Espritmodel.com Heli Air
Old Feb 22, 2012, 12:30 AM
New Zealand, Taranaki, New Plymouth
Joined Jan 2012
Originally Posted by Black_heart View Post
sure
You want the process of connecting the usb cable?
If you can plug the connector cable in either way into the USB adapter, just want to make sure it is documented which way around it should be.
Looks like it is connected with the pin locks facing up.
Does that red light come on when you plug it into the PC, or when you plug it in to the PC and the PC has the USB correct driver?
John_NZ is offline Find More Posts by John_NZ
Old Feb 22, 2012, 12:36 AM
Joined Apr 2009
Originally Posted by John_NZ View Post
Maybe it is the 324 or 644. Would help if they didn't keep sanding the information off
Would be nice if its the 644, that would leave room for future development. With the new firmware, the 324 would be close to capacity. It can't be the 164, that only has 16KB of flash rom.
Here's a pic I found that looks very like the chip in my cx3x1000
http://www.waveshare.net/photo/ic_pi...324PA-AU_l.jpg
Dan.
danau is offline Find More Posts by danau
Old Feb 22, 2012, 12:40 AM
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
I am uploading a video now
No making fun now Just trying to do My part
Connecting Tarot usb cable to computer (2 min 33 sec)
Black_heart is offline Find More Posts by Black_heart
Old Feb 22, 2012, 07:28 AM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
http://www.youtube.com/watch?v=5s0kG...ature=youtu.be
I think pretty much all the information is there! For me, it would have worked better with the camera in landscape mode, and you can even use one of those mini tripods to smooth out the camera movements - but that's only nit-picking! I'd actually never noticed the blue led's flashing on the USB unit, since I normally plug mine directly into the side of my laptop, where it's not so visible, so I actually learned something from watching your video!
2Doggs is offline Find More Posts by 2Doggs
Old Feb 22, 2012, 07:56 AM
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
Connect to ZYX via PC Software & USB link
Question about doing setup and firmware upgrade to ZYX gyro. Does the gyro need to be connected to the receiver and both transmitter & receiver be ON in order to connect to ZYX via USB link ?
I tried to use USB link/laptop with ZYX only (no connection to receiver and no transmitter) and a receiver battery pack. I could not establish a connection from software (either the original ZYX software or John_NZ software). ZYX had all 3 LEDs constantly ON when power was turned on.
I did try to use the programmer box and that only worked when ZYX was connected to receiver and transmitter needed to be turned on.
When I did the firmware upgrade to my Beast X, I needed no receiver or transmitter; just USB link from laptop to Beast X with receiver battery pack.
Any comment is appreciated..
Ching-Ho Cheng
lcc014 is offline Find More Posts by lcc014
Old Feb 22, 2012, 01:09 PM
Joined Jan 2012
Thanks BH, now I will have to do mine and get the page up.
Old Feb 22, 2012, 01:20 PM
Joined Jan 2012
Ching-Ho Cheng
I was doing my testing by having the transmitter on each time as that is what I had been advised by the manufacturer via a supplier.
Since that time, for development I just use a gyro connected to a Rx and I don't bother turning on the TX and it works fine.
I haven't tried just the gyro on its own.
If you have three lights on the gyro, it sounds like you need to try with at least the Rx connected to it,
To do the firmware upgrade, you need the Tarot 2.5 software.
You need to get the tarot software to connect to the gyro and all 3 lights to come up. This way the tarot software knows what port to use.
Next you need to load the firmware file.
After that, you need to disconnect power to the gyro. Hold down the button on the side of the gyro in the small hole and power up the gyro again. Gyro should start with a flashing red light. Now press upgrade on the tarot software and it will send the firmware.
You need to do this with 10 seconds or so, otherwise the gyro times out and will boot normally.
If you can get a connection to your gyro normally, then you won't be able upgrade the firmware.
Check that your USB adapter is being recognized by the PC and to use the tarot software make sure the assigned com port for the adapter is com4
Old Feb 22, 2012, 03:15 PM
United States, CA, Berkeley
Joined Jul 2011
Next you need to load the firmware file....
John, are we doing Tarot firmware upgrade in addition to your software?
asasan is offline Find More Posts by asasan
Old Feb 22, 2012, 03:24 PM
AMA Member # 458448
lcc014's Avatar
Joined May 2011
John,
Thanks, I will try to connect a RX to the gyro and check whether I could get a connection without the TX. Otherwise, I will turn on my TX too.
Ching-Ho Cheng
Old Feb 22, 2012, 05:31 PM
Joined Jan 2012
If you mean will the firmware upgrade option be available in my software, the answer is yes.
Just gotta get the day work under control.
Old Feb 22, 2012, 05:52 PM
Joined Jul 2011
That would be great. Meanwhile I tried to upgrade and the compressed file from Tarot has just txt instruction file and a 30kb zyx.bin. Firmware upgrade looks for .hex file. Somewhere in the middle of bad English instructions I saw something about using the software debugger to get the firmware upgrade file.
Any ideas?
Many thanks.
Old Feb 22, 2012, 07:15 PM
Joined Apr 2009
Warning Large Pictures
My second copterx gyro arrived today.
This time I took some photos. My first unit is inside the frames of my 250, and working very well, so i really don't want to take it out again.
First pic is as recieved. The other pics are after cleaning the chip with alchohol wipes and then a drop of liquid (CA remover) on top. I guess a drop of water would have the same effect.
Last picture is for reference.
I did the same cleaning and add a drop of liquid to the first one, but didn't think to take a photo before installing it (I was too excited to just fly it).
With what I could read on the first chip and now this second one, I am 99.99% sure that the chip is an ATMEL ATMEGA324PA-AU.
Big thanks to John_NZ for his awesome software, and everyone else who has contributed to make this as pain free and enjoyable for us all.
Cheers,
Dan.
P.s. After you click a picture, and after it is loaded you can click on it again to see it in full size on a new page.
Last edited by danau; Feb 22, 2012 at 07:20 PM. Reason: pics can be viewed in full size
Old Feb 22, 2012, 08:19 PM
Joined Jan 2012
Cheers,
Dan.
Yes, I would tend to agree with you. It looks definitely like a '2' before the '4', which would eliminate 164 and 644 and 1284.
Now all we need is for someone to write us the complete ATMEGA firmware with the PID models etc for the helis and then we can control the whole lot.
Old Feb 22, 2012, 08:53 PM
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Very clever, danau!
Dr.M is offline Find More Posts by Dr.M
Old Feb 23, 2012, 12:40 PM
Joined Jan 2011
one question ..if I update copterX firmware with the new tarot update can I use my copterX program box or I will need Tarot box future?
m_sas is offline Find More Posts by m_sas
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
