Old Jul 10, 2012, 08:51 PM
LevTor is offline
Find More Posts by LevTor
United States, NJ
Joined Jan 2011
I am using the same ST1 throttle and pitch setting as when I was using my genius motor.
Throttle 100 85 100
Pitch -60 0 +60
I am thinking that it should have more kick with the C05.
LevTor is offline Find More Posts by LevTor
Old Jul 11, 2012, 06:42 PM
gdwiz is offline
Find More Posts by gdwiz
United States, NC, Hendersonville
Joined Jun 2010
Throttle 100 85 100
Pitch -60 0 +60
I dont think the C05 is supposed to be that much more powerful than the stock motor. What pinion are you using with the C05 vs. the genius motor
gdwiz is offline Find More Posts by gdwiz
Old Jul 11, 2012, 06:59 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
The c05 isnt the same type of upgrade to the stock motor in the mini like it is if you use a c05 in the mcpx. If you want more kick go hp05s. I love that motor in mine and it will go into the ceiling quick if i am not careful..
indoorheli is offline Find More Posts by indoorheli
Old Jul 11, 2012, 08:18 PM
Skovoroda is offline
Find More Posts by Skovoroda
Joined May 2012
What batteries and tail do you use with hp05s?
Skovoroda is offline Find More Posts by Skovoroda
Old Jul 11, 2012, 09:21 PM
indoorheli's Avatar
Joined Sep 2007
I use an 8 tooth pinion, the stock tail with Hyperion and turnigy batteries.
Old Jul 11, 2012, 10:13 PM
bigflier is offline
Find More Posts by bigflier
Joined Mar 2012
See what I found:
bigflier is offline Find More Posts by bigflier
Reply With Quote  (Disabled)
Old Jul 12, 2012, 12:19 AM
Joined May 2012
How are the flight times on tyrnigys ( I assume you have 300)? I'm on the fence for hp05s brushless, but if I would get 4 min figure 8 flying I'm in.
Old Jul 12, 2012, 12:56 PM
indoorheli's Avatar
Joined Sep 2007
Well I always get about 2 minutes...somtimes 3 minutes But always atleast a solid 2 minutes of 3d type flying. I guess you probably could get 4 minutes out of them if you flew mellow. THough really if you are doing more sport type flying i think the stock or c05 would be better
Old Jul 12, 2012, 02:11 PM
Joined May 2012
Thanks, i been kinda confused by itmillertime timings. He was getting 5:30 out of 300mah. I guess i will just wait till my stock dies then before doing BL. It is so tempting though. Was thinking jumping straight to hp05s and not to start my own little collection of motors. Maybe i can do 7t hp05s to start, it should be about 5000-5500 head speed and less stress on the motor which should theoretically translate to longer flight times. Hmmmm....
Old Jul 12, 2012, 02:28 PM
indoorheli's Avatar
Joined Sep 2007
Yeah flights times are quite vairable per person and how the mellow/crazy they fly and i was just guessing on 4min..you might be able to get more. I just cant fly this heli without constantly flipping it back and forth and is the reason i am always sub 3 minutes. If you fly idle up but only do figure 8's your battery will last a quite a bit longer than if you fly idle up and do lots of flips...then of course if you fly in non idle up and pinion choices can make the flight time even greater.
Hp05s and a 7 tooth wouldnt be too bad
Old Jul 12, 2012, 02:39 PM
Joined May 2012
Thanks indoorheli. I just got out of hover without crashing stage and can do something figure 8ish looking and stall turns. Great vids of Red devil btw. I watch it at least once a week if not more
Old Jul 13, 2012, 04:58 AM
Marioinc is offline
Find More Posts by Marioinc
Joined Feb 2012
hey guys I just got the xp-7a from astroid designs
(for pics)
http://astroid-designs.myshopify.com...xp-7a-1-2s-esc
The White-Red-Black wire, the B\R need to go where the battery would plug to the rx, and the White is signal.
But I checked with the multimeter and the B and R wires on the three wire plug don't short to the B and R wires to the battery on the esc, unlike on a walkera esc.
I'm guessing the wiring is different than a walkera? How should I wire it up?
Marioinc is offline Find More Posts by Marioinc
Old Jul 13, 2012, 02:42 PM
indoorheli's Avatar
Joined Sep 2007
You need a converter for that esc signal to work. I think the easiest route is to use the walkera tail esc with built in brushed to brushless converter
Old Jul 14, 2012, 11:24 AM
Newbmeister is offline
Find More Posts by Newbmeister
Russian Federation, Primorsky Krai, Vladivostok
Joined Jun 2012
In case anyone's interested, prices are dropping. I noticed rc711's BNF price dropped by $10 to $129.90 and Ehirobo is now selling BNF version for $109.99.
http://www.rc711.com/shop/24g-walker...12-p-5869.html
http://www.ehirobo.com/shop/product_...ducts_id=11487
Newbmeister is offline Find More Posts by Newbmeister
Old Jul 14, 2012, 12:24 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
So far my MiniCP has survived a few crashes unscathed, even though, in my CP-noobness, I have to unlearn putting the throttle stick fully down in case of an inpending crash, and use "throttle cut" instead...
After the last crash, I remembered the wise advice to tape the canopy to the skids, as it has shifted up and the corner with the fragile coil was revealed. Skids simply popped out, wise move to make these seperate parts instead of part of the frame, like on the Genius...
I can now hover it in a square about the size of an old record, even getting some seconds of handsfree hover, and then do a soft landing on the same record, as I keep it on the ground as "heli-pad". But as soon as I try to do a simple circle/circuit, things just don't "click" yet in my brain. I think it's the same psychological barrier of flying in a too small space to feel safe. I had this with my first Solo Pro 260 as well, inside I could take off, land, make a box pattern, but as soon as rudder turns were involved, it always went wrong. Then I went outside, and it just fell into place.
Something else, what is the best charge rate for the batteries, using an after marktet charger like the Imax B6? I have more faith in that charger than in the stock Walkera charger. So far I've been using a charge current of 0.4 A which is about 1.75C or so, which is not uncommon for lipos. I wonder what rate you are using, when using a different charger than stock Walkera.
SoloProFan is online now Find More Posts by SoloProFan
Latest blog entry: Pictures of various boats
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9888 Jan 15, 2016 02:26 AM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 11:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 12:38 PM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 08:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 06:07 PM
