Old Mar 31, 2012, 11:35 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Originally Posted by VISTAVEGA View Post
can I go into the tail settings in advanced menue and set it the same as soft 3 d?
I did notice the tail didnt stop quit as fast but still very aceptible .
Absolutely! If the tail works well in one of the presets, you can copy those values into your own custom settings, which might use the cyclic settings from another preset. Every heli is different (special?) so just use the settings that work for you.
Since you have the USB adaptor, it's really easy to save all your settings in a .ini file - and it helps if you give the file a descriptive name that will mean something to you when you look at it some time in the future.
Do make sure that your heli is as good as it can be mechanically - otherwise you'll be chasing a moving target.
2Doggs is offline Find More Posts by 2Doggs
Old Apr 01, 2012, 12:17 AM
Pitchlynn is offline
Find More Posts by Pitchlynn
Joined Dec 2010
Originally Posted by Dawk View Post
Hi, I got rid of "Wobble of Death" by shortening servo arm ball distance from 12 to 8 mm, on my CopterX 450, like you told me.
All was nice, BUT... Today I flew twice, then decided to remove the training kit and, sadly, I immediatly got "WOD" again :-(
The training kit seemed to somewhat stabilize the heli / FBL module.
What can I do now to get rid of it again ? Lower some gain ?
Thanks in advance for any help.
I have the copterx head and started out with the WOD. Move your servo balls into about 5.5mm. I tried lowering the gains to 20 when I had longer servo arms. That got rid of the WOD but the heli was very unstable. With the balls at 5.5mm and the gains at default it flies like a dream.
Pitchlynn is offline Find More Posts by Pitchlynn
Old Apr 01, 2012, 01:27 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
I love the ide that all helis are "special" - some of mine are very "special" and not in a good way
MikeHRC is offline Find More Posts by MikeHRC
Old Apr 01, 2012, 05:33 PM
hudsonaj36 is offline
Find More Posts by hudsonaj36
United States, CA, Chico
Joined Apr 2011
First off thanks for all the help from all here. I have been lurking for a while.
When I adjust the gain setting on the radio, does that only affect the tail gain or does it affect all the gain settings?
hudsonaj36 is offline Find More Posts by hudsonaj36
Old Apr 01, 2012, 05:45 PM
Dawk is offline
Find More Posts by Dawk
France, IdF, Paris
Joined Mar 2012
Thank you for your answer and your help. I'll give a try.
5.5mm seems so close
Does any CopterX owner confirm having these wobble / shaking and need such a close distance with servo arms ?
Dawk is offline Find More Posts by Dawk
Old Apr 01, 2012, 05:48 PM
Dawk is offline
France, IdF, Paris
Joined Mar 2012
Nobody answered yet, so I'll try to help you.
As far as I know (but I only know a little) the gain in radio (gyro gain) is only for the tail.
Cyclic gain is adjusted in FBL module.
(Can someone more experimented confirm ?)
Old Apr 01, 2012, 06:11 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Yes
Now it's my turn. I thought I had every thing set up in my 250. All servos going the right direction, when you move the heli the gyro is working in the right direction, but it ends up my collective is 100% backwards. What do I need to change? Futaba radio.
mhills51 is offline Find More Posts by mhills51
Old Apr 01, 2012, 06:15 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
I did fly my 450fbl today. I don't like the dead band on the tail at all. I also realized in my rush to get it in the air I didn't check how much pitch I had. Need to plug it back into the computer and increase it.
Old Apr 01, 2012, 06:21 PM
Joined Apr 2011
Copy that, only for the tail. Thanks
Mhills51
Go back into setup and change your collective pitch adjustment to a negative number, if it is already negative make it positive. This will reverse your collective.
Old Apr 01, 2012, 06:47 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Thanks! all fixed! massive brain fart.
Old Apr 01, 2012, 07:57 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Both correct. Only for the tail..
ridge_racer is offline Find More Posts by ridge_racer
Old Apr 01, 2012, 07:59 PM
Black_heart is offline
Find More Posts by Black_heart
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
Originally Posted by mhills51 View Post
Yes
change your collective pitch for opposite of how you have it +95 well be -95
Black_heart is offline Find More Posts by Black_heart
Old Apr 02, 2012, 08:26 AM
wc_wickedclown is offline
Find More Posts by wc_wickedclown
United States, CA, Signal Hill
Joined Aug 2009
what is a good pitch and good rpm setting for the 450 pro ?
wc_wickedclown is offline Find More Posts by wc_wickedclown
Old Apr 02, 2012, 08:47 AM
Dawk is offline
France, IdF, Paris
Joined Mar 2012
1- What is the title of this thread ?
Oh yeah "PC Software for Setup/Programming the CX-3X1000, 3GYS, TG-1, ZYX etc."
2- I googled your exact question and had the answer...
Old Apr 02, 2012, 11:08 AM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Whatever flies right.
If u can get 12deg collective and 7-8 cyclic with the servo horns that short, go for it. It all depends on the length of your blade grip arms and the design of the frame.
Dr.M is offline Find More Posts by Dr.M
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
