Old Mar 07, 2012, 06:25 AM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
http://www.rcgroups.com/forums/showt...6#post20954215 so it looks like the only way to get more flight time out of these c05 motors is to rewire with thicker wire. I emailed aeorc.com to tell them the situation and that we are looking elsewhere for a motor. I had asked if they could maybe rewire or add stronger magnets. I haven't heard anything back from them yet.
I hadd said that the motor inside the double brushless kit is a hpo5. I had read it was. it probably isnt though. I will weigh it soon. I also do not think that 1015 motor is capable enough for our helis. people are using the 1012 on the mpx though.
http://www.bphobbies.com/view.asp?id...05&pid=U832265
this feigao 12x22mm at 10 grams might work. its ment for gearboxes. I run the slightly longer one in a edgerc pocket cimbat wing.
I had just read how quickly lithium batteries are progressing and that soon we will have lithium air but before that lithium sulfur. wow lithium air technology super light batteries.
mescalinedream is offline Find More Posts by mescalinedream
Old Mar 07, 2012, 06:44 AM
vronny is offline
Find More Posts by vronny
los angeles,ca
Joined May 2010
The double brushless main motor is the motor for v100D03BL!
vronny is offline Find More Posts by vronny
Old Mar 07, 2012, 07:10 AM
Joined Jul 2008
the weight of the double brushless motor is 7.02grams without the stock cable and plug. 7.33 grams with cord and plug.
my c05 is 4.3+/- cant really get a good reading since I still have the esc soldered to it.
stock mini main motor reads 9.97 grams. but I dont know if that is right since its a powerful magnet and gets stuck to my scale. it might be pulling down from metal inside the scale too
the weight of the wks-wk-10a-lt is 3.33 maybe I think cause I still have it wired to the c05 motor.
and I just counted 10 teeth on the pinion that is on the double brushless kit's motor.
Old Mar 07, 2012, 08:45 AM
i812 is offline
Find More Posts by i812
i812's Avatar
Joined Aug 2009
One of the places I've worked at weighed magnetic stuff and had to always keep the magnetic stuff atleast X distance away from any thing that could get magnetized, so the magnetised stuff was always placed on foam atleast X inches thick the entire time it was in the factory.
When they weighed their stuff, they'd place an appropriate empty foam container on the scale, TARE the scale, then place magnetic stuff on the foam container waiting on scale to get an accurate weight measurement. When they were done weighing they would simply pickup foam container with magnetic stuff, and the magnetic stuff would stay in that container throughout it's life in the factory until it shipped inside a better all enclosed and even thicker foam container packed inside a cardboard box.
No one was allowed to use "normal" tools within X inches of the magnetic stuff. People had to use special non-magnetizable tools. If magnetizable tools were brought within X inches of the magnets, then the magnets would loose their strength.
i812 is offline Find More Posts by i812
Old Mar 07, 2012, 09:14 AM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
HP05s 12,500kv Outrunner
Received the hp05s. I really like it, not sure why it's not more popular with the genius and mini. It definitely has more power than the c05 and only about 1 gram heavier. With a 7t it was a bit subdued, but still fun for cruising.
With an 8t it felt really good...but loads of tail blow outs. Thinking I will either extend the boom, go dual tail like this, or try dialing down my pitch TA a little as a temp fix until I can come up with a tail solution.
The hp05s is also a little slimmer than the c05 so you probably won't need to dremel down your aileron servo (mine's already see through it's so dremeled) when using a 7t pinion.
Pics and flight vids below. I could probably lose a few grams if I cleaned up my bl setup...might do it later if I get motivated. Included photos of c05 for comparison. If you watch the vids I think you'll see why I use the servo saver mod
Walkera Mini cp hp05s 8t Tail Blowouts (1 min 17 sec)
Walkera Mini Cp Hp05s 7t Pinion (2 min 44 sec)
bytemuncher is offline Find More Posts by bytemuncher
Old Mar 07, 2012, 10:13 AM
i812 is offline
i812's Avatar
Joined Aug 2009
Is there anything useful "buried" inside a Motor's name, or are Motor's names about as helpful identifying a characteristic as people's names are at determining their personality?
It took me a while; however, I've finally realized for some Motors having xx##yy names, the ## = ~ ## grams weight. For instance C05 = ~ 5g, HP05 = ~ 5g, HP03 = ~3g, HP08 = ~ 8g, etc.
So if the numbers in some Motor's names signify the weight, do the letters signify something?
I've seen the different specs for C05, C05M, HP05 but haven't figured why if any reason C, M, HP, or S signifies something.
Do the letters help users remember something about the Motor's spec?
Or are they just random letters that different manufactures use, but within a manufacturer's product line represents something about the Motor's characteristic?
Is there "decoder" "Lookup Data Table" that has all the common micro Motor's and their parameters all on one sheet, to help users narrow their design choices?
