Old Oct 11, 2012, 11:09 AM
sbstnp is offline
Find More Posts by sbstnp
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
Originally Posted by PeteAir View Post
Does anyone know what size the canopy support rod is going into the servo holder?
I'm ordering some square carbon for the boom I might as well get the canopy rod. I've also heard of gluing a 1 inch 1mm rod to the back of the servo holder instead. Not sure if this is stronger I haven't tried this.
It's 1mm. I'm gluing the whole boom length inside and it becomes very very resilient, but eventually I broke a frame and just CA'd the boom in. Around 40 flights and some 30 light crashes later both are still in one piece.
sbstnp is offline Find More Posts by sbstnp
Old Oct 11, 2012, 12:39 PM
PeteAir is offline
Find More Posts by PeteAir
Joined Dec 2008
Thanks! Seems like the tail boom and servo holder are weak links on this heli. Other than that this little heli is very resilient!
PeteAir is offline Find More Posts by PeteAir
Old Oct 11, 2012, 05:08 PM
sbstnp is offline
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
I would say just the boom, expected though as it splits longitudinally. I only managed to break one servo holder, the canopy pin shoulder thing, but it was a very very bad crash on concrete. I'm at around 300 something flights on this little bird and abusing it to no end.
Old Oct 11, 2012, 06:22 PM
i812 is offline
Find More Posts by i812
i812's Avatar
Joined Aug 2009
The Canopy Support Rod(s) is(are) 1mm diameter
The Canopy Support Rods don't go all the way through the Servo Holder, instead there are two rods that are attached to the sides of the Servo Holder. When the stock Canopy Support Rods break off the Servo Holder, instead of trying to attach two Rods (one to each side of the Servo Holder), it is easier to Hot Glue one long Canopy Support Rod on to the top back surface of the Servo Holder. The CF Rod is stronger and will last much longer than the stock plastic Servo Holder - Canopy Support Rods. After the Canopy Support/Servo Holder mod is performed, pretty much the only repairs that will be required to the Servo Holder will be to re-glue the CF Support Rod after a forceful impact.
Edit: I wrote this post before reading the above replies.
i812 is offline Find More Posts by i812
Old Oct 12, 2012, 09:18 AM
andy6622 is offline
Find More Posts by andy6622
Joined Oct 2012
Walkera Mini CP Helicopter Servo issue? (2 min 51 sec)
MIni CP servo or gyro problem? (1 min 50 sec)
[url]http://www.youtube.com/watch?v=SSX5gLongno[/url
mini cp servo shaiking (0 min 21 sec)
Please someone help me!
Please tell me how to contact walkera
I have already write email for them
But in vain!
andy6622 is offline Find More Posts by andy6622
Old Oct 12, 2012, 12:57 PM
Crash Survivor is offline
Find More Posts by Crash Survivor
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
Contact who you bought it from. Try unplugging one servo at a time & test it. May be one bad servo & if so have who ever you bought it from send you a replacement servo, if not set up an RMA with them.
Crash Survivor is offline Find More Posts by Crash Survivor
i812 is offline
i812's Avatar
Joined Aug 2009
It looks like you've done electrical mods to the RX.
If so, please describe what all electrical mods have you done to it.
BTW, it might be easier and safer to investigate and troubleshoot if you use Throttle Hold to turn off the Motors before using the TX EL, AIL, and Pitch stick movements.
Old Oct 12, 2012, 06:49 PM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
http://www.buychina.com/items/bolt-t...le-qwutsusjqjp check out this esc for the mini! bl heli software ready too!
here is one that shows exactly how to hook it up http://www.buychina.com/items/origin...al-rtpomrsolnk
mescalinedream is offline Find More Posts by mescalinedream
Old Oct 12, 2012, 08:46 PM
waveOmatic is offline
Find More Posts by waveOmatic
waveOmatic's Avatar
Joined Aug 2012
Hi everyone, I finally got all the things I needed, new servo (before that came a member here sent me some spare gears so I could be up and running, that's whats up indoorheli!) new leads for the battery since they got so short, soldered them the back, everything looks great, multimeter check, I put this puppy back together and now the tail wont work. I swapped the connector from the bottom to top just to rule out if the motor or wires went bad, works fine when I apply throttle. I put the tail connector back on the bottom area and it doesn't work. I tried the various configs I have on my Devo 7 to rule out and transmitter issue, but it does that in all configurations. I checked the board good to see if there is some solder or maybe if I screwed up some tiny component, but from my eyes I can't really tell. Where on the board should I look other than the connector that might be the cause of this?
