Old Jul 20, 2012, 11:17 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Originally Posted by mescalinedream View Post
Its been awhile since I have been on here, mainly due to my mincp's board glitching. I was wondering if Walkera was still repairing minicp boards? My board has a faulty trace in which the heli will only work if i push on the board. I remember walkera was replacing/repairing boards for a fee but that was in feb. Please, if anyone has any information then please post. I would love to fly my mini again!
I have had two boards repaired back from Walkera so far. One for a broken socket on the board and the other for a blown fet. The turnarond time was 6-8 weeks and the repair was free. Although you had to pay a shipping and handling cost which was around $3.2 in my case. However, it seems that Walkera would like you to do this through your vendor and not all vendors are willing to do this.
Right now, I am very frustrated with the Mini CP. I had 36 flights with the last repaired board and I have now got the same problem as you do. The board will not work unless I push on it. It seems that something is loose but I just cannot find out what it is. The problem here is that Walkera may not repair a board like this if the job is too complicated.
I have got 4 boards and 2 air frames. It seems that I can only get a single heli in the air for a few days at a time. In the same period of time that i have had the Mini CP, I have had 50% more flights with the V120D02S which has proven to be more reliable. In fact, a lot of modelers in Hong Kong have switched to the V120D02S because of high likelihood of damage to the Mini CP board.
zadaw is offline Find More Posts by zadaw
Old Jul 20, 2012, 03:47 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Does this damage occur during normal flight, or as a result of crashes?
SoloProFan is online now Find More Posts by SoloProFan
Old Jul 20, 2012, 04:50 PM
dreamz123 is offline
Find More Posts by dreamz123
United Kingdom, England, London
Joined Jun 2012
Can anyone answer this?
If the throttle adjust is put to say 150% on travel adjust on h and l with devo 7 does it increase head speed?
Also ive set my gyro to manual and with mix switch at pos 2 all gyros are off, even cyclic as I set gyro to 40%. Has anyone tried to fly it like that? Is it hard?
Sent from my mini cp using tapatalk 2
dreamz123 is offline Find More Posts by dreamz123
Old Jul 20, 2012, 07:23 PM
thloh85 is offline
Find More Posts by thloh85
Malaysia, Penang, Bayan Lepas
Joined Apr 2010
Odd enough, I'm the opposite. My v120d02s gave me a whole lot more problems than the MiniCP. My MiniCP has been great, but I've been cautious with it (crashing excluded ). All new MiniCP comes with the coil epoxied, and so far I'm a lot happier with it than the v120.
Also, the FBL system in the MiniCP is a lot better than the v120 imho. It feels like it is flying on rails, the v120 feels all over the place in comparison.
thloh85 is offline Find More Posts by thloh85
Old Jul 20, 2012, 07:40 PM
zadaw is offline
Hong Kong
Joined Jan 2010
Sure I did have crashes during those 36 flights. They were mainly due to the fact that my batteries have lost their power after being left fully charged during repairs. However, they must have been mild as the canopy, boom, and head was unscathed. The only thing I can think of was the vibration from the large number of inverted blade scrapes the heli had because the heli did not have much power.
When there is little or no wind, the Mini CP is more precise than the V120D02S. But I almost always get some wind here and the V120D02S handles wind much better. As far as FFF goes, I find the Genius even better than the Mini CP as I could go hands off in FFF all the time a few feet from the ground. In any case, the V120D02S is greatly superior to the Mini CP for learning 3D, that is if you set aside the question of durability.