All this C05, C05M, HP03, HP05, HP06, HP08, 1015, 1050, 1220, .... Motor stuff that people frequently post makes as much sense to me as yesterday's Lotto number drawing.
Old Mar 07, 2012, 10:20 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Originally Posted by repressor View Post
Thanks guys, think I'll strengthen all the connections by soldering and add hot glue. Is it easy to remove hot glue if I need to get to the connections?
Yes you just put some alcohol on it and it will peel right off..
livonia bob is offline Find More Posts by livonia bob
Old Mar 07, 2012, 10:40 AM
HeliFlyer711 is offline
Find More Posts by HeliFlyer711
♘ Heli's Lives Matter ♘
HeliFlyer711's Avatar
United States, PA, Philadelphia
Joined Oct 2009
Originally Posted by i812 View Post
Is there anything useful.
No.
HeliFlyer711 is offline Find More Posts by HeliFlyer711
Old Mar 07, 2012, 10:52 AM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
I used a hp05s on my genius for testing with an 8 tooth pinion..tail blow outs were horrible. Tried a dual tail and it seemed like it never had enough power and piros were too slow
Maybe ill try with an sr120 tail this time around on the mini
Thanks for the vids..I think i will go order a 7tooth pinion. What main gear were you using?
BTW happy Birthday to the little one
indoorheli is offline Find More Posts by indoorheli
Old Mar 07, 2012, 11:19 AM
achogg33 is offline
Find More Posts by achogg33
Joined Oct 2011
http://www.youtube.com/watch?v=54Ul7LfMQS8
http://www.youtube.com/watch?v=ZRwvjbVO2J8
The HP05s is a very good motor i find the power is a little smoother than the c05m and there is more of it however The stock tail just does not cut it. I used a HP05s and HP02t brushless tail on my genius cp for a little bit worked qUite well however a bit heavy and unbalanced because of two escs had a bit of a bobbing effect similar to my mcpx had with 120sr tail and HP05s.
I am using a HP03s motor on my mini cp with 8t pinion is a bit smoother and a tad more powerful than the c05m a little lighter too however it does bog easier than the c05m but not as much as you think. I don't mind a little bit of bog it teaches you good collective management, then when you move up to bigger helis its all SOO much easier.
achogg33 is offline Find More Posts by achogg33
Old Mar 07, 2012, 11:46 AM
ilotek is offline
Find More Posts by ilotek
Joined Jan 2012
Originally Posted by indoorheli View Post
Morning Chris,
I meant to post a few videos for you last night..but damn mobile phone.
Here is one to verify you have 0 pitch at center which along with too much top and bottom pitch is almost always the culprits on the micro motor tail CP's
http://www.youtube.com/watch?v=PX9UgHfg_NM
These micro helis havecrazy extreme pitch possible as you have found out and sometimes like the mcpx if too much pitch and pounded inverted the tail will just turn off or blow out. I personally run 60% travel pos an neg for pitch and at least an 85% throttle curve and I am able to fly popping around a decent bit with no tail issues as in this video
http://www.youtube.com/watch?v=AJhq9ThUUk0
Thanks! I just zero'd in my blade pitch with your video guide, very simple and very easy to understand.
ilotek is offline Find More Posts by ilotek
Old Mar 07, 2012, 12:13 PM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Yes. This is among the best videos I have seen on basic CP setup for these small helis. It doesn't address all facets of CP setup, bit what the video aims to cover, it covers it very succinctly. It's been very helpful to me as well.
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Mar 07, 2012, 01:11 PM
andrewho83 is offline
Find More Posts by andrewho83
United States, CA, SF
Joined Jan 2012
Hey guys, I accidentally purchased the brushed version of the Mini CP when I wanted the brushless version from WOW. Is the upgrade much worth it ?
andrewho83 is offline Find More Posts by andrewho83
Old Mar 07, 2012, 02:00 PM
ilotek is offline
Joined Jan 2012
i'm still learning to fly basic maneuvers and orientations (no 3d yet), but the brushed version from wow is plenty for me. i have the C05 brushless that is currently on my genius, so when the time comes i might switch over. The brushed motor that comes with the stock mini-cp is great, plenty of power (but also a power hog), i get somewhere between 3 and 6 minutes (i have a collection of 240mah 25c's and some 350mah 20c's) of reliable around the house flying. every once in a while i'll do a pitch pump or some piro swivels, but nothing too fancy.
Old Mar 07, 2012, 02:02 PM
ilotek is offline
Joined Jan 2012
Chris
what i appreciated most was the back and forth between the Tx and Heli. Even though it was for a different Heli and a different Tx, I was still able to follow along. So many guides show one or the other, and it can be difficult to adapt to my particular situation (2801pro with the genius or devo 8s with the mini cp).
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
