Old Jan 13, 2012, 08:56 PM
dragbikebam is offline
Find More Posts by dragbikebam
dragbikebam's Avatar
Memphis, TN USA
Joined Apr 2009
Originally Posted by steve bisco View Post
What o rings do you mean ? I have asked Bruce about buying one of these bikes, but after that post I am having second thoughts, might just put the money into tires and spares for my t-258 as its running so well
I wouldn't let a little problem like orings keep you from getting one. Its an awesome bike, I was just frustrated because I couldn't fix it . all is well now.
dragbikebam is offline Find More Posts by dragbikebam
Old Jan 13, 2012, 10:42 PM
Memphis, TN USA
Joined Apr 2009
there is plenty of space between the inside body and lower chassis, a trick i do to get more lean with my tt r1 bodys is to split them down the middle and overlap the edges, use a couple of plastic pop rivets and shoe goo it back together .you cant even tell its been done and still just as strong. this can be done to the zh body too so i can get more lean if needed no problem.
Old Jan 17, 2012, 11:08 PM
Memphis, TN USA
Joined Apr 2009
servos came in today
the servos are a perfect fit. also noticed that the upper plate has 3 layers of c/f then to a dual layer were the servo slides in to accept the wider than 10.2mm width servo. you can see in first pic. I ended up using an extra Pats brakes inner cable and the stock housing, its a working bike. waiting on battery and time to paint.
Old Jan 20, 2012, 05:40 PM
steve bisco is offline
Find More Posts by steve bisco
canvey island
Joined Jul 2002
Gone a little quite here, hows it going
steve bisco is offline Find More Posts by steve bisco
Old Jan 20, 2012, 06:02 PM
Memphis, TN USA
Joined Apr 2009
been a busy week at work so not much time plus i had a couple of spills on the dirtbike and laying up in bed as much as i can. im getting too old for this . now you have forced me to get up and work on it ...i really want to finish it so i can try it out..
Old Jan 20, 2012, 06:56 PM
621clay is offline
Find More Posts by 621clay
621clay's Avatar
United States, TX, Houston
Joined Dec 2009
Springs coming, Your obligated to visit us!!
621clay is offline Find More Posts by 621clay
Old Jan 20, 2012, 07:03 PM
Memphis, TN USA
Joined Apr 2009
dont worrie about that i will be there. did my part for the night, drilled and tapped crash bar mounts and finished adding all the washers. its so wierd after handling this bike i forget its an 8th because its so similar in design to some of my 5ths. but then when i hold my 5ths after working on this thing they feel HUGE here are some pics and one of the front pulley grub screw.
Old Jan 23, 2012, 01:25 AM
Memphis, TN USA
Joined Apr 2009
Thought you might want to see how the body is trimmed for the steering rods..still painting and tunning. Will be finished soon. Im taking a little more time on the paint job than usual.
Old Jan 23, 2012, 08:49 PM
Memphis, TN USA
Joined Apr 2009
Pic of The Day
My attempt of a Castrol replica. It looks pretty good from 3ft...lol
Old Jan 24, 2012, 04:40 AM
canvey island
Joined Jul 2002
Looks real nice, where you guys get the decals from ?
Old Jan 24, 2012, 06:11 AM
Memphis, TN USA
Joined Apr 2009
Thanks Steve Im happy with it. I'm just using left over decals from NF bikes and other items. All my striping is paint..
Old Jan 24, 2012, 01:20 PM
deen247 is offline
Find More Posts by deen247
UK, Brentwood, Brentwood
Joined Feb 2011
hey the paint job looks great really nice and great thread as well
deen247 is offline Find More Posts by deen247
Old Jan 25, 2012, 02:07 PM
Memphis, TN USA
Joined Apr 2009
Battery came in!
OK here's were I'm getting exited. Since my battery came in today it was time to split the body and reattach with shoo goo. Lean angle is no longer an issue, it has more than it can use and lots of clearance. Had to trim around the pinion, it sticks out past the body now. In the 3rd pic you can see how much the body squeeze together. I will be running it soon. Thanks for the props Dean
Old Jan 25, 2012, 04:21 PM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
It could almost pass for the dry clutch you see on the side of the RC211V. Looks good love the retro graphics.
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Jan 25, 2012, 05:06 PM
Memphis, TN USA
Joined Apr 2009
THANKS CHRIS! Means a lot coming from you. I ran it for the first time today and it was a success. The stock steering springs are very soft so it took just a bit to get use to the steering. I replaced them with an NF spring cut in half and it was a little too hard so I got a little dialing in to do but it drove strait with no trim needed yet. I'm not a fan of the nonsensored esc/motor set up the power is very abrupt and tends to surge at the touch of the throttle when exiting a curve...this will not do...novak mongoose on the way and this systems going in the kyosho hor....
Discussion ZH 201 or 203..? Lukey B Motorcycles 15 Jan 08, 2012 12:19 AM
Sold Compagnucci GASOLINE 1/8th scale Mini Cooper David Hogue Cars - Cars and Parts (FS/W) 7 Mar 29, 2011 11:16 PM
For Sale 1/5th and 1/6th scale tires and 1/8th tires wingmanrc39 Cars - Trucks and Parts (FS/W) 2 Mar 20, 2011 12:01 PM
Discussion Scale Pursuit Models, Booth #203 ScaleMe AMA Expo 2 Jan 15, 2008 05:03 PM
For Sale Serpent 8th scale on and Ofna 8th scale off road Pacoson71 Cars - Cars and Parts (FS/W) 18 Jan 24, 2007 03:40 PM
