batteries in a row and would have had it running too hot, I guess).
If it is the board: that means a new Mini is the only option.
If it is the motor, then a new one is needed.
Or an upgrade to brushless! With its own ESC the brushless should take care of this prob for sure? Right? Even if the std motor control on the board is damaged?
torsten01 is offline Find More Posts by torsten01
Old Dec 26, 2012, 06:09 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Does the main gear move up and down? If so, either the main gear is pushed partly down the main shaft or the lock collar just below the swash plate has moved up. Whichever the case, is causes erratic pitch and will seem like the motor is changing speed rapidly.
BThirsk is offline Find More Posts by BThirsk
Old Dec 26, 2012, 06:25 PM
harmony is offline
Find More Posts by harmony
Joined Nov 2005
I bought one mini cp with devo 8S a few days ago.
Everything is fine except that flight time is too short.
The flight time is 2 min with the original battery.
Hobbyking 300mAh lipo gives me 2:30 ~ 3 min.
I just did a hovering for the flight test.
The mini cp is without any MOD.
Telemetry function was off.
I downloaded a setting from walkera website.
I have searched getting answers for that, but I could not.
Some people says that 2 min flying is normal.
However, others say that they can fly more than 4 mins using stock battery.
What is true?
The followings are my experiments.
1) stock battery
flight time: 2 mins
Used: 120mAh
120mAh remains still. Is it normal???
2) hobbyking 300mAh battery
flight time: 2:30 ~ 3 mins (telemetry off)
Used: 150 ~ 180mAh
3) hobbyking battery teset
- discharge rate: 1A (This is the best configuration that my charge can support)
- discharged: 295mAh --> It seems that battery is normal.
4) telemetry on
- telemetry indicates 4.0~4.1V
- When starting hovering, the voltage goes to 3.7V.
- When a battery voltage becomes 3.3V, the battery cannot lift a mini cp.
From experiments, 50 mAh is used for 1 min flying.
harmony is offline Find More Posts by harmony
Old Dec 26, 2012, 06:48 PM
Joined Oct 2012
What is true?
1) stock battery
flight time: 2 mins
Used: 120mAh
Used: 150 ~ 180mAh
4) telemetry on
You should never push your batteries lower than 3.7 V on the fear of damaging and severely shortening their lifespan
From what I understand, brushed motors works better when near 100%. If your throttle and pitch curve are at their defaults and you are only hovering (40%~60% stick) then i think 2 mins is around right.
I dunno why but I dont trust my telemetry very much
Old Dec 26, 2012, 08:04 PM
Joined Nov 2012
Good idea, but not the problem. The collar was a little loose and I tightened it. End of main shaft flush with bottom of main gear. Everything turns freely. Here the result:
heli is stationary with just enough throttle to be light on skids, but NO movement fwd/back, l/r or up. Then -after a few seconds- heli jumps up (without ANY change on sticks) by 3 feet and shoots off to 2 o'clock.
I understand the change in direction as gyro gets confused when skid is on ground and will overcompensate when heli lifts. BUT what remains is a sudden change in RPM and the jump (problem here: difficult to identify whether the motor changes rpm or the swashplate changes and that leads to rpm change).
If the rpm change was caused by a faulty servo that changes pitch in the blades then the heli would jump too. You got me thinking here. I eyeballed the servos and carefully pushed the rods up and down. Nothing loose, nothing feels funny.
So we have -in my opinion- four possible causes here:
the esc on the main board (would a brushless conversion fix this?)
the mainboard controlling the servos (new main board)
the motor itself (that is not very likely, is it?)
the servo controlling lift (would I not feel broken servo gears by gently pushing the rods up/down?)
Any idea where to look next?? And my apologies the number of ? in this post!
Old Dec 26, 2012, 08:11 PM
harmony is offline
Joined Nov 2005
As far as I know, that is true only if there is no load for the battery.
When a motor runs, the voltage is dropped much.
(Please check the discharge graph for turnigy 160mAh 30C.
http://www.hobbyking.com/hobbyking/s...X100929X44.jpg)
As in the figure, the voltage decreases around 3.3~3.4V during discharge.
However, if the discharge stops (means no load), the voltage should goes up.
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
