Old Jan 06, 2012, 12:11 PM
photopilot is offline
Find More Posts by photopilot
Charging a Lipo for first time
After doing my research I am firing up my new charger and plunging ahead.
I have the Pro-Peak Sigma II.
I am charging 2S 2300 mAH 20C batteries.
I have read about charging for the first time, but did not pay attention when I saw it. Now I can't find a specific thread or what the term is for prepping a new battery. I saw a suggestion saying doing it at 1/2 C. So would it be a good idea to charge these batteries at 1.2 A for the first time? For how long should I use this charge rate? When can I step up to 1C or 3C?
One last question, my charger did not come with a temp sensor even though there is a plug on the side for it, should i take it back, or get a different model?
photopilot is offline Find More Posts by photopilot
Old Jan 06, 2012, 12:34 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
As one who has tested and used many LiPolys over the years I see no valid reason to charge at under 1C when doing a balance charge.
Any decent quality 20C LiPoly should be fine with up to a 3C balance charge but it is best to stay with the vendors / manufactures recomendations especially until you gain experience.
LiPoly batteries do not warn up enough during a normal charge for a temperature sensor to provide any benefit.
Charles
Old Jan 14, 2012, 07:56 PM
RUDDERLESS is offline
Find More Posts by RUDDERLESS
Joined Oct 2009
New lipo
HI
As I understand, new LIPOs should be "cycled" at a lower "rate" for a few cycles before using them.
My new charger will discharge to "storage" of 3.8v per cell.
Will charging, and then discharging to "storage" for a few cycles achieve the desired results?
Thanks, RUD
RUDDERLESS is offline Find More Posts by RUDDERLESS
Old Jan 14, 2012, 10:19 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Thanks, RUD
Yes it will.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jan 14, 2012, 11:29 PM
Stumblebee is offline
Find More Posts by Stumblebee
Stumblebee's Avatar
Port Coquitlam, BC CANADA
Joined Jun 2009
So how many is "a few cycles"?
Stumblebee is offline Find More Posts by Stumblebee
Old Jan 15, 2012, 01:19 AM
RC Helicopter Pilot
Joined Mar 2010
I do 5 cycles.
Old Jan 15, 2012, 03:18 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
HI
I'd be interested in any manufacturers guidance that said this? I've never seen any, to me it smacks of 'urban myth'.. People applying the same 'runing-in' principal that you apply to new engines (new flash.. batteries have no moving mechanical parts to run-in)
I'll keep an open mind but until I see a manufacturer advising it I'll not be doing it. Until then as far as I'm concerned having a battery sitting on the bench cycling is just wasting cycles of the batteries finite life. I'll just charge it and fly it.
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jan 15, 2012, 06:03 AM
Wayne Giles is offline
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
Steve
Steve,
I believe that there is a forming process in the first cycle.
I recently tested a range of Gens Ace and I always measure IR and other parameters (at 25degC, controlled) "as received" and after each of the first few low discharge cycles.
The IR values dropped significantly and consistently by 20 - 25% after the first cycle but did not change after that. This means that if you subject a new pack to very high discharge rates then its internal heat dissipation will be high and may well damage it.
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Jan 15, 2012, 07:21 AM
Southern Pride
Myself,Charle Wang (Mr. TP) Dave (Mr. Hyperion) have all recomended a new LiPoly breakin / forming routine and first started doing so around 6 years ago.
This info is much like proper storage info which has been posted as long or longer which many still have not heard of.
I have numerious CBA graphs and supporting text data in the Battery Graph Vault which clearly shows the increase in a LIPolys performance if given a chance yo form before having its' guts torn out.
One point I have posted numerious times is that one should never charge a new LiPoly ,place it in an aircraft and do a balls to the walls performance check flight.
Charles
Old Jan 15, 2012, 09:42 AM
Joined Oct 2009
Great info
Charles
Thanks Charles.
Could you confirm the minimum number of "break in" cycles for a new battery, and wether only discharging to storage during cycles, 3.8v/cell, is OK..
RUD
Old Jan 15, 2012, 10:40 AM
Stumblebee's Avatar
Joined Jun 2009
Thanks Charles.
RUD
I would be interested in this number as well. So far, Woodcrafter has mentioned five cycles.
Old Jan 15, 2012, 11:21 AM
alexthecheese is offline
Find More Posts by alexthecheese
United Kingdom, England, Chelmsford
Joined Jan 2012
By break in, do you mean full charge and then full discharge?
alexthecheese is offline Find More Posts by alexthecheese
Old Jan 15, 2012, 11:54 AM
PGR is offline
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
I completely agree with this and act accordingly. That said, I've never cycled a single battery pack with a charger, at least not for the sake of breaking it in. I charge 'em and fly 'em, however I keep it sedate for the first few flights on a new pack and I'll end the flight a lot sooner than I would with an "experienced" pack.
That's how I break in my packs and I get outstanding cycle life out of them. But it's important to note that I'm not one of those full-throttle pilots***. I was born with two thumbs and I keep 'em both busy when I fly.
Pete
*** Many new pilots (and some experienced ones) haven't developed good throttle management skills. They basically firewall the throttle to launch and the throttle stays there for the duration of the flight. This seems to be particularly true for ducted fan pilots. People who fly like that probably should break in their packs by cycling them on a charger.
rePete
PGR is offline Find More Posts by PGR
Old Jan 15, 2012, 12:06 PM
RC Helicopter Pilot
Joined Mar 2010
Here is an excerpt from the latest Thunder Power battery safety instructions.
"First few Flights
Thunder Power recommends no more than 3-5C average discharge for breaking in new packs. Also be extremely careful not to over
discharge new packs (Packs should NEVER be over discharged at any time, but over discharging on the first flight will ruin the battery
permanently before you are able to enjoy it. See “Caring for Battery” below)."
Now the 5 flights that I mentioned and that I have seen quoted by others for quite a while may be somewhat of an "urban legend" but why push it right up to the edge. Why risk damage when you don't have to.
I have also read that many have had better flights from a pack with 10 cycles on it than with 5 cycles on it. This may mean that the IR is still coming down after as many as 10 cycles.
Charles may have some data on this.
A side note - When I break in a new battery I do it in the air not on the bench.
I try to enjoy discharging the packs, not just creating heat on the bench.
Old Jan 25, 2012, 02:17 AM
Aberdeen
Joined Mar 2006
Thanks for the info. If this 'break in' is so important to the longevity of a battery I wonder then why the manufacturer doesn't put a cycle or two through the battery in the factory? If it has the benefits described then this would both increase performance and reduce premature failure warranty claims. Surely they would do it if it worked?
However.... Woodcrafter, I asked for manufacturers advice and you provided it, so on the basis that 'it cant do any harm' in the future I will at least go easy on new batteries for a flight or two and charge at less than highest c limit.. Like you, what I'm not about to do is waste a battery by cycling on the bench.
Steve
Discussion Charging BLade 120 ONE cell 500mAh for the first time PaulGT3 Micro Helis 5 Dec 26, 2011 11:01 PM
Discussion Problem when charging lipo's for the first time. saitrix Batteries and Chargers 3 May 03, 2010 08:01 AM
Discussion first time charging 3c lipo, quick question marnixh Batteries and Chargers 6 Apr 27, 2007 09:59 AM
First time charging Lipo fungus519 Batteries and Chargers 5 Aug 14, 2005 07:15 PM
First time LiPO charging taking too long on Schulz drabunich Batteries and Chargers 4 Mar 27, 2004 05:07 PM
