![]() Catweazlec, I'm glad you're happy with your BT connection. I still get a buzz every time I connect with it.
Latest blog entry: RC Parts Suppliers - The Good and the...
I got my raptor to hover but that's about it. The tail movement wasn't very fluid and was to responsive. Is there a thread that goes into the setup and configuration/tweaking more since this thread is more software related? Also, anyone have a link to a more detailed description of what all the setting do? I thought I saw it on this thread but now I can't find it.
New Zealand, Taranaki, New Plymouth
Joined Jan 2012
This thread (http://www.rcgroups.com/forums/showthread.php?t=1512179) may have the other information you are looking for. |
Joined Jan 2012
http://fbl.net.nz/info |
Gloucester Ma
Joined Dec 2002
ALZRC 3GYS compatibility
I haven't seen much about this unit for a while. I will be setting mine up soon.
Is the current software still compatible with this? If I use Johns software will I still be able to use the programing box at the field. And lastly have there been any updates to the firmware? |
strange thing happen
Hi all after being assist by john i finally can upgrade firmware for my tarot but strange thing happen in the middle upgrade first on pc screen show time out when i click button ok sunddenly the gyro go crazy servo run itself and all 3 gryo light when on i did try to restart the gyro but no respon...
what when wrong ? thank john and to all who willing help me |
Paderborn DE
First up, I have absolutly nothing to do with John, never met, not talked, don't even live on the same continent!!!
Everybody seems to be delighted with his program, as I am, just think how much time it must take him to make our life easier, I know that I am thankfull and I am sure you all are. I have absolutly no idea how many people have clicked the 'Donate' button but I know I did. HINT HINT :-))))))) |
Oxfordshire, UK
Joined Jan 2007
The last time I used the software it was vcertainly still compatible - the only difference is in some of the comms identifier strings - but John has made his software compatible with all 3 (4?) of the FBL units. You can use the Prog Box as well as the software
I use the ALZRC 3GYS on my Gaui 550 - still original firmware (whilst it is probably preferable) I am not convinced that the firmware upgrade is essential. If you upgrade the software (to the latest Tarot firmware) |
United Kingdom, Witham
Joined Mar 2012
From my understanding if you upgrade the firmware the unit becomes a tarot zyx and only works with the zyx programming box. I think this is the case with the cx but not to sure that eny body has even tried upgrading ether the 3gys or the helicox but I'd imagine it would be the same
| Thread Tools | |
| Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. | Twmaster | Aircraft - Electric - Helis (FS/W) | 0 | Oct 08, 2011 07:31 PM |
| Multiplex mc V2 servo programming PC software | Thomas B | Radios | 3 | Jul 23, 2006 09:49 AM |
