United States, MA, Springfield
Joined Dec 2010
this rings a bell:
Joined Jul 2008
http://item.taobao.com/item.htm?scm=...&cm_id=&pm_id=
New larger maingear for the mini, More info here about it, not very interesting though! http://translate.google.com/translat...587880&act=url New 12000 motor for the mini http://translate.google.com/translat...196358&act=url New tail for the mini http://item.taobao.com/item.htm?scm=...&cm_id=&pm_id= Different servos that can be used in place of the originals http://translate.googleusercontent.c...7jopOazHlLxChA |
I really wish Taobao was in english (google translate doesn't do it for me) or had an english site. It seems like they have great products at good prices. |
Joined Mar 2012
Hey Guys,
So I am having an issue, when I throttle up, the heli will yaw to the left, also sometimes it abruptly just yaws on its own, sometimes up to 90 degrees. Other times, it wont yaw properly at all, really slowly yaws and it seems to fight my stick inputs. I have changed the entire tail kit hoping this would solve the problem but it still happens. I had also changed a servo recently, not sure if that had something to do with the issue. Could it be something wrong with my transmitter, using a DEVO 7. Please help! Thanks |
Feathering Shaft
I've read one way to inspect for a bent Feathering Shaft while it is installed on the heli is to remove one Main Blade, fold the other remaining Main Blade back so it is 90* away from its normal straight-out position, then verify the Main Blade does not flutter up and down as the Feathering Shaft is rotated using the Allen Key. If the Main Blade flutters while the Feathering Shaft is rotated, than it is an indication that the Feathering Shaft is bent. Also, the Feathering Shaft can be checked for straightness after it is removed from the heli by verifying no air gap anywhere under its entire length as it is rolled on a flat surface. I suppose if I see Main Blade tracking error, then among other things, a bent Feathering Shaft could cause it. So, if there is no Main Blade tracking error, then it is probably safe to assume the Feathering Shaft is straight enough, and doesn't need inspected? |
| Thread Tools | |
| Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! | DLY | Micro Helis | 9683 | May 24, 2013 10:34 PM |
| Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel | oomodel.com | Hot Online Deals | 12 | Oct 16, 2011 08:52 PM |
| Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" | Iceblade1A | Micro Helis | 91 | Sep 25, 2011 11:38 AM |
| For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 0 | Aug 16, 2009 07:38 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
