Old Jan 08, 2012, 07:09 PM
razorseal is offline
Find More Posts by razorseal
razorseal's Avatar
United States, FL, West Palm Beach
Joined Nov 2010
Voltage sensor not reading correctly on ER9x w/FrSky
I got a FrSky D8R-II with my er9x setup and I got the voltage sensor plugged into A2...
I go into the telemetry page and set A2 to 7.4v for a 2S lipo battery.
I go into the main screen and on the telemetry screen, it's showing me 2.78
Now I know my battery's charge is 3.75 and 3.76 per cell, totalling 7.57 or something... why is this screen showing me 2.78? I don't understand...
I gotta bring the voltage upto 19.8 on the A2 screen for it to give me 7.4 which isn't right obviously
I don't think I'm doing something right...
the voltage sensor hasn't been changed, it's on the 'ground' and 3S prong. apparently it's good for upto 5S (19.8V) like that.
it says to use the 2S one for upto 13.2 volts
I actually tried out a 3S battery on the sensor and it read off as well... (6.3)
razorseal is offline Find More Posts by razorseal
Old Jan 08, 2012, 07:23 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
19.8 or 19.9 is what mine is scaled at... with stock FrSky 3S sensor position.
ScottSails is offline Find More Posts by ScottSails
Old Jan 08, 2012, 07:27 PM
razorseal's Avatar
Joined Nov 2010
scaled at? so that's normal? that's really weird!
so this is normal to scale up to 19.8 to get it to read what you want? if I start dropping the voltage on the battery, it will also go down by 1:1 ratio?
I'd hate to see it drop by let's say .2 volts for every .5v my battery loses ya know?
Old Jan 08, 2012, 09:18 PM
ScottSails's Avatar
Upstate NY
Joined May 2005
That unit works up to 5S setup and uses a 6:1 resistor divider setup...
Max voltage at the receiver is 3.3V which is why the voltage divider is needed and the analog input is resolved to 8 bits as I read their manual.
I believe you can resolve to approx .1 volt RESOLUTION ON YOUR TRANSMITTER display/readout with this setup, do you need better?
If you use the 6 Channel receiver with built in input on receiver voltage, you will need a different scale factor on that input.
Last edited by ScottSails; Jan 09, 2012 at 08:15 AM. Reason: left off the RESOLUTION ON YOUR TRANSMITTER
Old Jan 09, 2012, 05:50 AM
razorseal's Avatar
Joined Nov 2010
I believe you can resolve to approx .1 volt with this setup, do you need better?
sorry, little confused =/
Old Jan 09, 2012, 08:09 AM
ScottSails's Avatar
Upstate NY
Joined May 2005
The receiver can only physically handle 3.3V max, it releases its "magic dust" if input voltages exceed this level - ie either clips the voltage or burns up. The setting you have used (default) on the voltage interface (which is really a resistor voltage divider) is a 6 to 1 ratio. So 19.8V on the red interface lead is reduced by a factor of 6 to 3.3V. 12.5V is reduced by a factor of 6 to 2.083V (examples).
In any case, this receiver 3.3V input (max) is converted to a range from 0 to 255 by the analog to digital converter (8 bit conversion) in the receiver. This 8bit (0-255value) is then transmitted by the receiver to the transmitter. The software in the transmitter needs to know the proper "scaling" to convert the digital number back to something that make sense to you and I instead of the 0 to 255 number. So in this case, with the 6:1 ratio, we tell the SW that 19.8 is the scaling factor for max voltage.
The resolution is roughly 19.8V/255 which is .077 volts (minimum change) so you will see ~.1 volt increments as the Lipo voltage drops down.
Make more sense now?
Scott
You can attach your DVM and calibrate your reported voltage even better since the SW lets you tweak the 19.8 value to 19.9 or whatever you like to allow your screen voltage to better match the DVM value since I am sure the resistors are not precision. You should only have to make small tweaks.
Old Apr 14, 2012, 11:41 AM
orentlikher is offline
Find More Posts by orentlikher
Joined Feb 2012
thnks Scott for this input, makes perfect sense now
orentlikher is offline Find More Posts by orentlikher
Discussion Spektrum TM1000 Y-harness not working with Voltage sensor coldboot Radios 5 Sep 20, 2011 07:05 PM
Discussion Hyperion Duo3 - balancer reading incorrect voltage on one cell malcolmm Batteries and Chargers 4 Aug 27, 2011 07:19 AM
Discussion Turnigy 9x + Frsky + er9x JasonR54 Radios 3 Jul 04, 2011 11:16 PM
Sold ER9x Eurgle 9x tx w/Frsky ACCST and 4rx panzerdivision Aircraft - General - Radio Equipment (FS/W) 1 Mar 31, 2011 08:09 AM
Help! Logger not reading correctly? beans07 Eagle Tree Systems 1 Apr 24, 2010 05:37 PM
