Old Jan 08, 2012, 08:19 PM
lmazoway@maine.r is offline
Find More Posts by lmazoway@maine.r
Joined Jul 2006
ASW-17 by Astro Flight
I am in the process of building this model. It has a 132" wingspan. I plan on adding an electric motor. The original design did not call for ailerons. An experienced pilot locally said if the plans don't call for it he wouldn't add them. I'm curious what the general consensus is about adding ailerons. It would be a whole lot easier to add them now then later. Personally, I like the added control ailerons offer.
Cheers.
Larry
York, ME
lmazoway@maine.r is offline Find More Posts by lmazoway@maine.r
Old Jan 08, 2012, 08:42 PM
sixty9mustang is offline
Find More Posts by sixty9mustang
Surf's up!!
sixty9mustang's Avatar
United States, Mt, East Helena
Joined Oct 2005
I personally would add the ailerons and maybe even flaps. If you do add the ailerons, reduce the dyhedral by at least half. When these were designed, servos were not available that would fit in the thin wings. One option you may want to consider is, having a set of foam cores cut with a modern airfoil, this would benefit using both ailerons and flaps, plus you would be able to customize it for slope or thermal capabilities. Just a thought though.
Good luck,
Chip
sixty9mustang is offline Find More Posts by sixty9mustang
Old Jan 16, 2012, 10:35 AM
rcsoar4fun is offline
Find More Posts by rcsoar4fun
United States, ID, Star
Joined May 2003
I have a couple of these kits under my workbench and my dad has flown one for a number of years.
I wouldn't build one without ailerons. It is a very long wing that can be fairly slow to respond. As chip mentioned back in the day the kit was designed it was a heavy and expensive option to add ailerons. Now there is really no reason to NOT add ailerons.
I would also add a little bit of fiberglass to the fuse. Over the years the fiberglass tends to get brittle. A layer or two of glass will strengthen the nose area and will account for some of the nose weight you will probably need anyway.
rcsoar4fun is offline Find More Posts by rcsoar4fun
Sold Astro Flight ASW-17 kit needacheaphobby Aircraft - Sailplanes (FS/W) 6 Oct 20, 2011 03:21 PM
Wanted Astro Flight ASW-17 kit nib Thomas Cummings Aircraft - Sailplanes (FS/W) 2 Apr 12, 2011 08:29 AM
Wanted astro flight asw-15, asw-17, californian NIB Thomas Cummings Aircraft - Sailplanes (FS/W) 2 Jul 16, 2010 05:03 AM
Discussion ASW 17 from Astro Flight Stefan Wahlberg Sailplane Talk 2 Oct 10, 2007 09:37 AM
FS: Astro Flight ASW 17 kit, collectors item ncapener Aircraft - Sailplanes (FS/W) 4 Feb 05, 2005 10:20 PM
