Anjan, I had about the same amount of experience as you a few months ago when I was scratch building my first glider. DiscoStu's suggestion of looking at plans of other gliders to find dimensions is good. The Supergee I is roughly the size of your glider, so you can get an idea of tail boom length and tail sizing. It's a very complicated glider but you can get a lot of basic sizing information from it.
The Clark-Y airfoil may not be the best choice for a glider....take a look at the AG03. Others here may have more suggestions. Assuming you're building a plane with rudder and elevator only you should plan on 11- 12 degrees of dihedral in each side of the wing. If you're using ailerons you can cut that in half. The tail volume calculations do seem kind of complicated, but if you download the Sailplane Calc spreadsheet and instructions you can try different dimensions until you get the tail volumes right. Tails will be bigger if you want to build a DLG (discus launch glider) rather than a regular hand launch glider. It will also help you with CG location, and pretty much any measurement on your glider. This spreadsheet helped me a lot when designing my glider, and it flies great. AND.....ask a lot of questions! There are a lot of friendly people on this forum who are willing to help out beginners like us! (thanks friendly helpful people! )
Joined Dec 2011
I don't see why not, can always try and fail and then you will know (I like different methods etc).
Only thing to keep in mind if this is to be a discus launch glider is will this method handle the launch stresses? Even if a wing survives a few launches, the constant launching can take its toll also. I had one wing I was fixing every few days flying cause it just couldn't handle the launch stresses properly. I guess I'm saying to try your method, but just keep in mind the extra stresses DLG technique puts on it. When you say plastic sheet,what type of plastic are you refering to? I've been keen to try stiff plastic over foam instead of fibreglass, just wondering if thats what your thinking |
Joined Dec 2011
I'm building this one to be Hand launched. what do you have to say about rocket propulsion?
Not thought about which plastic yet. I have experimented with the transparent plastic sheets used with projectors. I'm open for any better materials, but just not expensive ones. |
Here is a slope glider with wings made of foam sheets with ribs over a spar: the swinger. (It's a looong thraed....you'll have to dig to find construction drawings and photos.) |
| Thread Tools | |
| Article Cox Sky Cruiser EP 2.4 GHz RTF with FlightFlex Construction Review | 78dave | Beginner Training Area (Aircraft-Electric) | 82 | May 13, 2013 12:13 AM |
| Sold Airtronics RDS 8000 (8 channel)2.4 GHz TX, 8 channel RX with manual and wall charger | crosby | Aircraft - General - Radio Equipment (FS/W) | 1 | Nov 08, 2011 10:05 PM |
| Sold 6 channel dynam 2.4ghz radio with 2.4ghz receiver | flyer_dad | Aircraft - General - Radio Equipment (FS/W) | 2 | Aug 26, 2011 08:28 AM |
| Sold H.O.B 2x2 2 METER 2 CHANNEL GLIDER | Samboy | Aircraft - Sailplanes (FS/W) | 1 | Jan 03, 2007 04:18 AM |
