Old Nov 08, 2012, 02:17 PM
adbradley is offline
Find More Posts by adbradley
adbradley's Avatar
Joined Mar 2007
Ive had my 800g for a couple days now, did the mode 2 mod this morning, works great, much much better! THANK YOU talktodan
looking for more mods now, i noticed there was an extra hole on the servo control horns that would give the pitch more throw.. has anyone done this?
adbradley is offline Find More Posts by adbradley
Old Nov 10, 2012, 03:34 PM
adbradley's Avatar
Joined Mar 2007
Update:
I lengthened the sticks by an inch and that made a huge difference, I also relocated the control linkages for the swash plate to the further out hole, this gave me much faster movement fore, Aft, and side to side, bit it is still very controllable. It's well worth a try!
Old Nov 15, 2012, 03:21 AM
canadabear07 is offline
Find More Posts by canadabear07
Joined Aug 2012
Hello guys is this a good heli to buy? also is it true that you have to calibrate the controller?
canadabear07 is offline Find More Posts by canadabear07
Old Nov 27, 2012, 02:51 PM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
I just picked one of these up on a whim since they were so cheap over at Amazon recently.
I HAVE to do the mode 2 mod on this transmitter. Wow. I so cannot fly 4ch mode 4! LOL I also see why you guys want to lengthen the sticks. It's controllable but you have a fine touch on it. That's okay though. Will report back when I have a mode 2 TX working.
RoboHeli is offline Find More Posts by RoboHeli
Old Nov 28, 2012, 11:01 AM
djhazardous is offline
Find More Posts by djhazardous
djhazardous's Avatar
Joined Jun 2012
I've just been flying my 107c and 800g today. Rekindled a bit of lost love with flying these things. I stopped when my v911 tail motor stopped working when it crashed in flight, I think it might just be a re-soldering job but not sure.
djhazardous is offline Find More Posts by djhazardous
Old Nov 28, 2012, 11:48 AM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
Where's a good location to buy replacement sticks for the transmitter? Any recommendations?
Old Nov 28, 2012, 01:09 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Robo, can you confirm something for me? I have asked this question before, but I got conflicting answers and I didn't know what to make of it.
My question is that is the S800G Tx compatible with the other Syma models?
In other words, could it control a S026, or could it be controlled by the S026 Tx (sans the 4th channel)? How about the S107?
Not sure how to answer your question. But I think I've seen others glued on an extension to the S800G sticks.
Heli Pad is offline Find More Posts by Heli Pad
Old Nov 28, 2012, 01:11 PM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
I'll be happy to test this out for you! I'll do it tonight when I get home and report back.
I saw someone earlier in this thread with a picture of some sort of different TX sticks (Walkera???) attached to their TX. Since the 800 TX sticks just pop off really easily it seems that it would be really straight forward to put a different set of sticks on it--assuming the mounting socket matched up properly.
Old Nov 28, 2012, 07:16 PM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
Test complete!
The S800G appears to respond to the S107G protocol but not the S110G (S026G) protocol.
- I could fly a S107G with the S800G controller. There two available channels to select from on the S800G TX and both worked to control two different S107Gs (one at a time of course!).
- I could fly a S800G with the S107G controller.
Everything behaved as it should. The mode 4 controllers performed as expected on both helis. I just didn't have aileron control when using the S107G TX on the S800G and the aileron control didn't affect the S107G when using the S800G TX.
The S800G TX did nothing when I tried it on the S110G.
Now I'm even more excited to convert my S800G TX to mode 2. I'd love to fly my S107Gs with a mode 2 TX.
Old Nov 28, 2012, 07:31 PM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
Thanks, Robo. That was the most complete testing and report that I've read so far regarding this matter. I'm completely satisfied with the results.
Yes, there is all the more reasons to convert the S800G Tx to mode 2, so that you could fly both the S800G and S107G in mode 2.
Wouldn't it be nice, if there was a 4ch Tx in the form factor of the S107G Tx? I'd be so stoked to convert that into mode 2 and fly everything that it could control. I think the S107G Tx feels more comfortable in hand than the S800G Tx.
Thanks, again.
