Old Aug 18, 2012, 11:46 PM
Hajile is offline
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Originally Posted by Skovoroda View Post
BTW, oomodel shipped my mini cp and devo 8s as ....
wait for it
wait for it....
30$ runnig shoes
When you pick up the package at the post office, they open the package in front of you to determine that it's not a prohibited item
The post offices outside Manila seem to not be as strict (Some guys apparently don't get taxed at all!). Since i live in the suburbs, hopefully the test heli will get shipped someplace closer and not get reamed on the taxes. There are a lot of post offices, but i'm not sure if international packages gets distributed to them as well.
Hajile is offline Find More Posts by Hajile
Old Aug 19, 2012, 07:03 AM
Joncreid is offline
Find More Posts by Joncreid
Joncreid's Avatar
Joined Oct 2011
I'm in uk
Ive ordered minicp and genius from wow hobbies in US
I had to pay £40 to get it from post office
So I tried eHirobo in China
Cost me nothing!
Arrived in less than 2 weeks
Joncreid is offline Find More Posts by Joncreid
Old Aug 19, 2012, 09:46 AM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Is there any webpage that sells all the items needed for brushless conversion? Including 7/8/9 Teeth pinions? Preferably with ups or similar shipping. As I'm in need of ordering some spare landing gears i might as well order the brushless parts. My original landing gear is more CA then original plastic and only has 2 of the 4 pins that hold it in place.
Can Terence @ Chinese Jade ship with UPS/DHL? or he only does Hongkong post?
PS. Is the mini supposed to spin out when you do aggressive pitch pumps with the stock motors? Mine seems to love to spin out on the second pump. (100% throttle , 60% max pitch)
Xermalk is online now Find More Posts by Xermalk
Old Aug 19, 2012, 10:05 AM
indoorheli is online now
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
http://www.homefly.com/products.asp?id=36
Your tail rotor might be bent if you can only get 60% with the stock tail motor
Terrence has only shipped all my purchases regular mail
indoorheli is online now Find More Posts by indoorheli
Old Aug 19, 2012, 10:49 AM
Sweden, Helsingborg
Joined Jun 2012
My tail rotor looks just fine when i inspect / comapre it to the spare one i have.
Ill fly a couple of freshly charged batterys later today and see how it fares.
Could have been the wind that made it spin out yesterday.
Old Aug 24, 2012, 01:36 PM
Sweden, Helsingborg
Joined Jun 2012
Hrm, it still spins out after having replaced the entire tail with the spare one i had.
!00% throttle, 60% max pitch.
If i only give it max positive pitch it twists to the left.
If i give it positive after negative it spins out.
Definitely smells of issues with power getting to the motor, or it could be something with the newer minis.
Regardless, this happens both with the stock 240mah battery and the turnigy 300 mah 35c ones.
Im pondering whether to create a 2s 3.7v battery from the 2 stock ones i have. It should atleast result in a smaller current drop at full load. Issue would be charging it. id have to charge it as a regular 3.7v 1s batterys as i only have the stock charger, and no spare battery connectors.
Old Aug 24, 2012, 02:44 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
How about making a new model in memory, and input basic settngs? How's the potmeter on the receiver? No vibration anywhere, that can mess up the gyro?
SoloProFan is online now Find More Posts by SoloProFan
Old Aug 24, 2012, 03:13 PM
Sweden, Helsingborg
Joined Jun 2012
Tx gyro value 78% , Gyro Pot at stock /6 o'clock position, almost no vibration when i hold it in the hand. Doubt those would cause it to spin 1.5+ turns when going from high negative to high positive pitch (when the motor slows down the most).
If i get the opportunity to fly it tomorrow ill try to get some video of how it spins out.
Some voltage sensor info with 0 0 0 pitch curve.
Multimeter
Fresh battery 4,21V
Mini Sensor
0% throttle 4.1 V
Spinning up to 100% -> quick drop to 3.5
Idling at 100% throttle 3.8V
Same values with 3 different tested Turnigy 35c 300mah.
To actually have 3.75-3.8V left in a battery after a flight i have to put the voltage alarm to 3.4v on my devo 7E
As for going brushless on a mini, i presume http://www.wowhobbies.com/turboace41...43g-3-1-1.aspx is all i need? Should i grab some higer capacity batterys from wowhobbys or HK like 600mah ones? I was going to buy from Terence but he dosnt have any 8t pinions and their out of stock on http://www.homefly.com/products.asp?id=36
Old Aug 24, 2012, 06:24 PM
rldeveer is offline
Find More Posts by rldeveer
rldeveer's Avatar
Big Island of Hawaii
Joined Jan 2011
Better fix for canopy support repair!
After breaking a canopy holder off the servo holder, I tried hot glueing repairs and didn't like the results.
I removed the servo holder retaining screw and used a #59 bit in a pin drill and reemed the canopy support hole from one side to the other while installed. This notched the alignment pin on the way through. I put in a full length canopy support rod from a Genius canopy and it locks the servo holder in place. Some #22ga silicone insultion on the rod set so no linkage/motor interfearance with the canopy.
Works so good I will do it to new servo holders upon installation.
Regards,
RD
rldeveer is offline Find More Posts by rldeveer
Old Aug 24, 2012, 06:40 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
Well guys, to satisfy my insatiable thirst for power I bought a mini protos kit that I plan to stretch with 350mm blades and a 6s conversion. So I would really like to sell my cracked out mini to fund electronics for the new beast. Here's an example of what I'm going for:
Tareq Alsaadi - Mini Protos with MSH FBL System - Alpine Heli Smackdown 2011 (4 min 29 sec)
itsmillertime is offline Find More Posts by itsmillertime
Old Aug 24, 2012, 07:29 PM
rldeveer is offline
rldeveer's Avatar
Joined Jan 2011
Miller
Thought U sold it on EB
Old Aug 24, 2012, 07:42 PM
Joined Dec 2011
Bidding only reached $100 and then the winning bidder messaged me saying he couldn't get it. I was kind of relieved as I wasn't going to sell it that cheap anyways.
Old Aug 24, 2012, 09:21 PM
OrbitalGolem is offline
Find More Posts by OrbitalGolem
Joined Jan 2012
Sorry if this question has been answered elsewhere in the thread - I did try a search first.
Does anyone know if WOW's C05 brushless motor kit works with the Mini CP main gear? I have a tech support question into them, but I think they're misunderstanding my question.
http://www.wowhobbies.com/turboace41...r-43g-3-1.aspx
When I tried installing the motor and setting the mesh properly, the motor case rubs against one of the servos, almost as if the Mini CP main gear is too small. Am I just missing something?
OrbitalGolem is offline Find More Posts by OrbitalGolem
Old Aug 24, 2012, 10:30 PM
rldeveer is offline
rldeveer's Avatar
Joined Jan 2011
I have about 0.5mm clearance and no frame mod. Using an 8T from CME Hobbies on a C05M with 1.5mm shaft. Also drilled out a GCP 9T with a 1/16" and a perfect slip fit that also worked with the MCP main.
RD
Old Aug 24, 2012, 11:15 PM
Hajile is offline
Joined Jul 2012
How has your mini CPs been holding up? So far, after a few days, the Genius CP motor stopped working and it was a week before i could get it replaced. And then after just one crash, one of the bearings went missing so it's down atleast a month because the local hobby shop didn't have the part and i have to order from china
For the price of the motor and bearing, i'd be able to buy a v911 BNF Makes me wonder how the mini CP differs in construction and if it would have been worth the month it takes to order the miniCP from china.
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
