Old Jan 02, 2013, 07:09 PM
Grawyl is offline
Find More Posts by Grawyl
United States, IL, Plainfield
Joined Dec 2010
My servo suspicion has to do with a right roll crash that I had last spring.
The heli was in idle 1 about 15ft off the ground and without warning the heli rolled over to the right and planted itself about 2" into the soft ground. At the time I attributed it it static but, the weather that day was cool and humid (slight mist in the air) which is a very hard environment to build a static potential and subsequent discharge.
All of the servos survived that crash but I have noticed ever sense that pitch isn't always consistent with all 3 cycle servos and when movements get aggressive, it feels like the right cyclic servo isn't reacting the same as the others. It could be that with the DFC head, their isn't enough torque? My theory expands to the gyro trying to compensate for the servo issue and the result is the bouncing followed by the shuttering that happens avery couple of seconds.
Grawyl is offline Find More Posts by Grawyl
Old Jan 03, 2013, 09:18 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
If you're feeling experimental, you could swap out the servos to move the bad one to elevator, to see if the control glitch moves with it. It sounds like you should replace the servo though.
2Doggs is offline Find More Posts by 2Doggs
Old Jan 03, 2013, 03:24 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Yep, the Gotek's are only spec'd for 80Hz refresh rate.
http://www.hobbyking.com/hobbyking/s...g_0_07sec.html
As far as I'm concerned, they are not suitable for use on any function for any helicopter
Dr.M is offline Find More Posts by Dr.M
Old Jan 03, 2013, 03:39 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
I suspect HK have changed the spec in their description as a result of so many people reporting problems. My own experience is that the Gotek can be coaxed to run at 333Hz, but you have to keep a watch on temperature, and set the gain accordingly, all the while making sure that there's no binding in the linkage. Mine still works after more than 50 flights on the tail of one of my 450's, and to be honest I only bought it to see if it was really as bad as everyone made out. It's definitely a trap for the unwary, and there are lots of better servos at comparable prices.
Old Jan 03, 2013, 03:57 PM
cmavr8 is offline
Find More Posts by cmavr8
Chris
The Netherlands, NB, Eindhoven
Joined Sep 2010
Suggestion please?
I've also fallen in the "trap" but my tail seems ok.. (450)
Would be good to have a good replacement though.
cmavr8 is offline Find More Posts by cmavr8
Old Jan 03, 2013, 06:08 PM
ahamay is offline
Find More Posts by ahamay
ahamay's Avatar
Australia, QLD, Gold Coast
Joined Jun 2012
Originally Posted by cmavr8 View Post
Suggestion please?
I can highly recommend the TGY-S306G from hobbyking as a rudder on a 450. I've got them on both my PRO's and they are outstanding.
http://www.hobbyking.com/hobbyking/s...06sec_21g.html
ahamay is offline Find More Posts by ahamay
Old Jan 04, 2013, 06:05 AM
cmavr8 is offline
Chris
Joined Sep 2010
Thanks, so the extra torque of the Goteks is uneeded at a 450, right?
Old Jan 04, 2013, 08:49 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
The Gotek and pretty much all of the 9257 clones have enough torque to easily bend the tail pitch control rod on a 450, and they're man enough for a 500 tail. The 306 has enough torque to be used on 450 cyclic, and is perfect for the tail. The only downside is that it's a mini servo, and you need to use an adaptor to fit it onto the 450 Pro tail servo mount. When used on 450 cyclic, the downside is it's a bit heavy compared to the average mini servo.
Old Jan 04, 2013, 06:44 PM
Grawyl is offline
Joined Dec 2010
Thanks for the responses. I will work a little more on the heli tomorrow. Not much work in that regard happens during the work week this time of year (working dark to dark).
I will replace rx tomorrow and also check all wiring for any issues. Also need to recheck the gyro settings on the PC because I am also thinking I may have the gain set to high. And I will also start researching other servos to replace the cyclic servos.
Old Jan 05, 2013, 01:10 AM
cmavr8 is offline
Chris
Joined Sep 2010
I guess it will pay off if used in a FBL setup though...
Thanks for the suggestions
Chris
Old Jan 05, 2013, 02:20 PM
Grawyl is offline
Joined Dec 2010
Turns out its a bad servo. I had originally thought it was the right servo but turns out its the left. I caught it when reviewing the gyro set up where I noticed it didnt move right away to a stick command. Further review and testing resulted in no movement unless forcibly coaxed in the proper direction.
I have a spare but I will also look for a good replacement set. The hitec digitals look to be a good value and I have seen some good reports on the bluebird servos as well.
Oh, and I just got it back together and guess what; just started to snow....like a dang blizzard out there. It was nice and sunny and calm this morning with temp about 32f...
Old Jan 05, 2013, 02:52 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
With the 9257 clones, it's often the motor that fails in that way - the servo won't move until you nudge it. You can fix it by replacing the motor, but that's rarely worthwhile on cheap servos.
Old Jan 05, 2013, 03:35 PM
Grawyl is offline
Joined Dec 2010
Servo also started jittering. Either way, it doesn't work. Time to look for a nice set of cyclic servos.
Old Jan 05, 2013, 04:27 PM
DESIGN ENGNR is offline
Find More Posts by DESIGN ENGNR
Smyrna, TN
Joined Jan 2005
Align 510s have served me well on two different 500s. They can be had pretty cheap for set in the classifieds.
Dave
DESIGN ENGNR is offline Find More Posts by DESIGN ENGNR
Old Jan 05, 2013, 04:30 PM
Grawyl is offline
Joined Dec 2010
Thanks Dave, I'll keep a lookout.
Break in the weather. Got a couple fo test flights in and Everything seems to be working very well for the moment.
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
