Old Mar 31, 2012, 08:04 PM
pmerritt is offline
Find More Posts by pmerritt
Joined Oct 2010
jb weld the coil?
pmerritt is offline Find More Posts by pmerritt
Old Mar 31, 2012, 08:17 PM
Apphoard is offline
Find More Posts by Apphoard
Apphoard's Avatar
United States, MD, Silver Spring
Joined Mar 2011
: found answer
Apphoard is offline Find More Posts by Apphoard
Old Mar 31, 2012, 09:17 PM
achogg33 is offline
Find More Posts by achogg33
Joined Oct 2011
I used a dab of hot glue on mine has not come off I have had plenty of crashes.
achogg33 is offline Find More Posts by achogg33
Old Apr 01, 2012, 07:24 AM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
new motors at http://mattbockman.com/?p=163 are 13,500 rpm and .25g heavier due to thicker winds! also they are black with a 1.5mm shaft. Someone said they are a whole lot more powerful then the c05. He plans on getting more soon! Hopefully we will have a new option other then the hp05. He says they will be cheap too like 19.99!
mescalinedream is offline Find More Posts by mescalinedream
Old Apr 01, 2012, 10:48 AM
Fraggle_Corp is online now
Find More Posts by Fraggle_Corp
Fraggle_Corp's Avatar
France, RA, Lyon
Joined Mar 2012
I proceeded to replace the coil by following the procedure given by mescalinedream (thank you again).
However, I have not used a cable from tail to promote a headphone cable, thinner and lightweight. (Certainly more difficult to solder on the PCB)
I set the new coil to the receiver with the epoxy resin to fix the assembly. The objective being to increase the crash resistance.
Before doing that I have verified that the receiver was working ...
After that, I've had no problem during a first test flight.
Old headphone used
welding and verifying
Fixing with epoxy
RTF
Fraggle_Corp is online now Find More Posts by Fraggle_Corp
Old Apr 01, 2012, 11:12 AM
MX48 is online now
Find More Posts by MX48
United States, GA
Joined Dec 2011
Looks good Fraggle_Corp.
Theres more than one way la peau un cat.
I hope the translation came out right .
Moto
MX48 is online now Find More Posts by MX48
Old Apr 01, 2012, 11:40 AM
France, RA, Lyon
Joined Mar 2012
Thx Moto and thx for your first contribution.
I do not know if this is the result of the translation, but it is not entirely clear to me, although I think understand the basic concept.
However, if we use the same method of translation, I hope mine are not so bad.
Old Apr 01, 2012, 12:22 PM
MX48 is online now
United States, GA
Joined Dec 2011
Ya, sorry. I didn't know how that would come out as I don't speak any French.
It was supposed to say 'there's more than one way to skin a cat'. But you may not even use that phrase there.
Coil still looks good tho, way better than my effort!
And yes your translation is better .
Moto
Old Apr 01, 2012, 12:50 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
I tried to buy one, lol. Sounds like a good deal. Revised c05 *with* pinion for $20 *shipped* And I'm looking for a 9 tooth now anyways. Sign me up.
itsmillertime is offline Find More Posts by itsmillertime
Old Apr 01, 2012, 06:46 PM
LevTor is offline
Find More Posts by LevTor
United States, NJ
Joined Jan 2011
Originally Posted by LevTor View Post
I just got my Mini CP but I may have a servo or gyro problem. The elev servo is moving rapidly without any input. Please see video below. Does anybody else had this problem?
http://www.youtube.com/watch?v=WCEf9vtuLU4
I think I know my elev twitching problem. I think my 5.8GHz cordless landline phone is interfering with my heli and causing the servo to twitch like that. Can anybody confirm if you get this twithing problem if you bind your Mini CP besides a 2.4GHz or 5.8GHz cordless phone? Thanks in advance.
LevTor is offline Find More Posts by LevTor
Old Apr 01, 2012, 07:14 PM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
I doubt that would be causing the issue. I have read posts from several users now, on here and helifreak, reporting issues with the elevator servo out of the box.
It seems the elevator servo is jinxed. If it were me I would try plugging other servos (e.g. aileron, pitch) into the elevator servo port and see if they get the jitters.
bytemuncher is offline Find More Posts by bytemuncher
Old Apr 01, 2012, 07:54 PM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
nice.. not holding my breath though. looks like it been a month since they last had any.. too many people seem to want to start a project and have good ideas but it never gets to the next step.
most likely a mcpx pinion.. we are the minority it seems. it's bad enough those mcpx guys wiped all the walkera ESCs from stock for their brushless conversion.
you can buy 9t here.
scub is offline Find More Posts by scub
Old Apr 01, 2012, 08:03 PM
Joined Dec 2011
I already bought a 7 and 8 tooth from there and don't want to buy another. I probably won't use the 7 tooth again and am hoping someone will be willing to trade.
Old Apr 01, 2012, 08:09 PM
paul2pilot is offline
Find More Posts by paul2pilot
paul2pilot's Avatar
Huntington Beach, CA
Joined Jan 2011
I have noticed that my wireless internet signal to my various computers gets severely disrupted (i.e. web surfing slows to a crawl) if I have the Tx switched on in the house, especially if it's close to the router or computer. I have never noticed the reverse where the heli signal was disrupted. I too suspect either a bad pot in the servo or the Rx may be messed up. Every time I start to see jittery movement from a servo, it has ceased upon swapping with new. Most were probably crash induced, but I think those little pots can get flat spots after a while regardless. Some last a long time and some don't. It's just dumb luck with these little servos.
paul2pilot is offline Find More Posts by paul2pilot
Old Apr 02, 2012, 09:46 AM
Joined Jul 2008
ITsmillertime, the pinion that is included is for a mcpx, its .03 mod and will not work with the mini's or genius gear. I too do not want to deal with homefly, It took 2 weeks to get 1 7t pinion from him when I ordered 2. HE said that he would send me the 8t when he has them. That was a over a month ago. Lots of excuses with that guy through emails. Avoid him like the plague.
Fragglecorps. Good job on that. I wish I would have known to use headphone wire. OR even thinner wire. I had read MX48 did his with tail sized wire 8 inches to be exact so I had done Benboys RX with the same diameter tail wire of 8 inches. It looked awful! I only charged him 7.80$ for the repair and to resolder battery cables. His rx works and I dont think a crash will rip the gorilla glued coil from his board. That is strong stuff. Benboy, if you want me to repair it with thinner wire i will free of charge! You pay shipping to get it here and I will pay the shipping to get it back to you. I can also put longer battery leads on it since the ones you had are short.
Levtor, so the problem goes away when you unplug your phone? that would cancel that theory right there.
Scub about those Walkera esc's There seems to be alot of those Double brushless walkera esc's out there which are a 10 amp and a 7 amp esc soldered together. i forgot how many amps the c05 pulls. It may be able to be run from the 7 and the 10 amp could be sold to break even? They are soldered together with 2 pins going from positive from one board to negative on ther other. There is only one power cord(actually two a male and female,one on the 10 amp which plugs into the battery,other you plug your battery cable out of the rx into it) though leading to the 10amp. The 7amp doesnt have power cables. If you are good enough at unsoldering the two apart then you are good enough to solder wires to the + and -(if you use the 7amp) . The wires leading to the motor have a plug that looks just like the servos plug on the mini/genius servos. The single white wire comes off the 10amp esc plugs in where the original motor plugs in at. The 7amp has a single yellow wire that plugs in the same spot. So its almost plug in play if you use the 10amp.
The esc is called WK-WST-10A-L7 Even though one esc is 7amps, they both weigh nearly the same.
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
