Old Feb 13, 2012, 01:20 PM
MikeHRC is online now
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Originally Posted by Dr.M View Post
Wow, those are pretty high gains. Perhaps tuning the PID settings would help: add more P and lower the I.
Strangely enough my 450 feels the same - faster flip rates on ele than ail. However, the 500 is backwards, ele is OK, but the ail roll is visibly higher. I guess each heli-gyro pairing has its unique quirks that need some tuning. I'm going to fiddle with the D/R on the Tx to get the same feeling on ele and ail rather than gyro tweaking. It's just so much easier and more predictable.
Get the lower Tarot head aileron flips on a sixpence (or on a dime for the septics)
MikeHRC is online now Find More Posts by MikeHRC
Old Feb 13, 2012, 02:55 PM
v823515 is offline
Find More Posts by v823515
United States, OK, Claremore
Joined Nov 2007
Quick question, under the Server Trim tab in setup, is this where I would use a swashplate leveling tool and if so, can I level idle up midstick and full positive collective and full negative collective here?
v823515 is offline Find More Posts by v823515
Old Feb 13, 2012, 03:31 PM
v823515 is offline
Joined Nov 2007
Sorry, I meant to say Servo trim tab.
Old Feb 13, 2012, 04:28 PM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
You use the Servo Trim tab to set the servo arms at 90 degrees (this will give you symetrical movement up and down), you then adjust the lengths of the Servo arm to swash links to get the swash level.
Old Feb 13, 2012, 06:11 PM
ptern is offline
Find More Posts by ptern
Joined Oct 2011
Originally Posted by naryan View Post
You can try removing the main blades and slowly spinning it up to about half throttle. If you still have the shaking then remove the tail blades and do it again. That helped me track down a tail blade vibration.
Very helpful thankyou.
ptern is offline Find More Posts by ptern
Old Feb 13, 2012, 06:14 PM
ptern is offline
Joined Oct 2011
Originally Posted by 2Doggs View Post
I can see from your smilies that you're feeling very emotional about this issue!
Nope it wasn't me who placed the smilies, it was my little 3 year old boy when I went out of the room. He sneaked in and played around with my laptop.
Old Feb 14, 2012, 12:54 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Brilliant! You better worry when he starts picking up hex drivers, though - you might need to check your setup!
2Doggs is offline Find More Posts by 2Doggs
Old Feb 14, 2012, 01:28 AM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I got my bluetooth adapter in the mail today. The good news is IT WORKS!!! I can now connect to my heli without the USB link. I just run John's app and click connect (COM5). The bluetooth links and I get 3 green lights. Everything works fine.
So optional it can be mounted on the heli or moved between helis for wireless connectivity.
Full details to come...
beenflying is offline Find More Posts by beenflying
Old Feb 14, 2012, 01:44 AM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Very cool - looking forward to seeing the details, particularly how heavy.
Old Feb 14, 2012, 01:56 AM
John_NZ is offline
Find More Posts by John_NZ
New Zealand, Taranaki, New Plymouth
Joined Jan 2012
Excellent! I am just working with a Wifi unit at the moment. Just need to find some more programming time to finish interfacing to it
John_NZ is offline Find More Posts by John_NZ
Old Feb 14, 2012, 02:00 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
3.6g without the lead and 6g with a 3GYS program box lead.
Old Feb 14, 2012, 02:25 AM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Old Feb 14, 2012, 02:47 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
That's excellent also! Opens the door to all sorts of devices that can link to it.
Old Feb 14, 2012, 03:39 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
FBL Bluetooth Interface
The Bluetooth unit can be obtained here: http://www.ebay.com/itm/290636551744
The 3GYS data lead here: http://www.rc711.com/shop/alzrc-3gys...le-p-5684.html
Description:
[Click pictures to enlarge]
The lead to the program box and USB link is:
GND - Red
VCC - Black
TXD - Red
RXD - White
The lead to the bluetooth unit is:
VCC
GND
TXD
RXD
This means that two wires in the program box lead have to be swapped. Carefully slide off the heat shrink and remove the read and black lead closest to one end. Be careful lifting the little plastic arms to remove the leads. Reinsert the leads the other way around:
VCC - Black
GND - Red
TXD - Red
RXD - White
Description: Name: DSC01922.jpg
Description:
Connect the lead to the Bluetooth unit with the visible gold pins facing up.
Description:
Power up a heli with the FBL unit and plug in the bluetooth lead to the gyro. The red LED will flash. Search for bluetooth devices on the PC/laptop. "linvor" will be detected. Add the device and enter a pin code of "1234". If it then asks to add a coms port to the device, check this and proceed (note the com port allocated). The red light on the bluetooth unit will go solid.
Turn on your Tx and wait for the gyro to initialize. Run John's app, select the com port noted above and click connect. You should get 3 greens lights, after a short delay.
As mentioned the unit weights 3.6g and with the 3GYS program box lead 6g. Of course you don't have to mount the bluetooth unit on the heli, you can just use it instead of the USB link, as a wireless connection. Just plug it into the gyro you want to change/program.
Old Feb 14, 2012, 03:50 AM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
^^^ Awesome!
Dr.M is offline Find More Posts by Dr.M
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
