Old Apr 05, 2012, 05:51 PM
Benf207 is offline
Find More Posts by Benf207
Fairfield County, Connecticut
Joined Dec 2009
The internal 5V is the transmitter if I'm not mistaken and the external is the helicopter.
Ben
Benf207 is offline Find More Posts by Benf207
Old Apr 05, 2012, 05:52 PM
MX48 is online now
Find More Posts by MX48
United States, GA
Joined Dec 2011
I haven't modified the servo arms, is it really required?
At least do the Elevator servo as this is the one that will strip teeth from sport flying crashes. The other 2 will go when you start crashing doing 3D. Of course if you don't crash...
Moto
MX48 is online now Find More Posts by MX48
Old Apr 05, 2012, 06:27 PM
nac is offline
nac
Find More Posts by nac
nac
nac's Avatar
Melbourne, Australia
OK thanks. I might take a look at the servos this WE, so just cutting a slot in the arm is OK?
Yep the 5v is the transmitter. i thought you could have both alarms set so that if the radio or the heli voltages get too low it will beep.
nac is offline Find More Posts by nac
Old Apr 05, 2012, 06:44 PM
Benf207 is offline
Joined Dec 2009
Check out Bytemunchers blog - http://www.rcgroups.com/forums/member.php?u=296568 He has compiled some information of mods that should be done. Make sure to use a fresh blade because otherwise the arms will slip much too easily. I would suggest using the o-ring, although even with it, if the slot is too big they will still slip easily.
Ben
Old Apr 05, 2012, 07:00 PM
nac is offline
nac
nac
nac's Avatar
thanks
Old Apr 05, 2012, 09:18 PM
djjd42 is offline
Find More Posts by djjd42
Joined Jan 2012
Here's a another vote of confidence for the Heli RC store: I placed my order around 2 AM their time, they shipped it by 10 AM their time, and included the following very much needed, very much appreciated, bonus in the box:
djjd42 is offline Find More Posts by djjd42
Old Apr 05, 2012, 09:26 PM
Benf207 is offline
Joined Dec 2009
I did my brushless conversion today and while sometimes the c05 works flawlessy, currently when I raise the throttle stick it just sits and sputters making slight beeping noises. Is there a way to fix it?
Ben
Old Apr 05, 2012, 10:05 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
Lower the gyro rate if you want to speed up the tail. Mine piros like a msr now. I was trying to get rid of my slight tail wag. Tx gyro gain anywhere from 40 - 100% and rx gain 45 degrees in both directions wouldn't cure it. I found that with a high enough gain I can eliminate the ccw yaw drift but at a price... a slow rudder. I prefer to just deal with the yaw drift and have a fast rudder. I even swapped in a stock tail boom and it still has the slight tail wag. Anyone else have this?
And I think "line" refers to linear - no expo.
My co5 does that intermittent no start if I have the gear mesh too tight.
itsmillertime is offline Find More Posts by itsmillertime
Old Apr 05, 2012, 10:15 PM
Benf207 is offline
Joined Dec 2009
I think I solved the problem, my connections to the esc weren't so great. I re-soldered them, this time directly to the esc board. It's working great now.
Ben
Old Apr 05, 2012, 11:05 PM
afloyd82 is offline
Find More Posts by afloyd82
ladybird, miniCP, msrx, 4F180
Joined Jan 2012
lower the gyro rate on the TX or the RX? Im guessing TX. I want the piro rate to be faster than it is now, but maybe not quite msr fast. Msrx piro rate is perfect, something along those lines.
afloyd82 is offline Find More Posts by afloyd82
Old Apr 05, 2012, 11:18 PM
Joined Dec 2011
Either. Just experiment on the tx first by lowering it a little at a time.
Old Apr 05, 2012, 11:23 PM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
if you want faster rudder set negative expo on rudder.. i have mine around -20%
scub is offline Find More Posts by scub
Old Apr 05, 2012, 11:29 PM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Don't lower the gyro gain more than 50.5% or your gyros will turn off.
See this post. I used this to setup my servos so it does work as stated.
http://www.rcgroups.com/forums/showp...postcount=2334
Tom
Tom Z is offline Find More Posts by Tom Z
Old Apr 05, 2012, 11:50 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
mescalinedream said "he felt that rudder imput was very slow with tomz settings".
This depends which setup guide you use. Some have normal rudder settings and others have fast rudder settings.
I am trying to cover all the settings that everyone can use to start with for Beginners, Intermediate, Advanced, and 3D settings.
Under my custom Mini CP settings I listed these for rudder.
Aggressive 3D settings:
RUDD D/R - 125%, EXP -70 %
I would start at EXP -10 % and work your way up to the EXP -70 % until you get the response you want.
Tom
Old Apr 06, 2012, 12:07 AM
Joined Dec 2011
I meant at full stick travel lowering the gyro gain will speed up the tail. I didn't mean dual rates and expos. I have 0 expo and 125% on my rudder but lowering the gain definitely sped it up. Turn your gyro down to 51 and see what happens, lol.
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
