Joined Feb 2012
SoloProFan,
I am in the same place as you right now. Coming from a 4-ch heli, I am already pretty comfortable with hovering but missing something with turning. I already figured that whenever I use the right rudder, for example, I need to compensate using the cyclics and use right aileron and down aviron. I still can not find the right balance for a good nice circle. Regarding the balancer, I am between the IMAX B6 and Turnigy Accucel-6. What I love about the B6 is that it has a built in power supply while the A6 don't. Is the B6 good enough for my needs? I currently have 6 350mAH pack of 25C and 6 150mAH packs for V911. |
![]() The things I have to figure out most with flying this FBL CP is the fact this thing can pick up speed fast. I'll try going outside, over grass, to get more chance to go beyond hovering. |
Latest blog entry: Vintage Kyosho Buggies, why I love 'em...
Hong Kong
Joined Jan 2010
I have been using the B6 for all my helis from the Mini CP to the 450 for some time. I am aware there had been user complaints about the B6 so perhaps you should do more research. The Mini CP is so stable in hover that it is not representative of a typical. Walkera has done some tricks with the gyro to make it so stable. I sometimes wonder whether in fact it has got a 6 axis gyro built in like the New V120D02S.
I got one of my receivers back from Walkera today. This was one of the 4 receivers under repair for blown tail fets. I only flew 3 packs today, two with the white Solo Pro 100D blades. The Solo Pro 100D blades are considerably wider than the Mini CP blades. I found them to make the heli more powerful and stable. However, battery life was shortened even further. Still I recommend the white Solo 100D blades for beginners because they will reduce crashes due to disorientation. |
Problem with the B6 is that there are also clones out there, which may not have the same build quality. You can check if it's genuine on the site of the manufacturer, there's a code on the back of the charger. I have 2 and so far these work flawlessy.
I wonder if there is any benefit in using FP blades. Basically, when it's in normal flight mode, with very limited neg pitch, it behaves a little like an FP anyway. Especially when you would program it with locked pitch so you basically only control altitude with motor RPM.
Russian Federation, Primorsky Krai, Vladivostok
Joined Jun 2012
Not having owned any CP helis yet, anything I say can be taken with a grain of salt.
![]() What I've read seems to indicate that yes, setting a flat pitch curve will allow you to control alt with motor power similarly to an FP. However, my understanding is that CP heli rotors have a symmetrical airfoil design whereas FP heli rotors are asymmetrical (similar to fixed-winged aircraft). I would think this would result in more efficient lift characteristics if flying it as an FP. Of course, I could be wrong about this.
Hong Kong
Joined Jan 2010
It is possible to program the Mini CP to fly like a FP or to tame it down for beginners. There is really no point in changing the blades. |
True, and Imax isn't the manufacturer, it's SkyRC in fact. Indeed some clones might just be rebranded stuff. But some people took various ones apart, and in this case both were labeled the same, so the clone wanted to look just like the original, although the color and sharpness of the printed lettering on the case was not identical on close inspection. Then it was found the clone had different components, and often also less neat soldering. A real Imax/SkyRC has a hologram printed on the back and when scratched with a fingernail or so, reveals a code, that can be verified on the SkyRC website. I don't know how "waterproof" this system is, but it does make copying harder, and cheap copies don't have that code, although they look identical to the B6 in everything else. Btw, took the MiniCP outside for the first time on a small field. It was a bit windy, but I tried to find a find a place which was a little sheltered. Take off and hover was easy, and even though there was a little unsteady breeze, the heli was very stable, and felt under total control. So I tried some rudder turns. Not so easy, as the heli picks up speed from a turn somehow, but I know had the room to catch it with correcting stick movements, before it would run into something. And running it can, it's fast, but good thing, it also has some good brakes to go with it. At one point it came soaring at me, so I didn't have time to think off the proper correcting stick movements, stepped aside, and the heli was already metres away and still moving fast. But full backward, and a little correction afterwards, and it was back in hover. Elevator response is great, and knowing you can stop the heli dead in it's tracks within a second gives a new to CP pilot a feeling of safety. |
Under cambered blades have higher efficiency and need lower motor RPM to achieve sufficient lift. This means longer flight times. I think giving the Super FP the same blades as the MiniCP is simply to keep inventory down. My 2 cents.
Joined Jun 2012
So it seems I can do with or without FP blades, but having them should give me longer flight times. Hmm... I guess I'm back to my original question then . Anyone know which FP blades will fit the MCP? Now that makes sense. |
I have ran FP blades on MANY cp's in the past. My first run in i believe was the 4g6 with 4#6 blades. I swapped the symetrical blades out for the FP 4#6 zeroed my pitch curve and lowered my throttle curve to around 40%. I then came to the conclusion I wasted my money on the 4#6's I had and sold them. The 4g6 with 4#6 blades and an adjusted pitch and throttle curve flew pretty much identical to a 4#6. I was able to fly at very low head speed which was my goal for close proximity indoor flying. Keep in mind though you can stress/burn up the system with FP blades running more than a 0 pitch curve and/or higher than needed throttle curve.
So IMHO I would say yes FP blades are beneficial if: 1) you want to save money and buy one heli for now 2) You need lower head speed for indoor flying and/or less crash damage Now like all standard FP helis they have many bad qualities like less stability and trying to come down or fly in wind. The fact the Super FP IMO has mini cp blades has nothing to do with inventory and more to do with the better characteristics you can get with symmetrical blades as an FP......the main one being higher stability due to increases headspeed. The symetrical blades will also make the heli move in all directions faster and more level than standard FP blades could. |
| Thread Tools | |
| Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! | DLY | Micro Helis | 9703 | Jun 15, 2013 05:38 PM |
| Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel | oomodel.com | Hot Online Deals | 12 | Oct 16, 2011 08:52 PM |
| Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" | Iceblade1A | Micro Helis | 91 | Sep 25, 2011 11:38 AM |
| For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 0 | Aug 16, 2009 07:38 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