waveOmatic is offline Find More Posts by waveOmatic
Old Oct 12, 2012, 11:05 PM
sbstnp is offline
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
On HK, backordered, with MCPX connectors though:
http://www.hobbyking.com/hobbyking/s..._100_etc_.html
The instructions are pulled from overskyrc's site.
An a buddy code for the Oversky 10A V3, on HK too:
http://www.hobbyking.com/buddy.asp?c...8-03491BCFD028
Old Oct 13, 2012, 12:09 AM
andy6622 is offline
Joined Oct 2012
I think it is the reciever problem !
I replace the new servo on but in vain!
Look :
Mini CP 發瘋了-1 (0 min 22 sec)
Mini CP 發瘋了-2(用其它主板測試) (0 min 36 sec)
but I can not sure that it is the reciever problem!
Old Oct 13, 2012, 09:17 AM
Joined Jul 2008
Itsmillertime, or anyone else who might know. I want to get a esc that is capable to run the blheli on the minicp. I dont know which esc to get though. Should I get the 3amp esc and double up on the fets or whatever or should I get the 7amp? Another thing is if the torque pre-compensation on the blheli software will fix the tail from blowing out? I will be using a re-wind c05 motor and it blows the tail out now. Or should I et the 7mm tail motor or should I get another esc and run a brushless tail?? Also if anyone knows is the walkera brushless tail motor from the double brushless kit is more or less weight and power then the hp03? I have a walkera tail motor and wondering if I should install it once I get the blheli software going.
My rewound c05 with thicker wire is stronger then the asteroid prototype c05. I am wondering if the blheli software running governor mode will let the walkera brushless tail motor shine or not. I dont have the money to be shelling out on a hp03 tail and xtra esc if a 7mm tail will work or if making a longer boom or if with the blheli torque pre-compensation mode turned on. This is the pre-comp mode here
BLHeli mCP X - torque pre-compensation (4 min 45 sec)
Old Oct 13, 2012, 09:20 AM
andy6622 is offline
Joined Oct 2012
IT seems like reciever problem
I have already replaced one new servo on but in vain!
Old Oct 13, 2012, 02:41 PM
Heli Crash Survivor
Joined Feb 2011
My rewound c05 with thicker wire is stronger then the asteroid prototype c05. I am wondering if the blheli software running governor mode will let the walkera brushless tail motor shine or not. I dont have the money to be shelling out on a hp03 tail and xtra esc if a 7mm tail will work or if making a longer boom or if with the blheli torque pre-compensation mode turned on. This is the pre-comp mode here http://www.youtube.com/watch?v=8ASVYtQ0Htw
Wonder if maybe set the TX to Mix to throttle or Program mix like master throttle & slave rudder using a curve to keep the tail from blowing out would work.
Old Oct 13, 2012, 09:46 PM
sbstnp is offline
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
I'm using XP-7A currently with a c05m at 11500kv and have the oversky 10A v3 on the way. I'm not really fond of how I do the flashing on XP-7A with the very small soldering pads, I broke the connector off a few times I already trashed the ground pad so I had to pick another ground to solder to. Annoying. And I no longer have my SMD soldering iron (small Donau 8W 12V) I managed to ruin the tip, totally my fault and now I can't find replacement tips in stock anywhere nearby.
Oversky 10A has a flashing connector built in so that's a plus. I didn't order the flashing stick I plan on using my Arduino, worked fine with the XP-7A, I only hope the connector on the ESC is a micro JST servo type, otherwise I'm screwed.
Stock tail holds just fine with this motor, probably it wouldn't with yours and you would need the 7mm tail motor. I don't think you need to go to a brushless tail unless you plan on swapping out to HP06s or similar.
I'm using a V throttle curve even on stock tail and it works just fine, something like 100-80-100, no tail blow outs but still my c05m is weak compared to yours.
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9888 Jan 15, 2016 01:26 AM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
