Old Mar 25, 2012, 09:51 PM
RawmadeCF is offline
Find More Posts by RawmadeCF
Perpetually covered in resin
RawmadeCF's Avatar
United States, NV, Las Vegas
Joined Dec 2011
Both kits come with the pinions on the motors, the Wow kit is the only one that comes with the genius main gear (and only Mini CP specific kit comes with it) which you would need to install on the helis main shaft, its the big plastic gear thay the motor drives.
RawmadeCF is offline Find More Posts by RawmadeCF
Old Mar 25, 2012, 09:54 PM
afloyd82 is offline
Find More Posts by afloyd82
ladybird, miniCP, msrx, 4F180
Joined Jan 2012
yea, my bad I was only referring to the pinion on the motor, Ive had the main gear off many times. I like the GCP gear more than the MCP gear simply because it gives more flight time. I like the extra headspeed of the MCP gear though. 200rpm is a difference for sure.
afloyd82 is offline Find More Posts by afloyd82
Old Mar 25, 2012, 10:01 PM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
I am using mannys settings itsmillertime. if that tells you pitch. -20-0-100% for normal I hover at the first line past half stick
afloyed I have the esc and motor from the double brushless kit if you want to buy it. heck i have the whole double brushless kit everything is used though. i installed it into the mini to try it out then took it all apart. I also unsoldered the esc apart to use it.
mescalinedream is offline Find More Posts by mescalinedream
Old Mar 25, 2012, 10:12 PM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
Originally Posted by itsmillertime View Post
With my blades folded back and main motor unplugged my blades almost touch the tail boom.
Your pitch TA should be somewhere around 55-65% if you're running 100 on your pitch curve (e.g. 0-100 in normal mode, or -100 -> +100 in idle up). I think most people use ta to set the pitch.
bytemuncher is offline Find More Posts by bytemuncher
Old Mar 25, 2012, 10:15 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
My ta is at 70% per Manny's settings. That may be it! Hopefully I'll get my replacement motor screws soon and will be able to fly it some more.
itsmillertime is offline Find More Posts by itsmillertime
Old Mar 25, 2012, 10:17 PM
Tokyo
Joined Jan 2010
Yeah, manny's pit ta is high as his collective management is god-like...definitely not a stick banger.
Old Mar 25, 2012, 11:29 PM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
anyone try the C05XL from hobbyking? got one on order.
scub is offline Find More Posts by scub
Old Mar 25, 2012, 11:35 PM
Joined Dec 2011
I almost got one but from Hobbyking's description it looks like it handles less current than the c05m.
Hobbyking c05xl description:
Kv (rpm/v) 10800
Weight (g) 6.8
Max Current (A) 4
Resistance (mh) 0
Max Voltage (V) 4
Power(W) 40
Shaft A (mm) 2
Length B (mm) 15 ,
Diameter C (mm) 14
Can Length D (mm) 9
Total Length E (mm) 22
co5 description
Kv (rpm/v) 11000
Weight (g) 4.6
Max Current (A) 7
Resistance (mh) 0
Max Voltage (V) 42
Power(W) 60
Shaft A (mm) 2
Length B (mm) 11
Diameter C (mm) 14
Can Length D (mm) 5
Total Length E (mm) 17
Old Mar 26, 2012, 12:29 AM
i812 is online now
Find More Posts by i812
i812's Avatar
Joined Aug 2009
Originally Posted by bytemuncher View Post
I see you're using a Gcp RX on the Mcp. How's that working out?
i812 is online now Find More Posts by i812
Old Mar 26, 2012, 12:42 AM
Tokyo
Joined Jan 2010
I like it. I haven't flown it enough to determine if it's up to par with my mini proper, but so far it's a lot of fun. As for the pitch servo issue (signal is reversed on the genius rx) I kind of half-a$$ed it using two linkages ca'ed together.
If you want to do it right should take the pitch servo apart and reverse it internally. If I get motivated I'll do that but for now flying it as is.
Also, tipstar said his mechanical version (long linkage on pitch servo) and electrical version (servo reversed internally) flew the same.
Old Mar 26, 2012, 06:40 AM
Joined Jul 2008
http://www.helifreak.com/showthread....ght=c05+rewind
I pmed this guy to see if he experimented more with rewinding. He says the c05 wire diameter is maybe 34g which means my wire is maybe 32 or 30. I am thinking my enameled spool of wire is 32. It is thcker than the c05 wire but same size as the red/clear wire going to the tail on the mini. I am really thinking about rewinding with whatever turns i can pack in there. I only have two other motors though and dont prefer them. The stock mini and the dble brushless. I was thinking of rewiring the dble brushless but it looks to be filled pretty good with copper. I know dr.kiwi who is a motor rewind guy on here has found out that neater winds equal more efficiency. I hate rewinding though. It hurts my fingers and i get scared of shorts
Anyone know how many grams of thrust the c05 is giving on the mini? With what gears? anyone know of any other motors thrust values on the mini? That will give a good baseline. I need to find an article on how to build a thrust stand. I have a nice 0.00g scale.
Old Mar 26, 2012, 08:23 AM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
I have thrust listed for the stock motor and C05 with different batteries in my Mini CP review.
http://www.rcgroups.com/forums/showthread.php?t=1616585
Tom
Tom Z is offline Find More Posts by Tom Z
Old Mar 26, 2012, 08:43 AM
Joined Jul 2008
I did a thrust test with my mini on stock battery with c05 1mmshaft 7tooth pinion on a genius main gear. I got 107.5 grams of full negative thrust. Tomz reported 101grams with 9t with genius maingear. So we know what the c05 can do stock. I am really wondering what rewinding this motor will do. The stock mini's motor is 79.5 grams full negative thrust. Tomz reported that stock mcpx thrust is 96.3 grams, he also said in another thread that with the mcpx on a c05 he got only 97.5grams of thrust. weird Another guy posted 120grams of thrust for the c05 v2 for the mcpx
The reason why I post the mcpx numbers is because its similar to our minis. My mini's weight with lightened canopy is 36.95 grams with c05 and lt walkera esc.
The mcpx weight stock is 38.5grams. Someone also reported the thrust for the hp08 rewound on the mcpx was 244 grams.
Old Mar 26, 2012, 07:48 PM
dbennettya is offline
Find More Posts by dbennettya
Joined Apr 2009
For the wire size just measure the OD with calipers and look it up here allowing for a little insulation thickness:
http://en.wikipedia.org/wiki/American_wire_gauge
Thrust numbers are not absolutes due to differerent wiring, escs, connectors and batteries and maybe different pitches and gearing when measuring. Most setups won't hold max thrust for more than 10 seconds or so.
Good Luck, Don
dbennettya is offline Find More Posts by dbennettya
Old Mar 26, 2012, 09:32 PM
Travis MCH is offline
Find More Posts by Travis MCH
Travis MCH's Avatar
United States, TX, New Braunfels
Joined May 2011
Has anyone heard a release date for the Genius FP?
Travis MCH is offline Find More Posts by Travis MCH
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
