Old Feb 09, 2012, 05:03 PM
IFHELI is offline
Find More Posts by IFHELI
taking time on my ride
IFHELI's Avatar
United States, RI, Woonsocket
Joined Apr 2010
CX3X1000 USB Setup Software
The software can be downloaded here. I saw this posted on Helifreak today.
http://www.ky-model.com/copterx/CX-3X100USB.zip
IFHELI is offline Find More Posts by IFHELI
Old Feb 09, 2012, 06:09 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks, IFHELI. Added the link to the first post.
beenflying is offline Find More Posts by beenflying
Old Feb 09, 2012, 08:00 PM
ridge_racer is online now
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Interesting that my cable arrived today even with the tracking info still showing the item at ISC NYC...?? Thanks again all for making this software work with all 3 gyros. I'll give it a try on my functional 3gys..
ridge_racer is online now Find More Posts by ridge_racer
Old Feb 10, 2012, 04:39 AM
asasan is offline
Find More Posts by asasan
United States, CA, Berkeley
Joined Jul 2011
On Tarot ZYX, between blue and red lights which corresponds to HH and which to Rate?
asasan is offline Find More Posts by asasan
Old Feb 10, 2012, 05:09 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Blue = Rate
Red = HH
MikeHRC is offline Find More Posts by MikeHRC
Old Feb 10, 2012, 10:27 AM
tdriver is offline
Find More Posts by tdriver
tdriver's Avatar
Athens GR
Joined May 2003
does it work with the tarot usb cable?
tdriver is offline Find More Posts by tdriver
Old Feb 10, 2012, 10:51 AM
costasp is offline
Find More Posts by costasp
Greece, Attica, Athens
Joined Jan 2011
FyeTech USB-TTL
Originally Posted by 2Doggs View Post
No, the power needs to come from your flight pack, or a bec. You need to bind the RX to your TX too. There is no power used through the USB cable.
Finally the CX-3X1000 arrived and its works with FyeTech USB-TTL (disconnect the red cable from USB-TTL first) and the Software.
Thank you all for your help.
John thank you also for the software.
costasp is offline Find More Posts by costasp
Old Feb 10, 2012, 04:02 PM
IFHELI is offline
IFHELI's Avatar
Joined Apr 2010
Tdriver,
Yes.. It worked fine with the tarot usb cable I have.
Old Feb 11, 2012, 10:30 AM
ptern is offline
Find More Posts by ptern
Joined Oct 2011
USB to IR for Tarot ZYX
Does anyone interested an IR (Infrared ie: wireless) version of the USB cable? I am thinking of building one. Can be done easily with a pair of IR Tx & Rx. (they used to fitted on older laptops). I believe the Tarot comms is 9600 which is well accepted by the IR devices.
ptern is offline Find More Posts by ptern
Old Feb 11, 2012, 10:45 AM
ptern is offline
Joined Oct 2011
John (or anyone) could you post some info about the advance page and some description how to usethem. Lost and confused about the items in there.
Old Feb 11, 2012, 11:32 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Presets
You should find most if not all the information within this thread, but I guess it's getting pretty long by now!
If you've tried out all of the five preset models, it should give you a reasonable understanding of how the parameter values affect how the heli flies.
Let's say you've settled on one preset as your preferred flying mode. In my own case, I use model #5, tamed with 40% expo, and also 80% rates in normal flight mode.
The one thing I've needed to change thus far has been the tail parameters, to reduce tail bounce. The single parameter that had the most effect on that was tail deceleration. On my 450 Pro with a 9257 clone, I ended up with PID values of 70 30 15, accel 100 and decel 20 after quite a few battery packs of testing on a Lazy Susan, and those settings seem to work well for me in flight.
If you're using analog cyclic servos, you might need to alter some of the cyclic gains, but for now I've left them all at their defaults.
2Doggs is offline Find More Posts by 2Doggs
Old Feb 11, 2012, 12:21 PM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Originally Posted by beenflying View Post
Yes, the program box is nice for taking to the flying field, unless you're happy to take a laptop. Also for $5 plus shipping (for the USB link), it helps to make this gyro a good low cost option as well, without the limitations of the Tx programming.
Where can I get the USB link for $5
freshmint is offline Find More Posts by freshmint
Old Feb 11, 2012, 12:37 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Ac-rc
Here but of course there's shipping on top of that. They have plenty of other useful stuff you might consolidate into one order, however, to mitigate shipping costs.
Old Feb 11, 2012, 02:29 PM
John_NZ is offline
Find More Posts by John_NZ
New Zealand, Taranaki, New Plymouth
Joined Jan 2012
Version 1.16 of the software includes the descriptions for each of the advanced page items from the text that Jaahaavi put together (here). I just haven't released it yet as I need to finish off the Russian translation (thanks Ruslan).
If anyone else would like a different language and is willing to provide the translation, let me know.
John_NZ is offline Find More Posts by John_NZ
Old Feb 11, 2012, 03:59 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Shipping for the USB link only was $3. Not a bad deal IMO.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
