Old Jan 06, 2012, 05:24 PM
Lukey B is offline
Find More Posts by Lukey B
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
ZH 201 or 203..?
Hey guys... Maybe I'm just a little slow... I have had a bit of a look around but don't really understand what's goin with the two models...
The 203 is obviously the latest and greatest... Comes with , Belt drive, front brakes, slick tyres, carbon chassis, esc, motor, brake servo, everything bar the steering servo, radio and batteries... ???
The 201 is the older model that will still continue to be produced..??
Chain drive, aluminum chassis, treaded tyres, esc and motor... ???
I know the 203 is a different set up chassis wise, but I assume all the running gear is the same... ie, swingarm, forks, crashback, wheels, layshaft, brakes....
Sorry if it's a dumb set of questions, I've tried check the ZH site but can't open it... So I thought the next best place would be here...
Thanks... Luke...
Lukey B is offline Find More Posts by Lukey B
Old Jan 06, 2012, 05:56 PM
ado1974 is offline
Find More Posts by ado1974
ado1974's Avatar
melbourne, australia
Joined Jun 2009
lukey
you know you want both
so why resist.... then you can compare them for yourself
a.
ado1974 is offline Find More Posts by ado1974
Old Jan 06, 2012, 07:44 PM
621clay is offline
Find More Posts by 621clay
621clay's Avatar
United States, TX, Houston
Joined Dec 2009
The pro and cons of both "IMO"
I would love the 203 but cant afford it right now so im picking up a second hand 201 tommorrow.
The 203..
more lean angle
slicks
carbon chassis
steering head has been made bigger to accept larger bearings for the steering stem shaft
belt drive on the little bike vers the SB5 probably wont be a problem.
Same running gear yes
I think the steering will be awesome as it copies the Sb5
These are all the thoughts i have for now. But i have driven the 201 for a good amount of laps at GCR (Gulf Coast Raceway) with the 5000kv it is soooo fast and has soo much tourqe. 3/4 - full throttle it will flip the bike over no problem.
621clay is offline Find More Posts by 621clay
Old Jan 07, 2012, 05:04 AM
tavora is offline
Find More Posts by tavora
Ayrshire - Scotland
Joined May 2010
Z-203B Kit
Size: Length 275mm Width 220mm Height 90mm
Weight: 830g
Program dedicated 30A ESC Z 380 4950kv brushless motor size
2mm thick carbon side frames
Servo plate 2mm thick carbon
Front-made CNC 7075 machined aluminum and Riahoiru
Large USD front fork oil shocks made CNC 7075 machined aluminum
Parallel Steering rod
Rear swing arm made of machined aluminum CNC 7075
Aluminum antenna holder and brace
Aluminum adjustable rear shock
High-grip racing tires with inner molded
Precision molded polycarbonate cowl and driver made
Front brake Single
Jura & FRP disc pads disc
Full ball bearings
Chassis Kit Assembly loading
Sold separately
Lipo battery 7.4V1300mAh
Analog servo for steering and brake Hitec HS-65MG/ HYPERION Atlas Digital HP-DS11-ABM or Servo
3ch Radio set specifications
The link - http://www.zh-racing.com
tavora is offline Find More Posts by tavora
Old Jan 07, 2012, 05:17 AM
tavora is offline
Ayrshire - Scotland
Joined May 2010
ZH203B 1/8 MOTOCYCLE TEST (3 min 57 sec)
Old Jan 07, 2012, 05:35 AM
Lukey B is offline
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
Thanks for that champ... I still can't access the page though... Seen the video, but it don't tell you much eigther...
Am I right to believe the ZH has very little in the way of set up options..? No adjustable rake, ride height or wheelbase..?
Old Jan 07, 2012, 10:52 AM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
Fork rake appears to be set the same way as on the 201 or FM-1e/SF-50x bikes. Rear ride height is set via droop and optional down stop rod. And who needs to change the wheelbase?
Even if it was just equal to the 201/T-258 it would be an excellent bike.
Guidoracer is offline Find More Posts by Guidoracer
Old Jan 07, 2012, 11:17 AM
dragbikebam is offline
Find More Posts by dragbikebam
dragbikebam's Avatar
Memphis, TN USA
Joined Apr 2009
I should be receiving my 203 today...I will report and provide some better info and pics...mail should be running around noon.
dragbikebam is offline Find More Posts by dragbikebam
Old Jan 07, 2012, 01:50 PM
steve bisco is offline
Find More Posts by steve bisco
canvey island
Joined Jul 2002
I run the old OTO think its the same T-258 I have 2 of them that I run every day, its just got to be the best 1/8 bike out there, so fast and smooth and tough, never broken anything, the only trouble is the wear rate on the chain and sprockets but still like it better than a belt drive. I notice the new bike has bigger head stock bearings this has got to be so much better than the small 8x4x3 mm ones they use now, I was using a new set every week as one crash and they would be finished and would really mess up the handling, I now use ceramic ones and they are fine. So as you say if it was just equal to the old bike it will be nice and the larger head bearings will help out the only bad designed part of the T-258, not sure about the belt set up, I have the SB5 and hate the slipping belt
steve bisco is offline Find More Posts by steve bisco
Old Jan 07, 2012, 02:02 PM
621clay is offline
621clay's Avatar
Joined Dec 2009
I wonder if the head stock will be able to fit the 201 chassis?
Old Jan 07, 2012, 02:18 PM
canvey island
Joined Jul 2002
Yeah would be nice, but ceramic bearings work well, and not too expensive
Old Jan 07, 2012, 03:39 PM
Memphis, TN USA
Joined Apr 2009
mail was late today but just got it in..here are some pics.. this is an exotic bike.. really cool
Old Jan 07, 2012, 03:50 PM
621clay is offline
621clay's Avatar
Joined Dec 2009
Damn that is soooooo sexy!!!!
Old Jan 07, 2012, 03:56 PM
Memphis, TN USA
Joined Apr 2009
it has the alloy shock ends already so thats good
Old Jan 07, 2012, 04:18 PM
canvey island
Joined Jul 2002
Dont get me wrong, but it still dont kind of look like the bike I bought 3 years ago.
Discussion Mold Making 101 or 201? TomFlyer Slope 29 Dec 03, 2014 01:17 PM
Discussion Obama's Numbers Are Rising.........He Borrowed 203 Billion in October LcJ Life, The Universe, and Politics 31 Nov 03, 2011 10:27 AM
Help! RV 900 mHz TX/RX, DX-201. PROBLEMS bsfixit FPV Talk 3 Sep 12, 2011 02:13 PM
Discussion OTO T-258 or ZH Z-201B tavora Motorcycles 2 Jan 15, 2011 05:23 AM
Found FMA Lipo 202 or 203 chargers jcstalls Aircraft - Electric - Batteries & Chargers (FS/W) 5 Apr 20, 2010 02:39 AM
