Old Jan 06, 2012, 07:14 PM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Are there guidelines for prop-in-slot designing?
I want to design a flying wing with a prop-in-slot. Looking at other designs for examples of how far back to put it, I see a variety of solutions. Are there any guidelines for this kind of design?
I'm working on a 20" w.s. delta for indoor use, built of 3mm Depron with a KFM step and running a 10 or 15g motor powered by 350 mAh 2S. Right now the motor would be right on the calculated CG or a tad behind it. How would this work out? (The parallel lines on either side of the slot are fins.)
Thanks in advance.
potshot is offline Find More Posts by potshot
Discussion Not another prop-in-slot F-22! foamflyer Foamies (Scratchbuilt) 6 Dec 28, 2011 07:34 PM
Discussion What 4s motors are out there for a 10 or 11" prop Howemd Multirotor Talk 1 Nov 08, 2011 12:21 AM
Discussion did anybody try a 1500KV 6s setup for "in the slot" prop?? HugePanic Pusher Prop Jet Models 0 Jul 06, 2011 12:49 PM
Question Is there anything to look out for when designing/building an airboat? boredom.is.me Dock Talk 17 May 19, 2011 10:32 AM
Discussion Slot design for "prop in slot" leadfeather Foamies (Scratchbuilt) 32 Oct 17, 2008 09:45 PM
