Old Jan 22, 2012, 10:09 AM
Yak 52 is offline
Find More Posts by Yak 52
Yak 52's Avatar
UK
Joined Jan 2009
Originally Posted by Sundancer View Post
Trouble is, you wouldn't know what the permissable stress was until you exceeded it and the wing fell off - a bit "all or nothing" maybe!
Hehe, that's true. Although I reckon you could work out the power of the magnets reasonably easily. They are incredibly strong for their size and I reckon the loads would be pretty low ...unless you're planning on pulling massive amounts of negative G
Yak 52 is offline Find More Posts by Yak 52
Old Jan 22, 2012, 11:38 AM
Guizzo 17 is offline
Find More Posts by Guizzo 17
Guizzo 17's Avatar
Joined Sep 2007
Magnets
I use magnets to hold my wings. See my thread here and my post here and sequents.
Guizzo 17 is offline Find More Posts by Guizzo 17
Old Jan 23, 2012, 02:04 PM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Hey guys, thanks for the comments and your input regarding wing fixing.
I have already decided to go with dowel pegs on the leading edge, in fact they are in already, slightly offset to reduce the weakness effect in alignment. I don't know if it's any better, just a theory I had while doing it!
They protrude through the UC former and provide positive location for the chin hatch, held at the front with a single magnet acting on a small adjustable screw head.
The nose cone has two short balsa tabs and is a friction fit.
I must admit I was close to going the way Owl suggested, ie sticking with the simple method, but I really do want to tidy it up. Anyway, I hadn't thought of using magnets on the TE, it's a wonderful idea! And as Yak says, I don't intend pulling negative G anytime soon, well not intentionally anyway
I had sort of decided to install a dowel peg or tab inside the fuse and another tab on the underside with a small slot at the rear, A band would be routed through a small hole in the TE to keep everything in place, something like the very rough sketch.
The more I think about the magnets, the more I like the idea! A pair of magnets with a small location tab would do the job admirably I think!
Cheers guys
sparks
sparks59 is offline Find More Posts by sparks59
Old Jan 23, 2012, 02:36 PM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Sounds OK to me Sparks. I came late to the use of magnets, only started using them for hatch and nose cowl retention etc about a year ago when I bought a pack of 50 5mm ones from Giant Cod and have used them so much that the last 6 of the 50 went into the Mamba, so I need to order more! They really do make for easy and neat fitting and convenient operation on the field.
Sundancer is offline Find More Posts by Sundancer
Old Feb 18, 2012, 01:24 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Back from my travels and had a bit of board time today.
Finally built up the elevator and it's on the board drying now.
I still have to sort the wing retainers, then its on to sanding, smoothing and covering. Looks like I might just get it finished in time George.
sparks
Old Feb 18, 2012, 02:29 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Go on Sparks, you can do it!
Old Mar 09, 2012, 10:24 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Hi Sparks
I really should hang out here more often - there's about the right amount of proper building going on here.
Here's my 'Raven 2X' - finally ended up as a pull-out plan in the October edition of 'Quiet & Electric Flight International' from UK based Traplet Publications. 2X full size meant that the span closely matches the standard length of balsa - less fuss all round
Did pretty much what you did - doubled the kit plan from 'House of Frog' and converted it to a much shorter motor. That's a 25gm Chino-cheapie that delivers adequate power to fly for ages on a 7 x 4 and a 2S LiPo of around 400mA. Controls are rudder and elevator, which work just fine. Flying weight is 8.6oz or thereabouts, battery dependent.
Used bamboo dowels and rubber bands to hold the wing on, as that looks about right. Your magnets will look even better, as a simulated glued-in wing. My top battery hatch is not exactly 'scale', but have long had this thing that electrics should be as easy to 'refuel' as the slimey models I used to fly in the last century
Other grand departures from 'scale' involve the tailfeathers - built up from 1/8" strip, as the model started looking like tail-heaviness was setting in - and she's covered in 'Solarfilm Lite'. I'd run out of Balsaloc to stick Litespan on with and doped tissue is right out of it. One, we live in a condo and the neighbours wouldn't care for the smell. Two, my wife is allergic to all paint fumes (unless being applied to the inside of our condo, oddly enough ).
Good luck with your 'Frogging', she'll make you smile when you get to watch her doing scale-like circles in the sky, but landing in the same field she started from. Mine also does some very un-Frog-like party tricks, but only if no-one else is watching...
Regards
Dereck
Dereck is offline Find More Posts by Dereck
Old Mar 24, 2012, 12:44 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Looks great Dereck,
I have been away again!
But have made a little progress here and there over the last week:
Covered the wing with red litespan, result looks good. I used the matt side out so it does have very 'tissue like' looks. Prepped the fuse and remaining components for covering with yellow litespan. Yes rhubarb and custard is the order of the day.
Still trying to get this one finished before the deadline.
sparks
Old Mar 24, 2012, 12:46 PM
owlsabie is offline
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
Welcome back Sparks
owlsabie is offline Find More Posts by owlsabie
Old Mar 24, 2012, 12:52 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Thanks Owl, seems to have been ages since I was on here!
Old Mar 24, 2012, 03:45 PM
Dereck is offline
Joined Dec 1996
'Rhubarb and custard' - love it !
Must at least get back to Litespan and stop this shiny plastic look I've degenerated to.
D
Old Mar 24, 2012, 04:04 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Glad to see you back Sparks - go for it, still plenty of time.
Old Apr 12, 2012, 03:35 AM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Progress update Frogaholics!
All flying surfaces are now covered!
I put the elevator and rudder control rods in last night, so now I can get the servos mounted, fuselage covered and the other bits and bobs finished.
Hope to get it there or thereabouts this weekend. Stormy weather (may be only sandstorm!) forecast for this weekend so the maiden will have to wait even if I do complete.
Photo's will follow before the final assembly.
Still aiming to finish in time and fly it!
sparks
Old Apr 12, 2012, 03:47 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Go for it Sparks - glad to see you should make it. If flying becomes a problem due to weather, don't forget this build off only specified photos of the FINISHED model, not flying shots or video were needed for entry. It'll be nice as we will then have three Ravens in different sizes and with different power systems - Jon's original size rubber one, Warren's 1.5x diesel powered one and your 2x electric.
Old Apr 12, 2012, 01:53 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Photo update on the Rhubarb and Custard Raven.
Fuselage covered and parts slotted together.
Still got some bits and bobs to finish, you know, those little things that always take longer than the big ones!
sparks
Contest Build off for FROG designs October 1st 2011 to April 30th 2012 Sundancer Vintage & Old-Timer Designs 237 Apr 23, 2013 03:29 PM
Discussion FROG Build Off Raven Yak 52 Free Flight 58 Oct 31, 2012 04:50 AM
Build Log FROG Build-Off Wren X2 Raf_Bob Vintage & Old-Timer Designs 55 Apr 07, 2012 07:45 PM
Build Log FROG Build-Off Widgeon X2+ orange&white Vintage & Old-Timer Designs 13 Nov 05, 2011 04:26 PM
Build Log Frog Build-off - Wren X2[ATTACH]4325080[/ATTACH] [ATTACH]4325081[/ATTACH] [ATTACH]4 Raf_Bob Vintage & Old-Timer Designs 2 Oct 06, 2011 05:13 PM
