Old Jul 27, 2012, 02:04 PM
tttom is offline
Find More Posts by tttom
United States, HI, Lahaina
Joined May 2007
scvjeff...where can I find those nylocks for the props
tttom is offline Find More Posts by tttom
Old Jul 29, 2012, 06:59 AM
bat is offline
bat
Find More Posts by bat
bat
bat's Avatar
cincinnati
Joined Jun 2003
I am really interested in how the motor and props just pop apart. What keeps these parts together during flight?
bat is offline Find More Posts by bat
Old Jul 29, 2012, 08:28 AM
eugenechong is offline
Find More Posts by eugenechong
Joined Jun 2011
Originally Posted by eugenechong View Post
hi all,
I'm new to quads. been flying heli for the past years n this is my first time doing quads. have a bit of issues with the t380. it is somehow not rotating to the left. does anyone know why? hovers fine just not rotating left.... can anyone please help....? many many thanks!
no one knows what's wrong......?
eugenechong is offline Find More Posts by eugenechong
Old Jul 29, 2012, 08:37 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
turn probelm
If your quad does Hover that means the motors are working, does it drift or turn by itself. if you adjust your trim full left or right does the quad move when the trim is moved)
tallflyer is offline Find More Posts by tallflyer
Old Jul 29, 2012, 08:56 AM
HummingbirdRPV is offline
Find More Posts by HummingbirdRPV
HummingbirdRPV's Avatar
Canada, AB, Edmonton
Joined Mar 2012
hi all,
I have found that if you overload the T380 it will not yaw correctly. Secondly if you are using one of those grey SpringRC radio systems the pot on the yaw channel can cause problems.
HummingbirdRPV is offline Find More Posts by HummingbirdRPV
Old Jul 29, 2012, 06:18 PM
SCVJeff is offline
Find More Posts by SCVJeff
Joined Mar 2009
Most hobby shops carry them in small packs.
SCVJeff is offline Find More Posts by SCVJeff
Old Jul 29, 2012, 06:23 PM
SCVJeff is offline
Joined Mar 2009
Magic magnets!
Don't stress it, it won't come part
Old Jul 29, 2012, 10:17 PM
Joined Jun 2011
Thanks for the reply =) It does rotate to the right when hovering and I've trimmed the tx all the way to counter it but no actual result. Im using a devo7 tx and the rx for it. I've tried to put on a 2801 rx and control it with the 2801tx and still the same. So i suspect it might be one of the motors has lost its full power.....not too sure myself.....
Old Jul 29, 2012, 10:22 PM
Joined Jun 2011
hi Hummingbird,
I've only attached a battery to it. It was rotating alright before until I have many bad crashes. =(
Old Jul 29, 2012, 11:16 PM
Joined Mar 2012
hi Hummingbird,
There is a chance that with the many crashes the bearings in the motor have become damaged. First hold the quad down with a weight and run the motors. After a few minutes see if the motors are getting hot. If they are hot something is wrong with them. After they cool take the props off and run the motors slowly and listen them. If you hear a squeally noise or the sound change abruptly the bearings are bad. Usually the top one as it gets the most force in a crash. New bearings should not be that hard to find.
Old Jul 30, 2012, 01:13 AM
Joined Jun 2011
now it might makes sense... one of the back motors bearing is dropping out easily when I take the prop off.... so it might b the bearing... I will get it replaced n see if it rotates... thx for that mate
Old Jul 30, 2012, 01:18 AM
Joined Jun 2011
oh....can't seems to find the bearings in the supplier where i get the t380 from....where can i buy the bearings.....? or do i have to buy the whole motor....?
Old Jul 30, 2012, 10:02 PM
Joined Mar 2012
Try LowPriceRC.com Look in the bearings tag. You will have to measure the OD and thickness of your bearing to get the right size. Of course they are 3mm ID. Cost about 3 bucks for five.
Old Jul 30, 2012, 10:05 PM
Joined Mar 2012
Also if the bearings are falling out put a bit of paper in the hole before you put the bearing in. This will hold it in. Drip a little oil in the bearing before you put the rotor on, it will help it last longer.
Old Jul 31, 2012, 11:31 AM
SCVJeff is offline
Joined Mar 2009
I use Tri-Flo with Teflon. The small bottle has a long and thin applicator tube making oiling them simple and controllable.
Also when checking the motors with props off, run only as long as necessary as the motors will heat up fast with no air being pulled by them (props off).
For Sale Flight controller & esc's from lotusrc's new T580P+ quad malcr001 Aircraft - Electric - Multirotor (FS/W) 1 Oct 24, 2011 05:09 PM
Discussion What is the best value 6+ channel radio available under $200 RC_Crazy23 Radios 33 Oct 11, 2011 10:10 AM
Discussion Quad Propeller Guard - Sharing ideas, videos, photos lowfi Multirotor Talk 7 Jun 01, 2010 10:12 PM
Poll Best value in ARF electric gliders? SquireM Electric Sailplanes 15 Apr 10, 2010 07:17 AM
ESC discussion thread & poll (best value on price, governor, softstart, program ease. mhale71 Electric Heli Talk 8 Oct 25, 2005 10:09 PM
