Old Nov 17, 2012, 08:06 PM
mikejbb is offline
Find More Posts by mikejbb
Bolingbrook, IL 60490
Joined Mar 2008
I have a ZYX (not S) and updated to the non-s 3.5 software and tried it on a plane. I couldn't get the controls to work out and then I read that the S version supports planes... Previously I attempted to put the S software V3.5 on the non S ZYX and it never loaded properly. Has anyone gotten the S firmware on the non-S ZYX? In a previous page someone said they thought it might work, but I couldn't get it to work.
mikejbb is offline Find More Posts by mikejbb
Old Nov 17, 2012, 08:36 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Unfortunately it wont work. My guess is they used a different encryption key in the boot code, so the code that ends up in the gyro, after you flash it, is just garbage.
beenflying is offline Find More Posts by beenflying
Old Nov 17, 2012, 08:59 PM
mikejbb is offline
Joined Mar 2008
AHhh, yes I read the encryption code was different, but didn't figure out the rest. Thanks.
So then has anyone gotten the ZYX (non-S) with ver 3.5 firmware to correctly control a plane? I was completely connected and I tried to change to plane mode, but I could see the response was still like a heli, not a plane. Have I screwed something up.
Old Nov 17, 2012, 10:16 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I haven't heard of anyone using a non S version in a plane or X-copter. Even though both versions are v3.5 I think the S version only has these features.
Old Nov 17, 2012, 11:40 PM
krisnov is offline
Find More Posts by krisnov
krisnov's Avatar
Indonesia, Jakarta Capital Region
Joined Apr 2012
I dont if it'll work or not but have you tried to set the swash type to mechanical mix swash on zyx. Put your ail servo to ch1, elev to ch2, and rudder to ch4. Use Y harnes if you use 2 servos for ail. Just leave ch3 empty.
krisnov is offline Find More Posts by krisnov
Old Nov 18, 2012, 04:40 AM
Busher is offline
Find More Posts by Busher
Joined Apr 2011
I was under the impression you could use it so long as your non s version had the 3.5 software loaded. Somewhere down the line I seem to remember the programmer of the unit saying you could but I could not get a full and frank answer from him. I really cant see a problem with it but I have yet to try it and summer in the uk is definately over. Hope to get a plane to use as a platform soon.
I would imagine the worst situation would be that the gains cannot be reduced to zero so you switch off the gyro completely should you wish, I guess I would set up a low gain and a higher gain on the condition switch and switch to the low gains if I got in trouble.
Busher is offline Find More Posts by Busher
Old Nov 18, 2012, 05:45 AM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
I think the gain channel still acts as a proportional gain setting. The difference is flipping over the 0-point does not switch to rate mode, buts sets condition2.
Problem i found with conditions is you have to redo EVERYTHING on the setup. Servo trim, servo reverse, total gains, etc.. I opted just to use dual-rates on the Tx to chance flight behavior.
sp00fman is offline Find More Posts by sp00fman
Old Nov 18, 2012, 07:24 AM
Busher is offline
Joined Apr 2011
If you use Johns software you do not need to re do everything for the 2nd condition, just use the copy condition function to make the change then tweak the gains etc to how you want them, save the profile and send it to the gyro, and your done.
Old Nov 18, 2012, 09:18 AM
mikejbb is offline
Joined Mar 2008
It's been awhile since I tried using the zyx on my plane, but I'll try this setup next time I try it. I now have the HK rate only 3d gyro on it and it's fine, but it controls the rolls so they are hesitant, but they still happen. And the gain is set on the pot only as far as I know.
Old Nov 18, 2012, 12:05 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
I've always had a feeling you can do this with some clever setup. But I don't have a plank to try it... I wouldn't discount the non-s zyx just because it doesn't have a plane mode.
Dr.M is offline Find More Posts by Dr.M
Old Nov 23, 2012, 02:53 AM
Helinator is offline
Find More Posts by Helinator
Joined Nov 2012
Originally Posted by Helinator View Post
OK, just to be sure ...
Looking at the port of the ZYX unit with the ZYX-logo-label of the unit facing up
the pins would be (from left to right) ...
pin1=GND pin2=VCC pin3=TXD pin4=RXD
Right ?
Yes, this is correct.
Sorry, but we both were wrong.
This is the correction for the TAROT- or HK- ZYX PINOUT ...
ZYX logo facing up, looking at port from the side, from left to right ...
pin1=GND pin2=VCC pin3=RXD pin4=TXD
(This was already dokumented in post #254)
Happy cabeling !!!
Helinator is offline Find More Posts by Helinator
Old Nov 28, 2012, 02:25 AM
Hardy1966 is offline
Find More Posts by Hardy1966
Germany
Joined Apr 2006
I have an HK450 helicopter running with zyx-s and conventional receiver (orange 610). Now I want to upgdate zyx-s to firmware 3.5. Do I have to re-setup and re-adjust the zyx-s and the helicopter after firmware update?
Thanks for your help!
Best regards,
Hardy
Hardy1966 is offline Find More Posts by Hardy1966
Old Nov 28, 2012, 02:37 AM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
Best regards,
Hardy
No. All your settings will be preserved. You might have to tune the cyclic D gain down a bit. I think a value of 10 is a good start.
Old Nov 28, 2012, 06:15 AM
Germany
Joined Apr 2006
That's fine,
I think I will update, hope therer will be no abnormal termination.
Old Nov 28, 2012, 07:27 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
save an .ini file
As a sensible precaution, however, just be sure to save a .ini file prior to upgrading the firmware. Then you'll have a record of your settings which you can compare with the settings after the firmware upgrade or load into the unit if need be.
2Doggs is offline Find More Posts by 2Doggs
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
