Old Feb 26, 2012, 06:37 PM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
my RX pot came at around 12 o'clock (the flat side).. on TX im using 85-86% (have tried 90%, but feels too robotic i think) not sure what others are using.
scub is offline Find More Posts by scub
Old Feb 26, 2012, 06:38 PM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
Originally Posted by Tipstar View Post
Hi all,
Since 2801Pro version of min CP are unlikely to be released, I transplanted GeniusCP to the frame of mini.
Hi Tipstar, interesting way to deal with the reversed pitch servo. Do you think this setup flies as well as the original genius?
bytemuncher is offline Find More Posts by bytemuncher
Old Feb 26, 2012, 06:43 PM
Tokyo
Joined Jan 2010
When I cranked it up it was just to see if it would eliminate the ccw yaw drift (just testing as I already use a program mix to mix out the drift). Didn't really fly it long enough at that setting to see how it performed, but I know what you mean, I also like the tail a little loosey goosey.
zadaw is online now
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Originally Posted by djjd42 View Post
To those getting lots of bench time while learning 3D with their MCP (and/or other helis,) I keep seeing lots of posts about getting bench time, even a few folks getting disillusioned about the learning process due to all of the crashes and repairs and such, but rarely do I ever see sim time mentioned alongside bench time! Are folks just not mentioning their sim time or are they not getting any?
I ask not to point fingers or to claim any superiority, but simply as a new pilot who is trying to get daily time on both the sim and the real bird and finds himself wondering if his sim time will earn him less bench time once he does start flipping his MCP.
I am getting a bloodbath learning 3D with my V120D02S, The issue is that what the heli does in a sim is very different than in a real life. In the sim, you have a near perfect gyro, tail and power system. This is particularly true of flips where I can do low continuous flips and don't crash anymore. The problem is that flips on the V120D02S are often very skewered and that you are liable to a loss in power or tail blowout that result in a crash. Once you have crashed the heli a number of times, problems really mount and that will get you more and more crashes. In the end, it may be better just to buy a new heli.
I am interested in the MIni CP because it had been reported to flip more precisely and is much more robust than the V120D02S. However, I don't have a Devo transmitter and the choices are confusing.
zadaw is online now Find More Posts by zadaw
Old Feb 26, 2012, 06:46 PM
Tokyo
Joined Jan 2010
Originally Posted by mescalinedream View Post
ebay, and goto rcecho.com and get the 350mah 20c for 14.90 for five of em 2 bucks shipping.
Are those 20C or 25C? The one's that Kopteri recommended are 25C, so cost a little more $$
Old Feb 26, 2012, 06:52 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
The miniCp is the most sim like micro I have ever flown. It is super solid no matter what orientation you put it in.
indoorheli is offline Find More Posts by indoorheli
Old Feb 26, 2012, 08:30 PM
i812 is offline
Find More Posts by i812
i812's Avatar
Joined Aug 2009
Anyone know if this is the smallest lipo alarm available? http://fpvhobby.com/149-1s-lipo-low-voltage-alarm.html 0.1grams is pretty light.
Here's more info from the link:
Dimensions : 4 x 8 x 2 mm
Weight : 0.1 gram.
Red color led will turn OFF when voltage between 3.3 - 4.3 Volts
Red color led will turn ON when voltage drops under 3.2 Volts.
I think most heli's will drop out of the sky before that LiPo "alarm" activates the microdot LED at 3.2V
Even if you where determined, and let the LiPO discharge on the ground to 3.2V just to watch the microdot LED light up, isn't 3.2V considered below the recommended LiPo LVC point? If so, that "alarm" may be more accurately described as a "you just ruined/shortened the life of your LiPo" indicator.
i812 is offline Find More Posts by i812
Old Feb 26, 2012, 09:14 PM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
I guess they are 20c they could be 25 not sure. I know that they fly just as good as my stock battery. I am running the genius motor though. I haven't tried using these batteries with the stock motor.
any news on the servo gears, where can I get those? anyone know?
mescalinedream is offline Find More Posts by mescalinedream
Old Feb 26, 2012, 09:39 PM
superglued is offline
Find More Posts by superglued
superglued's Avatar
United States, CA, Cerritos
Joined Jan 2012
I spoke to Bob at helircstore on the phone earlier today to inquire about a replacement rx. He said that he will be getting practically every part for the mini cp in next week and will be calling Walkera about including servo gears in the upcoming order.
superglued is offline Find More Posts by superglued
Old Feb 26, 2012, 10:31 PM
ShaneXman is offline
Find More Posts by ShaneXman
Coaxial to CP? *shrugs*
ShaneXman's Avatar
United States, CA, Laguna Niguel
Joined Nov 2011
Originally Posted by indoorheli View Post
I think they are tired of hearing me try to haggle so the leave me out of the loop I know I can be a pain when it comes to pricing on anything as I consider myself a power user/buyer so i want discounts all the time
If anyone was curious about the frame drill out it looks like my original assumption of the drill area was correct. I took apart my mini last night to give a servo back to the genius since the genius servo cord is longer ,then to give the good servo gears to my mini (priorities).
I took a picture without the motor on so you could see the drill out. I didnt think walkera was ever that sloppy with my previous frames..
On the next go around I think I will purchase the regular and drill if needed myself, though I admit I am quite picky on things like this even though it has no effect on function.
I still have yet to use the miniCP gear so on a personal level I cant say which is better yet.
That's incredibly sloppy, and I can't believe Wow has the audacity to call that a "Mini CP Pro". If I could have a do-over, I too think I would go for the regular Mini CP and drill it myself. This type of shoddy work doesn't bode well with my OCD tendencies.
