Joined May 2012
Joined May 2012
after a crash today, my mini cp just spins like crazy upon take off. i put a new tail on it and the same thing happens. any ideas. and the plug on the top right of the receiver, the plug that plugs in to the motor, that was out a little bit so i pushed it back on.
also I'm getting a second mini cp. this one brushless. i want to get another bird. a bigger on. one capable of doing 3d. i need something bigger that i can just cruise in. the mini cp is too small to see far away when i get disoriented. so i want something bigger, that can do 3d when the time is right, and can survive a crash. o, and use a devo 7 Tx. i was going to get the mx400 but i keep asking myself, y? any suggestions |
Joined Jan 2012
I'm finally in love with my Mini CP...
Joined Sep 2011
hobbyone
Does anyone have experience in buying from http://www.hobbyone.com.hk, that you can share?
Thanks, Sven |
United States, TN, Memphis
Joined Dec 2011
Buy from Bob at www.helircstore.com. Awesome customer service, low prices and fast shipping.
Joined May 2012
Joined Feb 2012
Regarding the Tx saver mod, should the plastic extend all the way to the apex of the canopy or should I cut it shorter? Currently it go all the way to the apex and maybe that is why it feels almost impossible to remove the canopy and break the rods. When I think about it further, I think that the canopy moving on crush is a good thing since it take out some of the crash energy. So, the mod is just to make sure the canopy doesn't bump the receiver on it way off. Did I understand it correctly? |
Joined Feb 2012
Thanks guys for the answers. I just took it outside for 3 packs and got 2 soft crashes. The mod seems to work perfectly. The canopy was just a little bit up, nothing like before the mod. A small snap and it is back again.
i812, I will use your kind advice and wait for the holder to break and then replace it with CF rod. Much appreciated. |
Joined Jan 2012
I have a fairly silly question, especially when considering the context of "preventive maintenance" for a bird as cheap as a Mini CP.
![]() How does one know if the feathering shaft needs to be replaced? I've had several rotor down impacts in grass with no apparent ill effects on the servos, head, blade grips, or main shaft. However, what is the easiest means of testing that the feathering shaft hasn't been knocked out of round? Is it as simple as moving the aileron/elevator very slowly and looking for any "weirdness" in how the blades change pitch? She does have this nasty tendency to pitch up in a level position if I come off forward elevator hard in FFF, though that may be due to using "LINE" for aileron/elevator. The tendency was reduced when I enabled EXP on the pitch. But maybe this is a sign of a feathering shaft needing to be replaced? |
| Thread Tools | |
| Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! | DLY | Micro Helis | 9680 | Yesterday 07:58 PM |
| Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel | oomodel.com | Hot Online Deals | 12 | Oct 16, 2011 08:52 PM |
| Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" | Iceblade1A | Micro Helis | 91 | Sep 25, 2011 11:38 AM |
| For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 0 | Aug 16, 2009 07:38 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
