This thread is privately moderated by sotog, who may elect to delete unwanted replies.
Old Jan 07, 2012, 11:02 AM
sotog is offline
Find More Posts by sotog
Trader Rating: 22
sotog's Avatar
United States, CA, Santa Barbara
Joined Nov 2009
Trader Rating: 22
For Sale
Multiplex Easy Star / Sky Surfer / Bixler Adjustable Aluminum Motor Mount
This CNC machined aluminum two piece mount is designed to adapt a large range of outrunner motors to the Multiplex Easy Star. It will allow for three different motor mounting heights to accommodate propeller sizes ranging from 6" to 8".
With this feature you can easily run a lower KV motor with a larger propeller for more thrust and better efficiency. This would be a perfect combination for FPV pilots looking for longer flight times and a more quite platform.
Swapping motors from a 35mm outrunner with an 8" prop to a 28mm outrunner with a 6" prop can easily be done by removing a few screws. This is ideal for those looking to achieve the best performance possible.
Position 1: stock height up to a 6" prop.
Position 2: (+) 0.41" for up to a 7" prop.
Position 3: (+) 1.0" for up to an 8" prop.
Compatible Motors:
28mm Outrunner
35mm Outrunner
Acceptable bolt patterns (mm): 16x16, 16x19, 19x19, 19x25, 25x25
Due to the large variety of compatible motors, please verify motor size and KV will suite flying style. Contact me for any questions regarding motor compatibility
Three step installation:
1. Glue motor base tube into the fuselage (nacelle) making sure mounting flange is square.
2. Attach new motor to motor plate with supplied flat head screws.
3. Attach motor plate to motor tube at desired height with suppled pan head screws.
These are manufactured by Small Parts CNC. Please visit my website for more rc products.
Included: 1 - Motor Base Tube and Motor Plate, 4 motor screws and 4 mount screws.. Weight: 20g
Notes: A 35mm outrunner motor will only fit in Position 3 (+ 1.0"). 28mm outrunners will work in any of the three positions. The stock thrust angles are retained in all 3 positions. If a change in thrust angle is desired, simply add a small washer between the motor base and motor plate at the appropriate locations.
Price is $15.95 ea. with a fixed shipping of $2.00 in the US and $4.00 International. Send me a PM if you are interested or have any other questions.
Thanks for looking!
Terry
sotog is offline Find More Posts by sotog
Site Sponsor
For Sale Multiplex Easy Star / Sky Surfer / Bixler Adjustable Aluminum Motor Mount sotog Aircraft - Electric - Power Systems (FS/W) 6 Jan 05, 2012 05:44 PM
For Sale Multiplex Easy Star / Sky Surfer / Bixler Adjustable Aluminum Motor Mount sotog Aircraft - Electric - Power Systems (FS/W) 8 Dec 11, 2011 05:29 PM
Wanted 28mm 2200kv Inrunner for EZ Star/Bixler/Sky Surfer Rocketman1092 Aircraft - Electric - Power Systems (FS/W) 2 Dec 05, 2011 03:18 PM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
