Old Jan 06, 2012, 08:24 PM
62pilot is offline
Find More Posts by 62pilot
Don't look at me like that....
62pilot's Avatar
United States, AR, Piggott
Joined Aug 2005
Build Log
Guillows P-38.
Not sure where to put this one. It is a Guillows, yet it's a scratch foamy also. I 'm using the plans and the plastics from the kit, but the airframe is all foam. 8 oz as she sits but I'm sure a couple more by the time the rest of the details get added.
The wing is built with spars and sheeted like sparks cartoon fatties, but the fuse and booms are more jetset44 style. Of course it has stayed the same size as the Guillows.
62pilot is offline Find More Posts by 62pilot
Old Jan 06, 2012, 08:34 PM
62pilot is offline
62pilot's Avatar
Joined Aug 2005
here's some more of the construction pics.
Old Jan 07, 2012, 01:02 AM
RJD1234 is offline
Find More Posts by RJD1234
RJD1234's Avatar
Bakersfield, CA
Joined Apr 2008
62Pilot - plane has foam, you're in the right place. Cool looking P-38. Any idea as to motor size?
RJD1234 is offline Find More Posts by RJD1234
Old Jan 07, 2012, 07:17 AM
62pilot is offline
62pilot's Avatar
Joined Aug 2005
I have a couple of 1100 kv swinging 8 in props from HK that should do fine. 2250 3 cell in the pod should give about 10 min flights.
Old Jan 07, 2012, 11:13 PM
ForeverFlying is online now
Find More Posts by ForeverFlying
ForeverFlying's Avatar
Christiansburg, VA
Joined Sep 2002
P-38
62,
Looks awesome! How did you cut the foam? CNC?
ForeverFlying is online now Find More Posts by ForeverFlying
Old Jan 08, 2012, 09:37 AM
62pilot is offline
62pilot's Avatar
Joined Aug 2005
It is 3,6 and 9 mm cellfoam. I just used an xacto. And then sanded the crap out of it. The booms are built as a box and rounded over to shape. The center pod is layered top to bottom and then sanded.
Old Jan 09, 2012, 10:39 AM
Grabber5.0 is offline
Find More Posts by Grabber5.0
Professional Plane Crasher
USA, MO, Kansas City North
Joined Sep 2010
Looks fantastic.
Grabber5.0 is offline Find More Posts by Grabber5.0
Old Jan 09, 2012, 05:03 PM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Winter Is Coming
Doushiyou12's Avatar
Joined Feb 2010
very nice 62, i was going to buy this kit but wanted it bigger.
looks excellent so far. im tuned in.
Ill work on a 70" or so in the future.
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Jan 09, 2012, 05:05 PM
vtdiy is offline
Find More Posts by vtdiy
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Nice!
vtdiy is offline Find More Posts by vtdiy
Old Jan 09, 2012, 05:58 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
Very cool!
I've have the Guillows plastic parts for some time now. Used only the engine turbo/intake bits to dress up a slightly smaller MM-P38. Since I the little MMP38 was destroyed (didn't pull out of a split-s) I've bee dreaming of doing exactly this. Several other projects on the table right now but will sure watch your build.
Retracts?
Grejen is offline Find More Posts by Grejen
Old Jan 09, 2012, 07:05 PM
62pilot is offline
62pilot's Avatar
Joined Aug 2005
I built a foam Birddog from an 18 in kit and used all the non wood parts , powered with UM guts and it looked fantastic. I have a P-38 NIB but was given a full set of plastics ( been sitting on them about two years now) so I thought what the heck. No plans for Gear at all, just belly landings. Stll have a lot of sanding and filling before paint. Maby I can get back on it tommorow. Been building a custom display cessna 182 for a freind.
Old Jan 09, 2012, 07:51 PM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Give some thought to protecting the lower tail fins in belly landing a P-38. I've chewed up or torn pieces off a couple of times now.
I was thinking maybe a bent wire skid glued into the leading edges of the fins. Or maybe a plywood insert for a LE. Or a separate wire skid in front of them.
Maybe you can come up with something better!
Can't wait to see it fly.
Old Jan 10, 2012, 09:32 AM
62pilot is offline
62pilot's Avatar
Joined Aug 2005
I was thinking of doing the ply insert in the foam, or just some CF vail covering the entire stabilizer. May just go with full balsa as that area of the booms is pretty thin and springy, it would give a boat load of support for the weight.
Old Jan 10, 2012, 03:10 PM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Ply LE insert is going to be the lightest and toughest of those, I think, as well as the easiest to do. I'm going to take my own medicine on that!
Old Jan 10, 2012, 04:18 PM
Grejen is offline
IAMCANADIAN
Grejen's Avatar
Joined Jul 2002
Second the ply LE insert idea for the fins. I definitly had a problem with the lower portion of the fins catching and breaking on my little MM-P38. What happens is the nose or a nacelle catches something and tail skids around sideways and a fin hits something. Retracts could be an even bigger headache, depending on your runway. If you're not planning rudders then simply planning to replace broken fins every few flights may be less problematic, and lighter, than designing them not to break on landing. Or maybe cut the lower portions off and re-attach with a 2 or 3 small RE magnets. Enough to hold in flight but break away easily if they snag something solid.
Discussion Micro Guillows Tuffoam 18" P-38 conversion samson55 Scratchbuilt Indoor and Micro Models 3 Nov 02, 2011 10:10 AM
Question GWS P-38 or Guillows P-38? Yellow Baron Electric Warbirds 9 Sep 13, 2007 04:22 AM
Discussion GWS-38 using Guillows P-38 plastic parts donglass Electric Warbirds 0 May 03, 2007 10:29 AM
FS NIB Guillows P-38 Kit fw-190 Aircraft - Electric - Airplanes (FS/W) 3 Jun 15, 2002 01:08 PM
Guillows P-38 conversion bztguy Scale Kit/Scratch Built 2 Nov 22, 2001 11:03 PM
