Its been reported that the Genius Main Gear is a little thinner, has 64 teeth and larger diameter; whereas, the Mini Main Gear is thicker, has 61 teeth and smaller diameter. If everything else is kept the same, using a Main Gear with more teeth will result in a lower head speed per this equation: New HeadSpeed = (Old Main Gear tooth count / New Main Gear tooth count) * Old HeadSpeed If you want to use the larger diameter Genius Main Gear, but don't want the lower head speed, then you can use a larger Pinion to increase the headspeed per this equation (assuming everything else is kept the same): New HeadSpeed = (New Pinion Gear tooth count / Old Pinion Gear tooth count) * Old HeadSpeed The combination of both Gears being larger would result in the most clearance between Main Motor and Main Shaft. |
Austria
Joined Sep 2008
One more question, is the tail motor glued in its housing? I tried to push it out with no results. |
Joined Nov 2012
Hey experience flyers....
Newbie to Mini CP needing some advice. Just flew my CP for the first time today and I am happy to say I could fly it without any major crashes. Just a question.....to throttle up and get it off the ground I have to utilise 70% throttle ....is this correct?..... I have not changed any settings and this is how it came stock standard. Doesnt seem much room to left in the throttle? Apart from that it flys fine. The battery life is between 3 -5 mins, is that ok? Many thanks !! |
Joined Oct 2010
Batery life looks ok. |
Joined Nov 2012
Thanks heaps .....
United Kingdom, England, Sheffield
Joined Jun 2012
If you gt a devo7E and pitch seems messed up after copying the original model and changing it try a new model from scratch. The Devo7E does not copy models without errors happening when changing the copied model. |
Has anyone found any better servos to fit the mini.
I had another one lock up on me this morning. It locks up and you can't move the servo at all, either by had or with the sticks. The last one I fixed by taking it apart, although I really don't know what I did. This one i broken because I tried to move it by hand and did strip the large gear. I have not idea why these do this as I did not crash the heli. When I took the servo apart, all I could see is a piece of plastic floating around, but could not find where it came from. |
Also myrcmart has the WK one for 9 Are you running the servo saver mod? I haven't stripped on yet and have crashed really hard. |
The one this morning is stripped because I got mad and forced it until it stripped trying to unlock it. If I had crashed it hard, it would be understandable, but not normal operation. |
This may explain why it might be possible to strip a Servo Gear without crashing:
| Thread Tools | |
| Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! | DLY | Micro Helis | 9683 | May 24, 2013 10:34 PM |
| Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel | oomodel.com | Hot Online Deals | 12 | Oct 16, 2011 08:52 PM |
| Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" | Iceblade1A | Micro Helis | 91 | Sep 25, 2011 11:38 AM |
| For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 0 | Aug 16, 2009 07:38 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
