Old Jan 28, 2012, 10:06 AM
simages is online now
Find More Posts by simages
AMA# SIMAGES
simages's Avatar
United States, NY, Cold Spring
Joined Dec 2006
Thanks....
I am working on it this weekend, at least cover the tail feathers. Have to build my garage workbench and cablnets.
simages is online now Find More Posts by simages
Latest blog entry: Strega MK2 "P-51 Mustang" by...
Old Jan 28, 2012, 05:44 PM
fleaz is offline
Find More Posts by fleaz
fleaz's Avatar
United States, CO, Colorado Springs
Joined Apr 2007
Very Nice!
fleaz is offline Find More Posts by fleaz
Old Jan 28, 2012, 08:46 PM
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Thanks....
Just have a little trim left to do on the tail feathers....
Old Jan 29, 2012, 04:56 PM
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Think I'm....
finished with covering....
Old Jan 30, 2012, 09:20 PM
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Fit Fuse-Tail and prefit Wing
I suppose it will look better in Flight...
Old Feb 19, 2012, 08:06 PM
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Build interrupted....
No rush, but after all my wiring of the motor, and Pixie7. The AR6400 "puck" binds and I have controls, but the esc does not see the rx and the motor will not engage. Pixie just has a continuous beep and no blinking light and after triple checking the wiring and solder joints, no luck. Although it's new out of the package, I probably have a bad pixie esc.
The WRAM show is in 5 days so, I'll wait to get what I need then and a few other SA kits.....
Here are a few more pictures of the build before I shelved the eHopper.
Old Feb 19, 2012, 10:08 PM
fleaz is offline
fleaz's Avatar
Joined Apr 2007
Looks great! Hope you get it sorted out soon!
Old Feb 20, 2012, 08:56 AM
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Thanks....
I'm sure I will soon enough, sometimes I can't see the simple stuff which is why I put it aside. I do know better and after having cut into the wiring my joints and color match up is correct. I should have bench tested all of it, but assumed all the NIB stuff wouldn't give me problems.
Oops my bad
I want to stay with the SA recommended "brushed power system" as the results are well tested, like all their models....
So, it's worth the wait besides, I simply can not get a break for park flying weather. If it's flyable weather, it's during work hours, if it isn't raining, the wind is 15+ mph......
Old Feb 20, 2012, 01:37 PM
jcstalls is offline
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Looks real sweet Man.
I should get back to finishing mine from nearly two years past. All covered sans the wing. Did Ultracote lite clear. Tried to cover the wing but just could not get it with too much warpege, as I just want the top covered.
jcstalls is offline Find More Posts by jcstalls
Old Feb 26, 2012, 08:25 PM
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Originally Posted by jcstalls View Post
Looks real sweet Man. I should get back to finishing mine from nearly two years past. All covered sans the wing. Did Ultracote lite clear. Tried to cover the wing but just could not get it with too much warpege, as I just want the top covered.
Well get with it then.... I have to put mine back up on the shelf again. I tried an ElectriFly C-12 ESC and at least it lights up, but LED just blinks on and off and will not arm.
I have a Futaba 9C with a Spektrum DM8 module, but I couldn't get it to arm with my DX7 either.
It has got to be the servo plug "signal pin".... I have to wait a day or to until my nano and micro plug supplies arrive.
Old Feb 28, 2012, 08:39 PM
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Ok not the plug....
Prepared a new nano plug from the AR6400L to the esc and it still will not arm so, it very well could be the AR6400.
All of this is new out of box items......
I tested both the Pixie 7P and ElectriFly C-12 using a new AR500 and both ESCs just blink also..... so, I guess it's not the AR6400L.
I can not find the problem, it does it with both my DX7 and the Futaba 9C with the Spektrum TM8 module.....
Old Mar 03, 2012, 12:42 PM
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Problem solved.....
My like thread adventure chasing this gremlin....... it's titled;
Old Mar 11, 2012, 08:11 PM
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Ahhhhhhhhh.... I give up on using a AR6400L with an ESC so, I ordered 2 JR S185 servos and will just mount the an AR500........
Old Feb 02, 2013, 10:12 PM
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Not a year yet.....
Finally put the eHopper on the bench and cut into the frame for the servo option modification and very pleased with the result.
Old Feb 08, 2013, 07:05 PM
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Specsheet
added....
Build Log Stevens AeroModels - SkyBuggy (100) simages Electric Plane Talk 33 Aug 16, 2013 09:56 AM
Build Log Stevens AeroModels - SkyBuggy (300) simages Electric Plane Talk 6 Feb 08, 2013 06:59 PM
Sold Micro Cap 232 - Stevens Aeromodels $55 shipped. RobDog Aircraft - Electric - Airplanes (FS/W) 1 Apr 03, 2011 11:34 AM
Discussion Stevens Aeromodels e-Hopper+AR6400 dawkins Scratchbuilt Indoor and Micro Models 3 Mar 30, 2011 04:04 PM
