United Kingdom
Joined Aug 2008
![]() Changing Fets can be easy enough to do yourself, if you can solder... Did have an idea which could save tail Fets. Live cable from tail motor to rx, cut RED and solder 3amp fuse wire. So when you stall tail fuse will blow before FET !? Any larger may blow fet before fuse. |
Sweden, Helsingborg
Joined Jun 2012
Hong Kong
Joined Jan 2010
Obviously the likelihood of receiver damage depends on how and where you are fly it, as well as your maintenance. I admit that there are things that I shouldn't have done, like flying in the rain. Knowing that the receivers can be repaired cheaply made me more careless.
Right now, I have no working receivers. One is completely unflyable because of strange behaviour and the other had its battery lead pulled out. I am not sure whether it is worthwhile sending them back to Walkera since they were already bad the last time they came back. |
United Kingdom
Joined Aug 2008
Your thinking fuse's you use in cars which would. Ok thats shows 5amp wire only but you can get 3amp but most likely quite hard to find. Still 5 amp for main would be good, would be ok for tail. Without looking at spec's for fets but guess peak amps would be about 6amps for few sec's so 5 amp could work. |
Sweden, Helsingborg
Joined Jun 2012
Anyone know if CB180Q Tail Rotor or HM-4#3Q-Z-03 would fit the minis tail motor?
CB108Q is a tri blade rotor (looks awesome) and HM-4# seems to have a higher pitch then the stock one. no clue on how large they are though. Edit, Nvm found a retailer that sells the mcp X v2 blades locally. On a side note, what parts from a mcp x would fit a mini cp? tail and rotor blades only? Edit 2: What batteries are recommended if you want a larger capacity for a brushless motor? They will be for sport and mild 3d. Im looking for ones in the range of 400-800 mah. |
so
what will walkera release for Blade NCPX competition? we all know something is coming lol |
Latest blog entry: Estes Rubber Band Condor gets powered...
Latest blog entry: Vintage Kyosho Buggies, why I love 'em...
Sweden, Helsingborg
Joined Jun 2012
So, i intend to try out some kdbb bullet blades on my mini cp, and the color options i have from my retailer is orange, yellow or green.
Anyone got suggestions as to what color would be easer to keep track of at distance? im leaning towards yellow or green. This is where i ussualy fly at
| Thread Tools | |
| Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! | DLY | Micro Helis | 9683 | Yesterday 10:34 PM |
| Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel | oomodel.com | Hot Online Deals | 12 | Oct 16, 2011 08:52 PM |
| Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" | Iceblade1A | Micro Helis | 91 | Sep 25, 2011 11:38 AM |
| For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 0 | Aug 16, 2009 07:38 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
