Old Jan 08, 2012, 06:23 AM
9XTremist is offline
Find More Posts by 9XTremist
San Bernacesspool
9XTremist's Avatar
United States, CA, San Bernardino
Joined Feb 2010
Question
Using 4.8v & 6v UBEC's simultaneously
hello,
somewhere here i read how to wire 2 differing voltage ubec's for use at the same time to get 4.8v to the receiver and some servos and 6v to others. can somebody point me at a source of some kind? searching has been non-productive (not asking exactly the right way)
any directional input will be appreciated.
thanks to any and all,
michael clyde
9XTremist is offline Find More Posts by 9XTremist
Old Jan 08, 2012, 09:13 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Connect the 4.8V bec and those servos you want to run at 4.8V directly to the receiver, just as you would if the whole system was run at 4.8V.
On those servos you want to run at 6V, cut the positive power wire. Connect the signal and ground wires to the receiver as usual.
Connect 6V bec positive output to the positive servo power wire(s) which you cut in the previous step. On the servo side of the cut! Don't let the 6V power get into the 4.8V side.
Connect both esc grounds together. Done.
jkettu is offline Find More Posts by jkettu
Old Jan 08, 2012, 10:30 AM
San Bernacesspool
9XTremist's Avatar
Joined Feb 2010
jkettu
only one esc w/linear bec but, 2 ubec's. if the crude drawing is correct you'd think i'd have remembered how it's wired.
thank you for the help,
michael clyde
Question moved 9XTremist DIY Electronics 0 Jan 08, 2012 04:30 AM
Discussion Regulate 7.2v down to 4.8v or 6v Thermalin Batteries and Chargers 7 Nov 18, 2011 06:44 PM
Discussion 4.8v vs 6v for a receiver cessdave Batteries and Chargers 4 Oct 16, 2011 11:10 AM
Help! Charging a 6v flight pack with a standard 4.8v wall-wart deegola Radios 8 Mar 18, 2011 11:32 AM
UBEC 4.8V or 6V Doc Data Electric Plane Talk 2 Feb 24, 2005 11:48 AM