Old Jul 21, 2012, 08:41 AM
Udonsushi is offline
Find More Posts by Udonsushi
Joined Feb 2012
Hey guys can anybody explain me, how do 3D works? I mean how can a heli fly turned over? Does the motor start to spin to the other side? Could be dumb for you guys, but i am new in this, still trying to flight it perfectly in a normal fly
Udonsushi is offline Find More Posts by Udonsushi
Old Jul 21, 2012, 10:22 AM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
You use a full range of positive and negative pitch. Basically a new flight more with new curves with high throttle a full collective range. So anything below midstick would give negative making the heli pull fast to the ground if right side up or if upside down make it gain altitude. Then anything above midstick would be positive pitch so flying upright would fly normal or close to normal depending on your settings.
indoorheli is offline Find More Posts by indoorheli
Old Jul 21, 2012, 06:18 PM
Joined Feb 2012
Ohhh i see and to put the heli invert, what do i have to do? After 3d settings on the tx, i have to pull all the way back the tail of the heli and after that trottle stick all up and then all down?
Old Jul 21, 2012, 06:49 PM
MarcusMX233 is offline
Find More Posts by MarcusMX233
MarcusMX233's Avatar
United States, TN, Johnson City
Joined Oct 2011
Thats sort of how. I would definitly try on a simulator before real life.The mini can take a beating but its better to know what to do and expect first.
MarcusMX233 is offline Find More Posts by MarcusMX233
Old Jul 21, 2012, 06:58 PM
indoorheli's Avatar
Joined Sep 2007
Yeah that it...........kinda. But you really want nice collective management and you really dont want to slam the sticks or use more pos/neg pitch than you need. If you slam the sticks it will be quite the erratic movements and you will crash hard.
I would go with what was suggested and try it on a sim first. If you dont you might as well put your heli on the ground and step on it
Old Jul 22, 2012, 11:17 AM
buychina is offline
Find More Posts by buychina
Joined Jul 2012
Originally Posted by Couchking View Post
I really wish Taobao was in english (google translate doesn't do it for me) or had an english site. It seems like they have great products at good prices.
you can just use buychina.com ,browse and buy in English ,Pay by Paypal, Shipping worldwide . Such as http://www.buychina.com/products/15028220733
http://www.buychina.com/products/16410624574
buychina is offline Find More Posts by buychina
Old Jul 22, 2012, 11:27 AM
indoorheli's Avatar
Joined Sep 2007
Hey if your going to spam your website links at least become a paying member of rcgroups...
Old Jul 22, 2012, 01:09 PM
cururu1 is offline
Find More Posts by cururu1
Joined Jul 2012
Originally Posted by bobepine View Post
http://youtu.be/OnG0RfhRwv8
http://youtu.be/yK6SHvUxGXQ
Cost me not one, not two, THREE servos.
Chris
Hi Chris!
I am impressed with your videos! Your mini CP is flying very well, absolutely stable. On full pitch pumps my Mini CP has tail blow-outs that sometimes I loose control of the heli and it crashes.
I though it was a problem with the brushless motor and the brushed tail motor... as the brushless is stronger the tail motor could not handle the yaw.
I am using a 8T pinion, Genius CP main gear and Devo 7 TX
But your mini cp is also brushless and the tail motor handles it. Now I think it is something with my TX settings...
Could please tell your TX settings for MiniCP?
Best Regards
cururu1 is offline Find More Posts by cururu1
Old Jul 22, 2012, 01:56 PM
itsmillertime is online now
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
Some had better tails than others it seems. Mescaline couldn't get his to blow out whereas mine was horrible. I went to a 7mm tail motor and it held great. Until I got a hp05s and then it wouldn't hold again. So I put on a hp03t brushless tail motor and now with a hp06v2 or even 2s hp08 I can not make the tail budge. Even from 100' high full negative descent to full positive climb stick banging. There's also a lighter 6 magnet version that would work great if you don't plan on going crazy with power.
itsmillertime is online now Find More Posts by itsmillertime
Old Jul 23, 2012, 07:45 PM
zadaw is offline
Hong Kong
Joined Jan 2010
Repair Service for Mini CP and Genius CP receivers in the US
This US based member at HF is offering a repair service for the MIni CP and Genius CP receivers. This is definitely something that is really needed. It could take weeks or months before you get anything back from Walkera.
Member name = zzyzx
http://www.helifreak.com/member.php?u=159961
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
