Old Mar 12, 2012, 12:59 PM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
http://static.rcgroups.net/forums/at...o%281%29TH.jpg glue this thing down, also glue the battery wires where they enter the electrical board. Also there is a single black wire on the top front right corner Glue that down. Someone didnt and it touched something and smoked his board.
You might want to break in the motor in some water. Use a 6 v equivalent battery and throw the motor in a glass of water and let the brushes set. Sounds like your motor is just fine. its a lot more powerful than the genius. You will only get about 2 minutes of runtime with the stock mini motor. YOu might want to buy a genius motor. YOu will get about 6 1/2 minutes with that. Plus use the genius main gear in the mini.
mescalinedream is offline Find More Posts by mescalinedream
Old Mar 12, 2012, 01:17 PM
Couchking is offline
Find More Posts by Couchking
180CFX - Nano CPX - DX6
Couchking's Avatar
United States, CA, Laguna Niguel
Joined Nov 2010
Will do the hot glue fix ASAP. As for the genius main motor, will it mesh properly with the Mini CP gear? I have a brand new genius motor sitting around but no gear.
Couchking is offline Find More Posts by Couchking
Old Mar 12, 2012, 01:23 PM
Joined Jul 2008
You have to elongate the middle most bolt hole for it to mesh. just a hair. But its well worth it. Just keep putting the motor on and check the mesh , take a little off, check,etc. Dont just start carving into it.
Old Mar 12, 2012, 01:39 PM
dbennettya is offline
Find More Posts by dbennettya
Joined Apr 2009
Hey guys, why doesnt someone try this place to make some metal servo gears? http://www.shapeways.com/materials
Don't even bother, they can't hold tight enough tolerances.
YMMV, Don
dbennettya is offline Find More Posts by dbennettya
Old Mar 12, 2012, 02:20 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
Just flashed my radio. Now I have two throttle activated timers and switched f mode and t hold switches. Also played around with the library files for better outside visibility. This tx is awesome. And I also got my new mini rx in today.
itsmillertime is offline Find More Posts by itsmillertime
Old Mar 12, 2012, 02:23 PM
i812 is online now
Find More Posts by i812
i812's Avatar
Joined Aug 2009
It's difficult for me to remember who has which Devo.
I'm guessing you're posting about the D12?
i812 is online now Find More Posts by i812
Old Mar 12, 2012, 03:09 PM
Joined Jul 2008
He has the devo 8
Old Mar 12, 2012, 03:46 PM
i812 is online now
i812's Avatar
Joined Aug 2009
I just read in the Devo 8 thread, that Walkera recently released new upgrade S/W which allows throttle activated Timer.
Old Mar 12, 2012, 04:17 PM
achogg33 is offline
Find More Posts by achogg33
Joined Oct 2011
How did you flash your radio?
achogg33 is offline Find More Posts by achogg33
Old Mar 12, 2012, 06:44 PM
Joined Dec 2011
Follow these steps:
http://image.helipal.com/helipal-dev...ware-big-1.jpg
I'm not having much luck with this heli. I got my new rx today, bound it, hovered in my backyard for 20 seconds and then it goes out of control. Turns out my elevator servo decided to die mid-flight.
Old Mar 12, 2012, 11:15 PM
PeteAir is offline
Find More Posts by PeteAir
Joined Dec 2008
Follow these steps:
I see that on the walkera homepage there's two different software downloads for 8s....1/3/12 and 3/12/12.
Do you have to download both or just the latest software update?
PeteAir is offline Find More Posts by PeteAir
Old Mar 12, 2012, 11:49 PM
Joined Dec 2011
First download the update tool which will install the correct driver. Then click the picture of your tx and download the 10 or 100mw version. Obviously you want the latest one which is the 3/12/12
Fixed my mini again. Apparently you can push the tail boom in far enough to bind up the pitch servo and then you won't have any right cyclic. I'm back to loving this thing
Old Mar 13, 2012, 03:19 AM
dado099 is offline
Find More Posts by dado099
Italy
Joined Sep 2007
I just received mini cp with devo 6S.
The first thing I've done is upgrade TX with latest version from Walkera site.
Now it says:
Hardware: Ver 1.0
Software: Ver 0.4A
Library: Ver 0.3
Everything works fine but the main problem is that ID fixed code sub-menu
has disapperead at all (see pict attached).
I tried to search in every other menu but no luck.
Where the f*** has gone ?
I cannot set fixed id now !
Anybody got the same ?
dado099 is offline Find More Posts by dado099
Old Mar 13, 2012, 05:31 AM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
Uhh, yeah...where'd it go?
I did confirm the timer can be set according to stick position now, which is cool.
Also on devo 6s firmware.
bytemuncher is offline Find More Posts by bytemuncher
Old Mar 13, 2012, 06:03 AM
dado099 is offline
Italy
Joined Sep 2007
Hi, which version did you use to upgrade?
v04a or v04b ?
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
