Old Apr 14, 2012, 12:14 PM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Originally Posted by Xizor View Post
Update - It seems you are able to force a re-flash even though the software shows the FBL unit as not connected.
I was able to re-flash the 2.5 firmware again twice, but still no joy. No leds lit and all servos dead.
I'm sure if you could re-flash the original CopterX firmware all would work again.
Where can I get that from, I wonder?
There should have been an option to save the original firmware, I feel.
Too late for that now... argh!!
Sorry to hear that mate - I'm in exactly the same position, waiting for Copterx to release some updated firmware
MikeHRC is offline Find More Posts by MikeHRC
Old Apr 14, 2012, 12:36 PM
IFHELI is online now
Find More Posts by IFHELI
IFHELI's Avatar
United States, RI, Woonsocket
Joined Apr 2010
I`m not sure where to place this post.... It looks like a new 3GYS is coming that will be able to use sat. rx.......http://www.alzrc.com/en/DownloadView.asp?/49.html
IFHELI is online now Find More Posts by IFHELI
Old Apr 14, 2012, 02:49 PM
Xizor is offline
Find More Posts by Xizor
UK
Joined Jun 2007
Is there any way that the original CX firmware could be extracted from a working 3X1000?
Anyone?
JohnNZ maybe?
Xizor is offline Find More Posts by Xizor
Old Apr 14, 2012, 03:30 PM
John_NZ is offline
Find More Posts by John_NZ
New Zealand, Taranaki, New Plymouth
Joined Jan 2012
Anyone?
JohnNZ maybe?
Not via the main upload protocol. But the jtag connections from the chip are connected to the connector pins. I don't know what functions are allowed with the jtag reader on this chip, but if the uploadable memory section is not read protected then it may be possible to read the image. But even if that was possible, you would need to figure out the starting. address. On top of all of that, the image may be encrypted before it is sent to the gyro.
I think people are just going to be patient and wait until copterx release a firmware upgrade, it will certainly be the path of least resistance.
John_NZ is offline Find More Posts by John_NZ
Old Apr 14, 2012, 03:48 PM
Xizor is offline
UK
Joined Jun 2007
OK, thanks for the reply John.
Just for the record, I've emailed KY-Model requesting a firmware file, but I'm not holding my breath. Hopefully the new upgrade won't be long.
Cheers
Old Apr 14, 2012, 05:08 PM
IFHELI's Avatar
Joined Apr 2010
Here`s a zip of V3.0en
Old Apr 14, 2012, 07:03 PM
Black_heart is offline
Find More Posts by Black_heart
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
John I think you should put something in your software to stop people from doing this (cross Flashing) tell CopterX releases a firmware of there own or one to repair units that people have already Bricked.
Black_heart is offline Find More Posts by Black_heart
Old Apr 14, 2012, 07:46 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Gosh, that's interesting. Completely different unit to these low cost units. Looks like the one I saw being made by the people (Robird) that made the Tarot GY650.
http://www.robirdrc.net/
It will be interesting to see the price and how well it flies. Can't wait.
beenflying is offline Find More Posts by beenflying
Old Apr 14, 2012, 07:57 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Yep, it's the Robird G31. Here's the G31 manual:
http://www.robirdrc.net/G31/G31_Setup_8_en.pdf
Old Apr 14, 2012, 11:12 PM
IFHELI's Avatar
Joined Apr 2010
Yep... I was checking the robird out and it is identical.
Old Apr 14, 2012, 11:27 PM
John_NZ is offline
Joined Jan 2012
Trouble is, the protocol for doing the upgrade doesn't distinguish between the different models. Nor does anything stop you trying to send some arbitrary file to the unit, you can send it any file you like.
Best I could do is offering a warning to make sure that you have firmware that matches the make of gyro you are using and that you may be at risk of turning it into a brick.
Old Apr 14, 2012, 11:29 PM
John_NZ is offline
Joined Jan 2012
Originally Posted by beenflying View Post
I tried the ZYX-S v3.01 in my early CX-3X1000, that is crossflashed to the ZYX. I decided to use the FBL app this time. The flash failed and just left the red light lit solid, so I decided to flash back to 2.5. I opened the 2.5 firmware and used the upgrade but at the end the red led was lit solid again.
I then decided to use the v3 Tarot app to flash the v2.5 firmware and the gyro was restored and worked fine. So I decided I would try flashing the v3.01 firmware again using the Tarot app, and again was left with the solid red led. Flashed back to v2.5 again and all was well.
I'm not sure why the FBL flash to v2.5 didn't work.
NOTE: I was able to crossflash my CX to a ZYX, because it was an early version (no silver edges on the blue part of the case). Others that have tried this have failed and the gyro is no longer usable.
Maybe it is that timing issue that I spoke about a while back. I may add a parameter in the fbl.ini file to allow you to control the time delay between blocks.
Old Apr 15, 2012, 01:17 AM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Cheers
Let us know if you get a response - I emailed them and Ehirobo a month ago and have heard nothing
Old Apr 15, 2012, 06:03 AM
Xizor is offline
UK
Joined Jun 2007
Yes, will do.
I've just emailed eHIROBO as well. Maybe if everyone else who has the same problem does the same we may get a result.
Cheers
Old Apr 15, 2012, 09:31 PM
2Drum is offline
Find More Posts by 2Drum
Jonesboro, AR
Joined Mar 2010
Had my ZYX-S set up using John's software everything worked perfect. Then I updated firmware, still worked perfect. Then I finally got instructions on binding to a satellite. Binding went flawless. After binding I removed the dual male connector, then re-powered system and it went through initialization then I got a blinking yellow light. That is all it will do!! It will not connect to computer or field programmer.
Now what????
I will try to put it back on full Rx tomorrow and see what happens.
If anybody has any ideas, suggestions or the same problem they have fixed please let me know.
Doug
2Drum is offline Find More Posts by 2Drum
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
