Oxford, Indiana
Joined Sep 2002
I believe the Syma's are all Mode 4, as opposed to Mode 2. Here's an explanation of them:
transmitter modes You can probably modify your transmitter, to make it fly Mode 2, if you have the 800, or any of them that actually has a transmitter that can move both directions, on the left. If you have the 107, which has just one direction on the left - up and back - you can't. However, the 800G flies great, and the transmitter is easily modified to Mode 2. Plus, it will fly the 107G just fine. That would be my recommendation - buy an 800G, mod the transmitter, and when you are a little bored with the 107G, switch to the 4-channel flying of the 800G I now have 4 107G's, 1 800G, 2 Blade mSR X's, and a Nano CPX. Won't be long, I'll have a Blade 130X, if everything goes well...and it started with the 107G. R |
Joined Feb 2011
http://www.instructables.com/id/DIY-...Control/#intro
Found this trying to figure out a way to boost the infared signal on the remote. seems like it will work well for our helis. |
Joined Jan 2013
I think I'll get an S800 main shaft on order just in case. This is the second one I've broken. Gluing didn't work at all. The first time I broke both pivot pins and the toilet bowl effect had the heli flying in 6-12 inch circles. The second time only one pivot pin broke and the circles were much larger, about 3-5 feet. Both times were caused by flying too high indoors and the flybar striking a light fixture. |
| Thread Tools | |
| Discussion F106 4ch inexpensive coaxial | Melnic | Coaxial Helicopters | 11 | Jan 11, 2012 04:39 PM |
| Help! 4ch coaxial beginner help please | Rusty Old Fart | Coaxial Helicopters | 5 | Nov 24, 2011 10:06 AM |
| Discussion Esky Nano 4ch coaxial. | Melnic | Micro Helis | 3 | Aug 01, 2011 01:19 AM |
| Discussion Large Size 4ch Coaxial??? | eviljack | Coaxial Helicopters | 11 | May 21, 2011 10:56 AM |
| Discussion 4CH Sub Micro Coaxial: Converting a 3CH to 4CH | EQMOD | Coaxial Helicopters | 6 | May 02, 2009 10:06 AM |
