Oxfordshire, UK
Joined Jan 2007
Sorry to hear that you are having issues still, part of the problem is that you are still trying to do things as you would in the FB world. Setting the sub-trims and ATV in the Monitor menu is not to trim the swash - it is to get the Tx and FBL unit in agreement about where stick-centre is. So by going into monitor and setting the zero and +/-100 the FBL unit will see "zero stick" when you have your sticks in the middle - you then use the FBL unit sub-trims to centre the swash servos. 1. If you are running the software, if you just connect the dongle to the FBL unit and connect the s/ware, it will show you your current settings. 2. you want to save the setting, go to top left click on "File" and then "Save Config Fie" Cheers, Mike |
Descriptive text?
I like your explanation of setting the TX sub-trims and ATV's, Mike.
It would probably be helpful for first-time users if there was a clearly written Quick Start guide, and then an extended, more comprehensive guide. Would it be easily possible to add those to the software - and could you squeeze in some text into the servo trim page? Incidentally, in the "Swash Travel" page, the descriptive text suggests that you check for binding - though it doesn't mention doing so with simultaneous full cyclic and collective stick deflections. With CCPM systems, there are two conditions to look out for - firstly binding, which I always check for by rotating the head clockwise by hand. You can then feel resistance at the binding points, whereas sometimes it's easy to miss seeing things actually coming into contact. Secondly, and especially when you're using an FBL head with long arms, you might run out of servo travel. This won't cause binding, but won't be good for the servos and will cause cyclic interactions. Now maybe the controller will never move the swash to the positions you can achieve on the bench, and I'm possibly locked into an FB mindset. Can anyone confirm this one way or another? (i.e. if the controller can move the swash to the extreme positions possible on the bench) |
United States, CA, Berkeley
Joined Jul 2011
Parkinson’s disease
Thank you John and Mike.
I have another issue that may not be even be relevant to gyro settings and this thread, but I need to make sure before I throw the heli and myself out of the window. Problem: There is a whole lota shakin’ goin’ on! All servo and swash settings and good, and all zero and max collective and cyclic are good. The gears are not wobbly and I put in a new main shaft and a new feathering shaft. No play in the shaft and no slop in the head. New set of bearings for the shaft is all that’s left for me to try. Yet as soon as I spool up, the heli manifests symptoms of pretty advanced Parkinson’s disease! Update: The issue was the Tarot head itself. The ZYX unit like the other equivalents is a marvel, but the metal head is soft and deforms easily, causing major head vibration that is not obvious at first but gets magnified with blades. When I asked the following question, I was thinking in the lines of high gyro gain causing the tail wag while hovering without rudder input. Are there any settings/gains I may have set to high (screwed up) that could cause this vibration even with no cyclic input and before it even lifts off the ground? It turned out to be FBL head issue anyway. |
Joined Nov 2010
Oxfordshire, UK
Joined Jan 2007
Joined Oct 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I need a bit of help, Got everything set up quite nicely but can't get good roll range without cranking the gain up too much (extreme 3d) with roll gain = 75, agil=60, pitch gain = 90, agil=60. Pitch semms to be ok as I can tilt back anf forth quite fast. But roll is another story, if I set the gain low say 60, I can reduce the roll shakes but very limited roll. What other parameters can I change to make it roll faster without shaking.Thanks in advance. FYI, I am using the original HK450Pro head but with the Flybar & the cage removed. This means the flybar arm contols are still being used. Ie: the swash travel related to the blade's pitch is identical for both flybared and flybarless version. Could this be the problem? |
![]() I find that pitch rate is faster than roll rate on my own 450, and consequently use about 6.5 degrees of elevator cyclic compared with about 8 degrees of aileron. Intuitively, you might think that the heli would have less roll inertia than pitch inertia, but maybe it boils down to collective management in a roll - and mine is as yet by no means perfect. I think there's a good chance the heli would fly better with a proper FBL head - and most of them, especially ones such as the RJX style one from HK, enable you to mount the head lower, which is bound to improve roll and pitch rate. For the small cost of an FBL head (around $15 for the HK one) I think it would make sense for you to try one. The Tarot head is also pretty good. I've found that the main blades can make a big difference to pitch and roll rates. I prefer the align 325 - style blades, which have a fairly thin airfoil section, concave towards the trailing edge, and I use the cheap "Pro 3D" ones. As a matter of interest, how much collective and cyclic pitch do you have - and what collective, elevator and aileron ranges are you using in the controller to achieve those? (presuming your TX ATV's are around 100) |
Strangely enough my 450 feels the same - faster flip rates on ele than ail. However, the 500 is backwards, ele is OK, but the ail roll is visibly higher. I guess each heli-gyro pairing has its unique quirks that need some tuning. I'm going to fiddle with the D/R on the Tx to get the same feeling on ele and ail rather than gyro tweaking. It's just so much easier and more predictable. |
| Thread Tools | |
| Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. | Twmaster | Aircraft - Electric - Helis (FS/W) | 0 | Oct 08, 2011 07:31 PM |
| Multiplex mc V2 servo programming PC software | Thomas B | Radios | 3 | Jul 23, 2006 09:49 AM |
