Old Jan 11, 2012, 06:36 AM
zbrubaker is online now
Find More Posts by zbrubaker
ParkScaleModels
zbrubaker's Avatar
United States, PA, Loganville
Joined Feb 2002
Originally Posted by danrc View Post
Maybe true. I have many of your planes still up and flying regularly, and the coupe is a mainstay in my rotation. I do need one for the indoor now too.
Will you be going to E-Fest Dan? I'm still debating.
zbrubaker is online now Find More Posts by zbrubaker
Old Jan 11, 2012, 09:13 AM
glewis is online now
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
A series of these is a great idea! What's the wingspan?
If you can finish it out at around 2oz it will be a great flying model.
Glenn
glewis is online now Find More Posts by glewis
Old Jan 11, 2012, 09:33 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
Glenn
Glenn,
The way it's looking now, I should easily be under 2oz. I cut and assembled the wheelpants, wheels and landing gear fairings last night and put every thing on the scale minus the battery and it's just over 1.0 oz, but not enough to register at 1.1oz.
Wingspan is 19", wing area is about 54sq.in.
I'd like to do a series of these and maybe even make conversions of things like Comet kits or other old rubber powered free flight designs. One of my short list items is to do a conversion of the Guillows Piper Cherokee to use this Power Pack concept.
Old Jan 11, 2012, 09:54 AM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Hi Zeke,
Looking good. Since making the power pack removeable has to cause some redundant structure, any idea of how much weight it's costing you over a direct installation?
Pete
Petefoss is offline Find More Posts by Petefoss
Old Jan 11, 2012, 10:00 AM
danrc is offline
Find More Posts by danrc
danrc's Avatar
Rockford Illinois
I may try to sneak down there, but with the newborn, It's a very delicate situation with the wife. I have friends that go every year, so I'm sure the pressure will start to mount for me to go along too.
We have a series of indoor fly-ins at a large sports complex here. Something like this would attract immediate attention.
danrc is offline Find More Posts by danrc
Old Jan 11, 2012, 10:15 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
Originally Posted by Petefoss View Post
Hi Zeke,
Pete
I'm guessing somewhere around 3g by the time you add up the balsa structure and the magnets. I can try and weigh it tonight.
Old Jan 11, 2012, 06:22 PM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
Well...it looks like the maiden of the Monocoupe will be a while off. I had hoped to have it ready to fly at a indoor event this weekend, but due to a really stupid mistake, that won't be happening.
I was using my heat gun to shrink some tubing. I accidentally pointed the heat gun at the AR6400 brick for a couple seconds while my attention was focused elsewhere and...melted the servo cases! The receiver works, but the servo cases are distorted and the teeth on the servo shaft melted slightly. The servo motors work, but the servos are basically dead.
Old Jan 11, 2012, 06:29 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Ouch .. sounds like one of my classic moves ..
Vyceroy is offline Find More Posts by Vyceroy
Old Jan 11, 2012, 08:21 PM
danrc is offline
danrc's Avatar
Rockford Illinois
Add expletive here________. Done that before, a replacement servo should do the trick for you. I may have one to send you, but it may not make it in time..let me know, I could always. Check the lhs or overnight you from my stash.
Old Jan 12, 2012, 09:05 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
Good news is that the servo mechanics are available. So for $20, I'm getting replacements. I may see if any of the not-so-local hobby shops have the ar6400 bricks in stock...I wouldn't mind getting one of the new bricks with the brushless ESCs.
http://www.horizonhobby.com/products...9-gram-SPM6833
Old Jan 12, 2012, 09:20 AM
KSU Flyer is offline
Find More Posts by KSU Flyer
KSU Flyer's Avatar
Manhattan, Kansas, United States
Joined Nov 2001
Zeke,
You'll definitely be filling a hole in the micro RC market. Good going!
You know whats funny, when I was browsing through this thread from beginning to end, and before I got to post 22 I said to myself...."Self, I dunno if putting the heat shrink tubing to attach the control rods directly over the brick is such a good idea". Then, I read post 22 and said..."Self, you were right". :-)
Enough of that...pretty sweet that you can get replacement parts. Keep at it friend!
-Mike
KSU Flyer is offline Find More Posts by KSU Flyer
Old Jan 12, 2012, 09:23 AM
kleinaberfein is offline
Find More Posts by kleinaberfein
Closed Account
Joined Jul 2009
I want it I want it I want it .... sell it to me??? Please :-)
Jens
kleinaberfein is offline Find More Posts by kleinaberfein
Old Jan 12, 2012, 09:47 AM
danrc is offline
danrc's Avatar
Rockford Illinois
The only way I've found to mess with heat shrink over a brick is by gently touching a soldering iron to it. It's not the easiest method, but it has proven to be fairly effective.
Old Jan 12, 2012, 10:05 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
Jens
I've already worked out the kit cost ($29.99), I just need to get it finished and test flown before I make any kits available. Then I need to make some assembly instructions.
Kit will include:
Laser cut balsa parts
Front windscreen
Rare earth magnets
CF rod for control rods and wing struts
possibly wire for the landing gear
Old Jan 12, 2012, 10:49 AM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
sounds like a great deal to me.. this plane will hopefully open the door for more great designs..
Discussion Kangke Monocoupe 90A (60 size) Rockin G Giant Scale Airplanes 3 Nov 20, 2011 06:30 PM
Sold Monocoupe 90A (Park Scale Models) - $200 shipped (lowered price) rexnuktia Aircraft - Electric - Airplanes (FS/W) 7 Apr 24, 2011 10:39 AM
Sold $60 SUPER-KRAFT **Monocoupe 90A** Park Flyer ARF (balsa/ply); NIB !! $60 !! old_dude Aircraft - Electric - Airplanes (FS/W) 2 Mar 15, 2011 02:11 PM
For Sale Ikon west-monocoupe 90a- quarter scale-central florida tony0707 Aircraft - Fuel - Airplanes (FS/W) 0 Mar 12, 2011 10:47 AM
Sold SUPER-KRAFT **Monocoupe 90A** Park Flyer ARF (balsa/ply); NIB !! $90 and Will Ship old_dude Aircraft - Electric - Airplanes (FS/W) 2 Mar 08, 2011 03:06 PM
