Old Nov 10, 2012, 11:11 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Originally Posted by zadaw View Post
Here is a thread here by someone who had exactly the same problem as you. He bought a Devo 8S from Helipal, and managed to get the transmitter fixed by Walkera directly. Perhaps you could contact him for details.
http://www.helifreak.com/showthread.php?t=455107
There are often problems in shipping electronic items back to China. Sometimes, the items even get taxed. That is why many vendors are reluctant to ship items back to China. We cannot get direct service from HH either and the vendors are reluctant to send things back to them. That is why many brands have a big advantage in their primary market.
Yes, I read that post several weeks ago and that was what gat me some false hope.
The parts to fix it are very cheap anyway. The controller is 5.09 and the screen is 10.00, both available from digikey. They are originally made by Texas Instruments. I have decided to fix my own as they are not really interested in helping their customers and the freight to get it to China is worth more than the parts to fix it.
BThirsk is offline Find More Posts by BThirsk
Old Nov 11, 2012, 12:17 PM
PonyBoy1973 is offline
Find More Posts by PonyBoy1973
Joined Mar 2011
Hey all,
I crashed my mini CP today, and now the poor thing will not power up. No indication from the LED and no binding at all. Just completely dead. Any suggestions?
PonyBoy1973 is offline Find More Posts by PonyBoy1973
Old Nov 11, 2012, 12:31 PM
Couchking is offline
Find More Posts by Couchking
180CFX - Nano CPX - DX6
Couchking's Avatar
United States, CA, Laguna Niguel
Joined Nov 2010
Originally Posted by PonyBoy1973 View Post
Hey all,
Have you checked to see that your battery cable is still connected to the receiver? Those wires are known to fray and even disconnect after a few hard crashed or pulling while removing the battery.
Couchking is offline Find More Posts by Couchking
Old Nov 11, 2012, 01:00 PM
Joined Mar 2011
Yes, I checked that. I confirmed voltage to the back-side of the RX board where the wires from the battery go through the board.
Just dead. no LEd, no nothing...
Old Nov 11, 2012, 01:46 PM
i812 is offline
Find More Posts by i812
Mike for President
i812's Avatar
Joined Aug 2009
Also, if one of the Coil's leads are broken off the PWB, the LED will not light.
i812 is offline Find More Posts by i812
Old Nov 11, 2012, 01:53 PM
Joined Mar 2011
can you elaborate? Coils? Thanks for your help... Hope I can fix it myself or i'm out another $60 for a Rx
Old Nov 11, 2012, 02:11 PM
Couchking's Avatar
Joined Nov 2010
Check this post out, the first picture has a circle on the bottom right corner of the tx, that's where the coil should be.
http://www.rcgroups.com/forums/showthread.php?t=1612171
Old Nov 11, 2012, 04:16 PM
Joined Mar 2011
My coil is still there, has a bit of that White epoxy around it too. the top of that coil thingy does move around slightly, like if i put my fingernail under it.
come to think of it, my canopy has been flipping up and coming off from the bottom, maybe that ripped something loose.
thanks again
Old Nov 11, 2012, 04:19 PM
Couchking's Avatar
Joined Nov 2010
thanks again
The canopy may have taken off one of the 2 connections holding the coil on. As stated above, the most common reason for the problem you're facing is either 1.) Battery wires to the RX worn/out or 2.) Coil falling off.
Old Nov 11, 2012, 04:50 PM
Joined Mar 2011
well, it's bricked now, so I might as well try and solder or fix the coil... blah...
Old Nov 11, 2012, 05:31 PM
i812 is offline
Mike for President
i812's Avatar
Joined Aug 2009
If you're able to wiggle the actual Coil (not the RTV), then one of its leads has probably broken loose from its solder pad.
Sounds like you didn't do a "RX Saver Mod"
Old Nov 11, 2012, 10:46 PM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
here is info about the coil saver mod and others http://www.rcgroups.com/forums/showp...8&postcount=10 I originally stated that the silicone does not work to save the coil. I have always used gorilla glue the "dries white 2x stronger" kind Its super lightweight and super strong. I glue the battery cables where they enter the board too,
mescalinedream is offline Find More Posts by mescalinedream
Old Nov 12, 2012, 11:17 AM
PurpleShark is offline
Find More Posts by PurpleShark
...if you take the time
Israel, Tel Aviv
Joined Jul 2012
I've just ordered the mini! and I have a few questions:
1. Anyone tried these batteries?
http://www.aliexpress.com/item/5x-Ex...540565691.html
2. Where can I find servo arms? I rather have a spare before trying the servo saver mod...
3. Is there a free PC simulator that works with the devo 8s?
If so, how do I connect it?
Thanks for answering, and for all the info already in this thread!
PurpleShark is offline Find More Posts by PurpleShark
Old Nov 12, 2012, 11:19 AM
DantHimself is offline
Find More Posts by DantHimself
Joined Oct 2012
1- i think i have 3 of those, aren't bad.
2- from what i read so far, you dont, either the full servo or nothing.
3- seriously, just, seriously, stay away from free simulators, they are crap.
get phoenix or real flight, costy but your heli is way more expensive.
DantHimself is offline Find More Posts by DantHimself
Old Nov 12, 2012, 11:30 AM
Couchking's Avatar
Joined Nov 2010
I also have 3 of those batteries that I use on my brushless Mini. When they were new I used to get around 4 minutes of sport flying, but now after about 15 cycles each they're starting to lose capacity and I'm getting around 2 minutes before my heli starts losing power and my charger only puts back around 200mah. I always took good care of them so I'm assuming they're just duds
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9888 Jan 15, 2016 02:26 AM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 11:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 12:38 PM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 08:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 06:07 PM
