Old Feb 03, 2012, 04:11 AM
heli ed007 is offline
Find More Posts by heli ed007
heli ed007's Avatar
BelgiŽ, Vlaams Gewest, Oostende
Joined Oct 2011
Hello you guys just got another mail from walkera.
Dear sirs,
the radio module of de devo8S is the same for the Devo12 convertion.
Hope this can help you to figure out this issues.
Many Thanks & Best regards
Sheila.Deng
Email: heli-13@walkera.com
MSN:heli-Sheila@hotmail.com
2012-02-03
heli ed007 is offline Find More Posts by heli ed007
Old Feb 07, 2012, 06:10 AM
heli ed007's Avatar
Joined Oct 2011
Cheapest you can find to do the conversion to S series.
Do not buy from hobby one is a real ripoff.
http://www.hobbyone.com.hk/cn/product.jsp?id=10896 19.90 dollars
http://www.ehirobo.com/shop/product_...ducts_id=11530 9.90 dollars
Grtz Ed
Old Feb 07, 2012, 03:21 PM
i812 is offline
Find More Posts by i812
i812's Avatar
Joined Aug 2009
So to convert to S, 8 and 12 need a module, but 6 and 7 don't?
i812 is offline Find More Posts by i812
Old Feb 08, 2012, 02:46 AM
heli ed007's Avatar
Joined Oct 2011
So far i know its only to convert the 8 an 12.
The 6 en 7 i dont know
Grtz Ed
Old Feb 08, 2012, 10:11 PM
bracketman is offline
Find More Posts by bracketman
United States, OH, Delaware
Joined Jan 2011
OK I bit the bullet and ordered the chip upgrade from ehirobo and the CTL01-D from oomodel.
I'm rolling the dice on this but what I can figure the CTL01-D is a stand alone unit that should bind with the upgraded DEVO 8. I have bound two RX's at once so it can be done.
I ran the update tool on my DEVO 8 and it worked fine using the standard non "S" files. Hopefully it will update to the "S" series after I install the chip.
If it works my next concern will be the range, I would like to install this in a plane also and it may not have the power to connect a long distance.
I will post when I receive them. It will imagine about 4 weeks.
bracketman is offline Find More Posts by bracketman
Old Feb 08, 2012, 10:49 PM
i812 is offline
i812's Avatar
Joined Aug 2009
If I understand the CTL01-D Telemetry specs that was posted on the first page of this thread, it says the CTL01-D Telemetry Module transmitter power is <= 100 mW
If that is correct, 100 mW = 20 dBm
As a comparison: the Devo 8S TX is spec'd to transmit from -5 to +20 dBm (0.3 to 100mW)
If that is correct, the CTL01-D Telemetry Transmitter puts out the same amount of power as the Devo 8S TX.
The range of their communication will also depend on their antennas, and RX sensitivities. Both the RX-802 and Devo 8S are spec'd to have -105 dBm sensitivity, and the RX-802 and CTL01-D appear to have about the same type of antenna, so I imagine you will loose range with the RX (RX-802) about the same range as the Telemetry (CTL01-D) Module.
Edit: original -20 dBm Devo 8S TX output power was "pulled" from Wowhobbies specifications which is erroneous
Last edited by i812; Feb 10, 2012 at 08:03 PM. Reason: Edited Devo 8S TX output power from -20 instead to +20dBm
Old Feb 09, 2012, 05:24 AM
NevB is offline
Find More Posts by NevB
microheli addict
Joined Nov 2009
Just received the module and updated my Devo 12 to Devo 12S.
Interestingly, I ordered a 8S module, but the package I received was labelled 12S module! Maybe the folks at hobbyone somehow recalled my emailing them and picked the "right" module?
Anyhow, the 8S upgrade instructions are basically useless for performing a 12S upgrade ... many more screws, bolts, and panels need to be removed on the 12S, but nothing too tricky if you are comfortable pulling electronics apart and putting them back together again.
NevB is offline Find More Posts by NevB
Old Feb 09, 2012, 06:22 AM
heli ed007's Avatar
Joined Oct 2011
I received my module also today.
If you look in the 12 manual its easily explained how to open the TX.
I think i will start now
Grtz Ed
Old Feb 09, 2012, 09:03 AM
eric16son is offline
Find More Posts by eric16son
Joined Nov 2008
walkera devo8s
Hi guys,
Any body knows whether the Walkera RX2801Pro receiver compatible with TX Walkera Devo8S?http://static.rcgroups.com/forums/im...s/confused.gif
eric16son is offline Find More Posts by eric16son
Old Feb 09, 2012, 09:25 AM
FDR_ is offline
Find More Posts by FDR_
Joined May 2011
Originally Posted by eric16son View Post
Hi guys,
No!
FDR_ is offline Find More Posts by FDR_
Old Feb 09, 2012, 11:11 AM
heli ed007's Avatar
Joined Oct 2011
Just upgraded my Devo12 toDevo 12S .
Did the software upgrade everything is ok.
Big Big problem i bought with the radiomodule the telemetry module WK-CTL01-D.
How do you wire it in the fancy plastic box there is no manual wiring diagram nothing.
One of you guys can explain how to get started with it .
How to wire and start using the damn thing
Thks Ed
Old Feb 09, 2012, 04:10 PM
Joined Jan 2011
Explain what you have tried so far.
The first page of this thread shows what wires go where.
The one in the lower right side should be RX power.
Post your progress.
Old Feb 09, 2012, 05:33 PM
i812 is offline
i812's Avatar
Joined Aug 2009
I think you might be correct.
The first page of this thread shows the WK-CTL01-D Telemetry Module's symbolization indicates lower right terminals are for POWER; however, the side "explanation" states "measuring connector of operating current and voltage". As usual, the explanation is probably incorrect; however the design (symbolization) is correct. Although, I haven't understood why 3 terminals are required for Power connection.
Edit: Later learned third "POWER" terminal is used as a signal terminal for binding Walkera Telemetry Module CTL01-D to RX802.
Also, what is the purpose of the top right terminals above the GPS terminals? They aren't symbolized.
Old Feb 09, 2012, 09:06 PM
Joined Jan 2011
Typical Walkera. Who knows what that terminal is for.
This thing is a option for the UFO-MX400, but it doesn't show it installed anywhere. A close look at the UFO-Mx400 receiver and speed controller does not have any wires or plug that would fit the upper right terminal. It is 6 prong, the RX and speed controller have a 7 prong connecting them together.
The module is suppose to plug into the RX the same as servo does. This would power it up at the same time as the RX, hopefully binding with the TX at the same time.
This sounds good.............. but it also could be a waste of money knowing Walkera..........unless someone with a working WK-CTL01-D could kindly post some info.
Old Feb 10, 2012, 02:27 AM
heli ed007's Avatar
Joined Oct 2011
Hello Guys.
Its working 4Temp sensorswhy. The 2 voltage are useful things.
The master voltage connector is also ok it shows the voltage of your RX battery.
If you using a separate Bec like on my 700.
The rest i have to figure out yet how it works with my 550 ho dos not have a separate bec
It binds immediately that's no problem
Where can you buy the GPS and connector. And how do you make(ore buy) the connections for the rate 1&2 i think this are for the rpm reading.
Grtz Ed
For Sale Walkera Genius 3D with DEVO 6 Touchscreen TX! volcomsnows2k Aircraft - Electric - Helis (FS/W) 1 Oct 30, 2011 11:51 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
