Old Sep 01, 2012, 07:35 AM
dway is offline
Find More Posts by dway
Joined Mar 2007
Mine was doing that. I was getting about 45 seconds to 1 minute hovering and then getting the low battery warning on my Devo 8s. It turned out to be the motor. I decided it was a good time to go brushless, and now my flight times are back to normal.
dway is offline Find More Posts by dway
Old Sep 01, 2012, 07:36 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Would a minicp motor fit a GeniusCP? I just burned out my second motor and i have no idea what i'm doing wrong. I may have done quite a few propeller hits on the first motor (note that it's still a LOT less than when i was on a v911), and that may have contributed to the first burn out. But the second motor barely had any crashes, with the 'crashes' being absorbed by the landing skids.
I've barely done any 3D flight, i'm in normal mode but the motors wearing out just from hover practice? I hear the miniCP motor is more powerful, maybe it's more robust? Would it fit on a GeniusCP?
Hajile is online now Find More Posts by Hajile
Old Sep 01, 2012, 07:43 AM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I found that on most helis the motors heat up more when hovering, than when doing circuits. I think there is more airflow because the heli is moving through the air.
SoloProFan is offline Find More Posts by SoloProFan
Old Sep 01, 2012, 07:56 AM
Joined Jul 2012
May be a factor, but wouldn't the fact that a helicopter literally flying in the middle of a maelstrom mean it's got plenty of airflow as is?
I hope you're right coz i'm going to be on my third motor and i'm moving up to walking around with it. All the same, if there's a better motor i can fit in it, i'd rather install that. The MiniCP is about the same size as the GeniusCP, i'm hoping the MCP motors screwholes line up with the GCP.
Old Sep 01, 2012, 08:07 AM
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Why not just go brushless? more power, less motor heat and longer flight times. Win/Win/Win
Xermalk is offline Find More Posts by Xermalk
Old Sep 01, 2012, 08:29 AM
zzyzx is online now
Find More Posts by zzyzx
United States, CA, Fullerton
Joined Apr 2012
brushless.. You can get a wk10 esc and a c05 for $40 from wow hobbies. Less if you order from hk.
the genius, minicp, and mcpx stock motors are more or less compatible with each other. I think you might have to reverse polarity on the mcpx motor to use it if I remember right.
zzyzx is online now Find More Posts by zzyzx
Old Sep 01, 2012, 08:58 AM
Joined Jul 2012
http://helitrex.multiply.com/photos/...EPARTS#photo=5
Local seller. About 2,500php or 60usd. Not really sure if they actually have it in stock, but worth a try.
Is there an explanation on why a brushless is more durable than a brushed motor? Not really familiar with the difference between the two.
Old Sep 01, 2012, 09:08 AM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
That looks like it might be the official walkera double brushless kit, Stay away from that one. it really dosn't preform that well. as said, grab it from wowhobbies or Terence/Chinese Jade <- awesome site for walkera spare parts
Old Sep 01, 2012, 10:00 AM
Joined Jul 2012
If it performs atleast as good as the original, but be more durable, i'll settle for it. At this rate four main motors will be enough to pay for the brushless set. If i buy a second motor, i'll already be halfway there.
googled terence. Is this it?
www.chinesejade.com
I'll check it out thanks.
However, if i were to get a helicopter that's a bit larger, what would you recommend? Req. Brushless + Tail rotor powered by main motor + about 400mm length + Landing gear separate from main body + Preferrably Walkera BNF Compatible.
Old Sep 01, 2012, 10:05 AM
zadaw is online now
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
www.chinesejade.com
I would recommend the V120D02S without reservation. It is far more powerful and capable than the stock Mini CP out of the box. In fact, I and many others in Hong Kong have switched back to flying the V120D02S because of recurrent problems with the Mini CP receiver. Otherwise I would take a look at the larger Master CP but that has a tail motor. I cannot recommend any other larger Walkera CPs at the moment because a poor track record of quality.
zadaw is online now Find More Posts by zadaw
Old Sep 01, 2012, 11:40 AM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
www.chinesejade.com
http://www.chinesejade.com/walkera.htm is correct yes.
And as Zadaw said, if your looking for something bigger then V120d02s or Master CP (440 mm,Brushed, tail motor, 119 usd without charger/battery ). Id wait a while with the master cp though, it was just released and not many have had the chance to test/review it.
Btw Zadaw, what kind of Reciever problems as my rx seems to be working just fine?
Old Sep 01, 2012, 12:37 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
There is no sliding contact in a brushless motor, so no brushes that wear down, or a collector that can do the same. The only thing that is prone to wear in a brushless motor are the bearings, and these can last a long, long time. Usually the only way to total a brushless motor is by letting it get too hot. During normal use, there is virtually no wear.
Old Sep 01, 2012, 12:42 PM
zadaw is online now
Hong Kong
Joined Jan 2010
There were all sorts of problems but the main problem were blown tail fets. I have 4 receivers for 2 air frames and all have been constantly sent back to Walkera for repair. In fact, I have never had a stretch of a week when I could fly a Mini CP. The current status is that one receiver is not repairable and another is back with Walkera. Off the two that are back, both fly very badly. I wrote a thread in another forum about this.
http://www.helifreak.com/showthread.php?t=423120
These problems are well known to my vendor who had been constantly sending receivers back to Walkera for repair. In fact he and many others have switched to flying the V120D02S almost exclusively because of this. The issue of blown tail fets occur with my Genius CP and mCPX as well so I am not completely sure whether the Mini CP receiver is much more susceptible than other 100 sized CPs.
Old Sep 01, 2012, 01:57 PM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
Interesting, iv been flying my mini now for ~3 weeks and my fets seem to be fine.
Old Sep 01, 2012, 02:07 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Perhaps it's your aura, zadaw?
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
