Old Jan 06, 2012, 07:43 PM
Modelholic is offline
Find More Posts by Modelholic
Modelholic's Avatar
Perth WA
Joined Feb 2007
Contest
Funbuild 5 - Piper Apache.
I hate all the plans being posted here on RCGroups! There are so many fantastic models that I have been feeling somewhat overwhelmed with all the "must builds". This to the point where I actually haven't done any building for weeks.
I've set myself a few targets for 2012: my first twin, my first biplane and a new waterplane. Funbuild 5 seems like a great way to motivate for the first on that list. Algy2 has just posted a control line Piper Apache for twin 1-1.5cc motors. This seems like an ideal candidate for an R/C electric conversion and it's screaming at me to get it built. So I'm in - my first fun build I can't wait
Simon
Modelholic is offline Find More Posts by Modelholic
Old Jan 06, 2012, 07:50 PM
Modelholic's Avatar
Perth WA
Joined Feb 2007
Thanks go out to Algy for his continued postings.
Old Jan 06, 2012, 08:05 PM
Parkk is offline
Find More Posts by Parkk
Parkk's Avatar
Near Austin, TX
Joined Dec 2008
Looking forward to your build, I've flown a few of those years ago!
Parkk is offline Find More Posts by Parkk
Old Jan 07, 2012, 06:55 AM
jofrost is offline
Find More Posts by jofrost
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
Very cool subject Welcome to the Funbuild and looking forward to your build !
-John
jofrost is offline Find More Posts by jofrost
Old Jan 16, 2012, 06:25 PM
Mapco is offline
Find More Posts by Mapco
Mapco's Avatar
White mountains AZ.
Joined Jul 2004
Simon
Good choice I got my multi rating in one back in 1961. Don't have much time right now to do this build but I'm looking at the Grumman XP50-2 Skyrocket It's the one with the long nose.
Good luck to all.
Sonny
Mapco is offline Find More Posts by Mapco
Old Jan 31, 2012, 11:58 PM
Modelholic's Avatar
Perth WA
Joined Feb 2007
It's been a few weeks since I last posted here. That doesn't mean I haven't been thinking about this build and making a little bit of progress.
First job get the plans printed. It's really great to be able to just e-mail the plans to the print shop, get them printed and just pick them up when ready. I had a set printed at the, as designed 37" span and two copies upsized to 50" - or 1/9th scale. This is the size to which I'm planning to build to.
There followed quite a few days of thinking about the redesign requirements to convert this control line model to radio control. Hopefully I've worked through a few of the issues but no doubt more will crop up as things progress.
I've treated myself to a set of E-flite electric retracts (15-25 size) and hope to use these. I've redrawn the nacelle formers as best I can to accommodate the retracts, repositioning the bearers to suit. Aileron and flap positions have been worked out.
The plan shows the tail feathers shaped from solid 1/2" sheet, this for the 37" span model. This didn't seem a good idea for an electric build so these have been built up on a 1/16" central core. The internal framework was added from strip and sheet, hinge blocks glued and drilled for the Robart pin hinges; then sanded to a hopefully appropriate section! The dremel was now pressed into action to add a series of lightening holes. Once happy more 1/16th was used to sheet all the tail components. A 2mm overlap on the sheeting was allowed on the fin and stabilizer to produce a hinge shroud. All leading and trailing edges were shaped, a little bit of filler, more sanding and so far so good.
Now I've gone and complicated things by committing to build a couple of small IPS prototypes for Peter Rake and having made that commitment this build will be pushed back a bit. I've got to the end of June right?! How long can a couple of small models take?!
I'm still waiting for a number of items to come off back order at Hobbyking for this build so I this one might take a while anyway. I'll keep updating here as things progress.
Simon
Old Feb 25, 2012, 01:54 PM
CESARNOGUEIRA is offline
Find More Posts by CESARNOGUEIRA
MULTI ENGINE FANACTIC
CESARNOGUEIRA's Avatar
SAO PAULO,S.P.,BRAZIL
Joined Dec 2000
Man, you have a very good taste, indeed!
This is a wounderfull classic twin, hardly seen as a Rc model and after finished my present 3 builds (AN-22, Draken and a XB-42) this will be the next one!
Congrats from Brazil !
CESARNOGUEIRA is offline Find More Posts by CESARNOGUEIRA
Discussion Funbuild 5 - Invader from Aerowerkes Comet SRK LenBFP Scale Kit/Scratch Built 61 Mar 08, 2015 07:03 AM
Contest Funbuild 5 Beechcraft D-18 pmullen503 Scale Kit/Scratch Built 103 Sep 22, 2012 11:05 AM
Discussion Funbuild 5: Mountain Models/Molt Models P-38 Lightning (kit build) danrc Scale Kit/Scratch Built 24 Mar 22, 2012 03:19 PM
Build Log Funbuild 5 - Mountian/Molt Models P-38 srt8madness Scale Kit/Scratch Built 42 Mar 22, 2012 10:31 AM
Discussion Funbuild 5 interest thread danrc Scale Kit/Scratch Built 112 Dec 19, 2011 05:40 PM
