http://www.wd40.com/faqs/ Funny how people will believe what they read on RCG more than what the manufacturer says or people who have used it for years report.. ![]() ![]() Most metal finger motors die because of motor stoppage with power applied burning the fingers than from wearing them out. And a little lube helps them last even longer. |
I use WD40 all the time...and while it has lubricating properties I dont consider it a lubricant really. It cleans great, repels water and rust and gets off all sorts of stuff...but it dries out lots of material and will do the opposite of lubricate.
It will do an okay job of lubricating metal on metal but just okay imo. I just stay away from it for that purpose and use products that do a much better job for it. |
Joined Apr 2009
I've used WD40 on my drill press as a cutting oil to drill large holes in steel to keep the drill cool and help it cut better. WD40 has many uses but not the best for lubricating. YMMV, Don |
Does anybody know if a new Collar is pre-threaded, or is the Collar Screw suppose to be self tapping?
I have a new spare Main Shaft with Collar and Screw, and am having difficulty installing them because the Collar Screw doesn't thread into the Collar. At first, assuming the Collar came pre-threaded, and without verifying, I tried very carefully to gently thread the Collar Screw into the Collar. I was unsuccesful, so then guessed that the new Collar didn't come with existing threads, and instead am suppose to use force to self-tap the Collar Screw into the Collar. After many attempts, using more force on each additional attempt, I was eventually able to forcefully self thread the Collar Screw most of the way into the Collar; however, I haven't been able to finish the last few remaining threads. I'm imagining with all the unsuccessful Screw turning I've done, what ever threads I did start are probably stripped by now! ![]() Any better ideas on what I should have done, and what I should do now? How to finish threading the Collar Screw into the Collar? And in the event that Collar's threads are stripped, any suggestions on how to "re-new" the plastic threads? The reason I wanted to replace the original Collar was because it is cracked at the "boss" (Collar's extended part that "houses" the Collar's threads), allowing the boss' diameter to widen and the threads to split open and preventing the tightening of Collar Screw. If the replacement Collar thread is stripped, and if it can be repaired, then maybe the same repair can be used on the original Collar with the cracked boss with split open thread? |
Joined Apr 2009
I was not angry. I have no reason to be angry and I appologize if it sounded that I am angry. All I had was good intentions to share my experience with the brushed motors. |
Joined Apr 2009
Joined Apr 2009
Joined Oct 2011
I just replaced the main shaft on mine. My old collar was stripped out. It took a bit of effort to get the screw started into the new collar, more than seemed nessesary. It worked fine for me, but I can see why yoou are having trouble. |
After many repeated attempts, I finally was able to use enough force and turn the Collar Screw all the way through the wall of the Collar. The Collar Screw backed out and re-inserted itself along the threads in both directions, so I thought the threads might be OK; however, when I assembled the Collar on to the Main Shaft and tried tightening the Collar Screw, as soon as the Collar Screw reached the Main Shaft, I wasn't able to get it to apply any significant back pressure "torque" to the threads, and instead the Collar Screw just easily spun non-stop.
I suppose I need to order a few more Main Shafts, so I can have a supply of Collars. ![]() Hopefully now that I'm aware about the possibility of a thread stripping problem that can occur while using the Screw to tap new threads into a new the Collar, I'll pay more attention, and somehow be more careful the next times. Maybe it might be easier, faster, better, and cheaper to locate, purchase, and use a proper sized tap? I'm not done with those old damaged Collars though. I'm thinking of doing some DIY plastic thread rebuilding experiments with them:
I just tried using CA on the cracked Collar. I didn't apply the CA on the inside of the threads in attempt to rebuild them, but instead applied the CA on the outside trying to keep the crack from opening as the screw is tightened. I'll allow the CA to cure 24 hours before verifying if it can hold up to Screw torque. |
United States, TX, Dallas
Joined Nov 2011
Why don't you just get a metal collar & be done with the problem. Since I got 1 from RakonHeli I haven't had any problems & they're cheap. Heres a link
http://www.rakonheli.com/rkh/index.p...emart&Itemid=1 The quality is great & shipping is fast. Hope this helps. |
| Thread Tools | |
| Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! | DLY | Micro Helis | 9681 | May 20, 2013 10:42 PM |
| Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel | oomodel.com | Hot Online Deals | 12 | Oct 16, 2011 08:52 PM |
| Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" | Iceblade1A | Micro Helis | 91 | Sep 25, 2011 11:38 AM |
| For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 0 | Aug 16, 2009 07:38 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
