Old Sep 25, 2012, 04:18 AM
LIUCHUNYAN is offline
Find More Posts by LIUCHUNYAN
Joined Jul 2012
T380 installation process
1.Out the body from the box .
Description: main body
2.Remove the cover.
Description:
3.Take down four nuts of fixed landing gear position
Description:
Description:
4.Install landing gear .
Description:
5.Lock the screws of the fixed landing gear .
Description:
6.Landing gear installation is finished .
Description:
7.Install propellers .
Description:
8.Set up the cover.
Description:
The T380 installation is finished completely
LIUCHUNYAN is offline Find More Posts by LIUCHUNYAN
Old Sep 25, 2012, 04:21 PM
BrianSF is offline
Find More Posts by BrianSF
Joined Aug 2012
Hi, I recently got a T380 and a THx9 tx/rx and I'm having real problems getting them to communicate... the T380 beeps continuously which I think means it's not getting a signal, but I'm fairly sure I've followed all the instructions properly - binding etc... Any help gratefully received!
Brian
BrianSF is offline Find More Posts by BrianSF
Old Sep 25, 2012, 04:23 PM
BrianSF is offline
Joined Aug 2012
T380 help please!
Brian
Old Sep 25, 2012, 10:45 PM
Joined Jul 2012
Brian
Hello.Brian . Please check the remote control and receiver connection is normal or not.If that don't work , please take a short video upload. Then we will help you to analysis these conditions ,then we can find the Solution method for you .
Old Sep 25, 2012, 11:00 PM
Joined Jul 2012
Originally Posted by 490905002 View Post
The assembly is simple.
.T80
Assembly steps: a. assembled tripod. b. mounted on the rotor. c. installed receiver.
Elapsed time.: About 5 minutes
T380(regular version)
Assembly steps: .a. assembled tripod. b. mounted on the rotor. c. installed receiver.
T380(Advanced version)
Assembly steps:a. mounted on the rotor. b. installed receiver.
T580
Assembly steps: a. assembled tripod. .b. mounted on the blade. c. open the top cover, installed receiver. d. lock cover.
Elapsed time.:5 to 10 minutes
T580P+
Assembly steps: a. expand arm. b. assembled tripod. c. installed blades. d. installed receiver
Elapsed time.:10 to 15 minutes
Description:
2.Remove the cover.
Description:
Description:
Description:
Description:
Description:
Description:
Description:
8.Set up the cover.
Description:
Old Sep 26, 2012, 02:23 PM
490905002 is offline
Find More Posts by 490905002
Joined Jan 2010
The aircraft relatively long time LOTUSRC flight.
Flying a long time, we must ensure a favorable factor of three aspects:
Power system efficiency is high enough (the match between the motor, blades, power transfer to the right).
The machine itself is light enough (to use a new or special material).
Ensure the strength of the body (to use high-strength materials).
Description:
490905002 is offline Find More Posts by 490905002
Old Sep 26, 2012, 03:19 PM
Joined Jan 2010
How To Make Lotus RC Quad Copter Modification Landing Gear (2 min 50 sec)
Old Sep 26, 2012, 03:20 PM
Joined Jan 2010
T380 Quad Copter In Strong Wind 1st Flights LotusRC T380 Quadcopter (3 min 37 sec)
Old Sep 26, 2012, 03:26 PM
Joined Jan 2010
Unboxing LotusRC T380 QuadCopter (3 min 2 sec)
Old Sep 26, 2012, 03:27 PM
Joined Jan 2010
How to setup LotusRC T380 QuadCopter (4 min 20 sec)
Old Sep 28, 2012, 09:05 AM
Steinhard is offline
Find More Posts by Steinhard
Steinhard's Avatar
Indonesia
Joined Sep 2012
Brian
My T380 work well with Turnigy 9x tx/rx.
Just make sure about your channel position and set a little trim, and fly.
Steinhard is offline Find More Posts by Steinhard
Old Sep 28, 2012, 05:22 PM
flatlandrobin is offline
Find More Posts by flatlandrobin
flatlandrobin's Avatar
New Zealand, Otago, Queenstown
Joined Sep 2012
Hi guys, any idea why this is happening. The front left motor is always trying to spin faster than the others. It just tries to tip over on take off. As you can see the props are on correctly and the ACC calibration has been done.
http://youtu.be/RxVxUbHD4d4
Appreciate your help
flatlandrobin is offline Find More Posts by flatlandrobin
Old Sep 28, 2012, 10:07 PM
Joined Jul 2012
Vedio
LotusRC T380 QuadCopter Onoard GoPro Hero2 First Flight (5 min 27 sec)
New Quadcopter onboard footage with GoPro Hero2 (14 min 30 sec)
LotusRC T380 Windy flight (onboard GoPro) (3 min 12 sec)
LotusRC T380 Maiden Flight (onboard GoPro) (3 min 27 sec)
Old Sep 29, 2012, 02:32 AM
ColSonders is offline
Find More Posts by ColSonders
United Kingdom, England, Consett
Joined Feb 2012
Trouble shooting list:
You stated you've tried various radio's, does this mean you've also tried different receivers?
Have you tried swapping the motors to see if you continue to get the same behaviour or if the behaviour follows the motor?
If it follows the motor then look at trouble shooting the motors, otherwise it's either the signal coming in (which could still be something on the RX maybe?) or something on the T380's boards, faulty sensor on the FC board or perhaps faulty ESC board.
Just kinda thinking out loud here as i'm new to the hobby and don't really know the in's and out's well but this thread gets spammed by the two guys who are obviously selling these things so you may not get much help here so maybe worth trying to fins a T380 trouble shooting thread.
Good luck with it.
ColSonders is offline Find More Posts by ColSonders
Old Sep 29, 2012, 08:18 PM
Joined Sep 2012
Good luck with it.
Hey thanks for the reply.
The thing is, I have just sold the quad and they guy who bought it sent me that video. It was working fine when I last used it and now he is having these issues.
I only had it about a week and never had it act like that. He said if I cant figure out the problem then he wants to get a full refund. Im stumped because he sent me another video of him doing the ACC calibration and then trying to fly it straight after and it still wants to flip.
T380/2 (5 min 8 sec)
It must be something with the radio system surely? Could any damage from shipping it to him cause a fault like that? I know the New Zealand postal service tend to throw things around a lot. They warn you when you post an item that it needs to be packed well enough to survive being dropped from 4 feet onto the floor.
Has anyone else had this problem and managed to solve it?
For Sale Flight controller & esc's from lotusrc's new T580P+ quad malcr001 Aircraft - Electric - Multirotor (FS/W) 1 Oct 24, 2011 06:09 PM
Discussion What is the best value 6+ channel radio available under $200 RC_Crazy23 Radios 33 Oct 11, 2011 11:10 AM
Discussion Quad Propeller Guard - Sharing ideas, videos, photos lowfi Multirotor Talk 7 Jun 01, 2010 11:12 PM
Poll Best value in ARF electric gliders? SquireM Electric Sailplanes 15 Apr 10, 2010 08:17 AM
ESC discussion thread & poll (best value on price, governor, softstart, program ease. mhale71 Electric Heli Talk 8 Oct 25, 2005 11:09 PM
