Old Nov 28, 2012, 12:34 PM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Well worth doing a thorough check on the servo direction movements and the corrections after you have upgraded the firmware
MikeHRC is offline Find More Posts by MikeHRC
Old Dec 03, 2012, 10:10 PM
Waterfly is offline
Find More Posts by Waterfly
Waterfly's Avatar
Joined Oct 2011
Can anyone give an explanation of what Condition 1 and Condition 2 are? What do you use them for? How do you switch from condition 1 to condition 2 using your TX; or do you have to mess with the gyro settings?
I have an old version that did not have conditions and I can not find an explation.
Waterfly is offline Find More Posts by Waterfly
Old Dec 04, 2012, 03:08 AM
Busher is online now
Find More Posts by Busher
Joined Apr 2011
Conditions 1 & 2 are like 2 different setups within the gyro. It means you can have 2 separate setups and switch between them in flight.
It is controlled by using the gain channel, and you have to enable it in the advance menu of the 3.5 version software. There is a drop down box and one of the 2 options says switch condition, select that one and you will have the ability to switch through 2 conditions.
Make sure you have both of you basic settings the same, as a different condition can mean you have the main controls reversed in the separate condition. I set up in condition 1 and then if it is correct copy the setiings to condition 2. I do this whether I use the function or not just to make sure that any glitch on the gyro the 2 basic settings are the same.
If you set the condition switch then go to the gain channel in your tx and set up say -75/+75. This should allow the switch function to operate.
It can be used to change from mild to wild or say to try out different settings on maiden flights.
Busher is online now Find More Posts by Busher
Old Dec 04, 2012, 06:45 AM
Waterfly is offline
Waterfly's Avatar
Joined Oct 2011
Old Dec 04, 2012, 07:03 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
What I don't like about the conditions feature is that you have to set your tail gain in the FBL controller - and so you can't change it easily in the field (or even in flight) using your TX.
You can approximate to a similar effect to switching conditions by making use of dual rates, but conditions switching might be a great way of establishing the maximum cyclic gain setting.
I was surprised to discover that my CX 3x1000, which I bought not long after they came out, can make use of conditions switching, just by using it with the appropriate software. In my case, I use John_NZ's. There have been no firmware updates for the CX, so conditions switching was there from the get go.
I also believe that this latent conditions switching feature could be responsible for many reported glitches with the controller, when the controller somehow boots up into condition 2, for which the parameters have not been correctly set. Busher's strategy of copying settings across therefore seems like a very sensible precaution, even for people not using conditions switching.
It seems odd that the conditions feature would have been set up so that you could have different basic settings, though. It's not as if you're going to make any changes to your servo reversing and trim, and it would have been better to have those automatically loaded into both conditions, and have both conditions updated with any adjustments to the basic settings.
2Doggs is offline Find More Posts by 2Doggs
Old Dec 04, 2012, 07:42 AM
krisnov is offline
Find More Posts by krisnov
krisnov's Avatar
Indonesia, Jakarta Capital Region
Joined Apr 2012
Actualy, no matter how old your gyro is, 2 flight conditions has always been there all the time. Remember when we do all the setup using tx method, there are 2 basic default settings we can choose, F3C and 3D. Those are actualy Flight Cond 1 and 2.
So even if we set the Gear switch for gyro gain, we still can change betwen flight conditions at field using tx programming method.
krisnov is offline Find More Posts by krisnov
Old Dec 04, 2012, 11:50 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Hmm, my reading of the manual is that the two defaults you refer to, F3C and 3D are just two of the five preset models, namely - Beginner, F3C, 3D Soft, Hard Core and Extreme - that you get when programming with the program box or with the software.
Old Dec 04, 2012, 06:06 PM
ewoodcox is offline
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
so I am having a bit of a problem setting up my 3rd 3X1000. The blade pitch is backwards but ALE and ELE work perfect. I give it forward the the front two pitch down and the elevator pitches up, reverse works as exected but throttle up pitches the blades down and vice versa.... normally I would review the swash but the one normal swash mix does not allow that. I have gone throught the software, the programming box, I just can't get this set right????
Any ideas what I am missing?
ewoodcox is offline Find More Posts by ewoodcox
Old Dec 04, 2012, 06:21 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Everything's fine, just set your collective range value to a negative number instead of positive!
On my CX's, I do all the servo reversing in the CX rather than in the TX, then I can use the same model memory to fly both 450's.
Old Dec 04, 2012, 06:59 PM
ewoodcox is offline
West Monroe NY
Joined Feb 2009
thanks 2Doggs, worked perfectly
Old Dec 04, 2012, 08:49 PM
krisnov is offline
krisnov's Avatar
Joined Apr 2012
The factory loaded F3C preset to Cond 1 and Soft/Hard 3D preset to Cond 2 by default.
You can try this, connect the gyro to pc software and remember which flight condition was active, cond 1 or 2. Now reboot the gyro in tx programming mode using ail stick and change to the other flight mode and save.
Reboot the gyro and connect to pc soft again. You will see the active flight condition has changed...
Old Dec 05, 2012, 11:01 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Excellent! It's great to learn new things about this gyro! I've never tried TX programming, but I'll have a go!
Old Dec 05, 2012, 11:39 AM
fishfiend is offline
Find More Posts by fishfiend
Joined Jun 2008
I do exactly the same with my 3 cx units, the only thing I change is the tail gyro settings via the transmitter..and I have never had a problem using the programming box and I was a total newby to flybarless...but since I changed I've got a whole lot better![/I]
fishfiend is offline Find More Posts by fishfiend
Old Dec 05, 2012, 04:37 PM
Chubbs is offline
Find More Posts by Chubbs
Fly, crash, rebuild, repeat
United States, MO, Platte City
Joined Jun 2012
I've read through quite a bit of this thread, but haven't quite found the answer I'm looking for...
Can the CX3X1000 be programmed via bluetooth and android app just like the ZYX can? All the android software i've found is explicitly for the ZYX. Will it work with the copterX version too?
Are they functionally any different at all?
Chubbs is offline Find More Posts by Chubbs
Old Dec 05, 2012, 05:07 PM
VArchT is offline
Find More Posts by VArchT
SoCal
VArchT's Avatar
Joined Oct 2011
Originally Posted by Zr_Flyer View Post
looks like the pin is "5782", I don't have one to verify it though.
Good news, this has been verified as the pin, Enjoy!
VArchT is offline Find More Posts by VArchT
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