Old Nov 28, 2012, 08:22 PM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
Sure thing! Glad to help.
I really like the Drift King (JXD 340)'s transmitter. It's large like the S107G and can switch from mode 4 to mode 2 if you hold down the two top buttons while powering it on. It only works on the 340 though. I tried it on my 339 but it didn't work.
Old Nov 29, 2012, 12:39 AM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
In terms of the flight characteristics, which one would you prefer? The S800G, or the JXD340? Especially, rank them of the precision and easy flying aspects.
Old Nov 29, 2012, 11:57 AM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
Hi Heli Pad, I'm not sure I'm in a position to answer that question yet. These little guys only arrived on Monday and I've not had too much of a chance to fly them yet. I've been diagnosing short flight times on my TRex 100X and now have a Nano with bad vibrations/shakes that I'm dealing with. LOL
I'm not going to be able to give you an objective answer until I can do the mode 2 mod on my S800G TX. However, I will give you my thoughts on the JXD 340 since I did get a chance to fly that around in mode 2 some last night.
First of all, if you fly it in mode 4 and don't touch the aileron, you can consider the JXD 340 to be a speedier and more aggressive version of the S107G. There's no spring on the throttle stick. There is a button you can press to put the tail motor into "high rate" which gives you much faster FF. There's a button that you can press to toggle the blinky LED array that this thing sports as well. I never touch the aileron in mode 4 because that totally messes me up.
Now, in mode 2, it flies well enough as a 4ch except that the aileron is essentially "bang-bang" at least it feels that way. It's either centered or it's all the way to one side or the other. When you do shift it to one side or another, it puts a bit of a shudder through the heli and you need to be able to compensate a little with the throttle to keep it at the same height. Other than that, you can fly this thing passably well as if you were flying a MCX but it just doesn't feel as agile because the elev and aile control doesn't have much variation. Still, you can fly sideways, do some nose-in and tail-in funnels, and in general do what you would normally do with a heli that actually had a functional swashplate. It's not bad. Then you can always "downshift" and fly it in mode 4 like a S107G if you like.
Be careful of the power plug. It's got the same connector as the S107G. I have no idea whether the polarity is correct though. The power plug LED is also backwards from the S107G. It lights up when its charging and turns off when it's not.
After I get my S800G TX converted, I'll let you know about that heli. I will say that in my initial testing, I found that it doesn't fly straight. It tends to fly diagonally--much more so than the MCX/2.
Old Nov 29, 2012, 12:18 PM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
Thank you, Robo. That's fair. I know you have these new toys to play with, and there is only so much play time in a day. Take your time on my questions. I'm not in any hurry.
Appreciate your early assessment on the JXD340. It is valuable info to me and to the others who might be reading this. Thanks for your work.
HP
Old Nov 30, 2012, 09:14 AM
Capatosta is offline
Find More Posts by Capatosta
Capatosta's Avatar
Joined Apr 2009
I can't see where the other end of the wire goes in the 2nd picture - can u elaborate I just got one of these and eft stick Throttle and Nose/Tail control and right stick fwd/back & side to side - Yes I'm a newbie
Originally Posted by talktodan View Post
I'm also an ME, or at least hope to be after this May
It was hard to get good pictures in low light (camera phone), but I think you should still be able to see the modifications. I cut two traces as seen as red lines and soldered the two wires where the blue circles are. I had to scratch off the green masking on one spot to apply solder onto the trace.
-Dan
Capatosta is offline Find More Posts by Capatosta
Discussion F106 4ch inexpensive coaxial Melnic Coaxial Helicopters 11 Jan 11, 2012 05:39 PM
Help! 4ch coaxial beginner help please Rusty Old Fart Coaxial Helicopters 5 Nov 24, 2011 11:06 AM
Discussion Esky Nano 4ch coaxial. Melnic Micro Helis 3 Aug 01, 2011 02:19 AM
Discussion Large Size 4ch Coaxial??? eviljack Coaxial Helicopters 11 May 21, 2011 11:56 AM
Discussion 4CH Sub Micro Coaxial: Converting a 3CH to 4CH EQMOD Coaxial Helicopters 6 May 02, 2009 11:06 AM