Originally Posted by wowhobbies View Post
Redefining the micro helicopter- We have tested the Mini CP-PRO and rated it the world's #1 micro performer in 2012. Not the one Walkera is shipping now, probably the one in your hand, LOL. It is not too late, you can still upgrade it yourself or buy a new PRO version.
We managed to recreate the original remarkable flyer that Manuel Campos flown in this video. We used the Genius main gear with a slight frame modification and a higher output battery. This upgrade greatly increases torque and power over the stock version. We will also include the stock Mini main gear in the package in case you want to go back to mild sports flying.
We are posting these video links again for those who have not seen them. Watch the amazing Mini CP-PRO, demonstrated by world-class pilot Manuel Campos, which breaks the traditional micro CP barrier. These videos are based on the initial version, which is far superior over the current stock versions. These videos were completed when Walkera first shipped its PRO version in January 2012. Wow Hobbies has recreated this pro version and has made them available again. The current stock Mini CP Walkera which we also sell on our site is still a great micro, a bit less expensive but it will not perform as well as the PRO version in this video.
Outdoor video of the Mini CP-Pro, available exclusively at WowHobbies.com
http://www.youtube.com/watch?v=49JOxQDZmQk
Indoor video of the Mini CP-Pro, available exclusively at WowHobbies.com
https://www.youtube.com/watch?v=Neit...5bFAAAAAAAAAAA
Which micro flies better than the Mini CP-PRO? It will take a modified upgraded brushless to even compare.
There has been discussion in the threads about the stock Mini CP which Walkera is shipping, not performing like the world's best ,IMO micro in the video above. We like to clarify that, it is because during the mass production run, Walkera had to change the gearing of the Mini CP to 9T to compliment the lower output stock batteries. The original design of the Mini CP was spectacular and now, Wow Hobbies has upgraded and recreated this version by re-gearing and upgrading the battery. The modification produces the extra torque needed for all-out 3D flight as shown on the videos. Our PRO package includes 2 gears and 2 batteries, one upgraded 240mAh, true 25C (measured, not what factory claims) with connectors installed in the USA and one Walkera stock 240mAh at true 20C (measured, not what factory claims). Both batteries have been tested and compared and the upgraded battery generates head speed at approximately 200rpm more than stock Walkera 240mAh battery. The upgraded battery also has twice the life cycle in comparison to the stock battery. Fly both batteries with the new gear we have installed for you and be your own judge of the difference in torque and head speed. All parts remain as Walkera stock so they are easy to obtain. Wow Hobbies has geared this heli precisely to match with the upgraded battery so you don't have to do any of the work. For those who are good in mod, hopefully this will help them save some money.
We call it the PRO version since it is not stock and flies way better.
Cheers,
Jonathan
www.WowHobbies.com
You see this Jonathan? Wow should take a long hard look at this quality of work before sending things like this out. We're already paying a premium buying domestically from Wow, so you'd think you'd take extra care and consideration to maintain your good reputation.
I paid BIG money for the Mini CP "Pro" / Devo 12S combo, and I definitely expect better quality of work than this.
That's just my 2 pennies though...
-Shane
ShaneXman is offline Find More Posts by ShaneXman
Old Feb 26, 2012, 11:25 PM
RawmadeCF is offline
Find More Posts by RawmadeCF
Perpetually covered in resin
RawmadeCF's Avatar
United States, NV, Las Vegas
Joined Dec 2011
lol.....did WOW do that professional cut job on the pinion hole and mount holes? Looks like it was done with a steak knife.
RawmadeCF is offline Find More Posts by RawmadeCF
Old Feb 26, 2012, 11:26 PM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Don't expect an answer from Jonathan. He's seen the picture, I'm sure. I think it's way to embarassing for anyone at Wow to comment on that picture without offering a free frame replacement along with a 20$ refund. You think this is going to happen? Don't count your chickens...
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
bobepine's Avatar
Joined Jun 2011
Really? Noway. I thought it may have been done with a bloody spoon!
Chris
Site Sponsor
Old Feb 26, 2012, 11:29 PM
Tokyo
Joined Jan 2010
@ShaneXman, it may just be the photo, but it looks like you need to press the gear on the main shaft until it "snaps" in...doesn't look like it's sitting flush in the photo.
See you've got a nice glue job on your power wires and coil. If you haven't already you might want to put a tiny dab on the end of the antenna wire. I saw somebody on helifreak burnt out his mini's rx because the antenna wire shorted on the power leads.
Old Feb 26, 2012, 11:34 PM
bobepine's Avatar
Joined Jun 2011
Alright. I have a question I have been meaning to ask you.
My Mini CP's tail hold fabulously. I didn't touch the pot on the RX. My gain is set to 83%. Doing pitch pumps as hard as possible, the tail holds flawlessly. But here's my problem. When I fly inverted, pitch pumps with negative pitch have a whole other result. The tail blows right out, like 360 degrees and I crash 90% of the time.
You know when you flip the heli you have to bring the throttle stick down to add negative pitch so the heli will fly inverted. Well, when I flip it, if I use moderate negative pitch, it works fine; tail holds. But...BUT... if I happen to lower the throttle stick too far when flipping which adds more negative pitch, the heli goes crazy because the tail blows, as I said, up to 360 degrees. Result: CRASH.
In brief, why does my tail hold so much better if I fly upright but blows out so easily when I fly inverted? Inadequate pitch settings? At this point, I'm teaching myself to flip the heli with only moderate neg pitch in order for the tail not to blow out.
My Genius CP doesn't do that. It may flip slower a bit but when inverted the tail holds fine, even for inverted pitch pumps.
Thanks!
Chris
Site Sponsor
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
